3 1/2 " Front Wheels
Old Nov 30, 2006 | 10:34 AM
jhashba's Avatar
What do I need to do to get 3 1/2" Weld Draglites to work on the front of my 1995 Pontiac Formula. The calipers will not clear the wheels right now. I would rather not run spacers, if at all possible. I will be drag racing the car and I'm supposed to use stock brakes in the class I'm looking at.
Thanks,
Jim Hashbarger
Old Nov 30, 2006 | 12:42 PM
GreenDemon's Avatar
http://web.camaross.com/forums/showthread.php?t=312442
Read that, it should answer any questions you have.
Old Nov 30, 2006 | 01:55 PM
jhashba's Avatar
Thanks a bunch!!
Jim
Old Nov 30, 2006 | 02:11 PM
jhashba's Avatar
Any ideas on where to buy the "good" spacers mentioned in the article? It appears I need them to be either lug or hub concentric.
Jim
Old Nov 30, 2006 | 05:36 PM
Skulte sells them.
http://www.skulte.com/
But in all honesty, I run a set of the cheapies you can buy in any auto parts store. When you bolt the wheel on, make sure the spacer is centered behind the wheel as you tighten the lugs.
Moving to "Wheels and Tires".
Victor Lamb
Aug 26, 2017 02:52 PM
carguy0119
Apr 11, 2016 11:11 PM
akwa
Apr 5, 2015 05:09 PM
squarehead
Nov 21, 2014 08:02 PM
sleeperZ96BT
Sep 5, 2002 05:45 PM
