Thickest spacers I can use on rear wheels?
Old Oct 19, 2006 | 03:02 PM
NiteRider's Avatar
Hey guys, just need a suggestion or two... Currently i'm running 17' Z06 wheels all around, I think they're 56mm offset and I really dislike the way the rear wheels sit in so much. I just want to know what is the thickest spacer I can run on the rear wheels with stock studs would be. Keep in mind my camaro is also lowered. Thanks.
Old Oct 19, 2006 | 03:18 PM
LT1 POWR's Avatar
Re: Thickest spacers I can use on rear wheels?
What size tire are you running?
Old Oct 19, 2006 | 05:52 PM
Rather than a spacer, consider using a beefy adapter that bolts to your stock studs, and provides new studs of the correct length:
http://www.skulte.com/
Old Oct 19, 2006 | 09:35 PM
NiteRider's Avatar
That is a good idea, i'm just worried that the wheel will touch the quarter panel since this is a lowered car. I'm running 275/45/17's in the back and front. That's why i'm asking how thick of a spacer I can run or else i'd replace the wheels and just run a different offset. So we're back to square 1. How easy are those adapters to instal? Do they just sit in the existing hub and studs?
Old Oct 19, 2006 | 09:50 PM
LT1 POWR's Avatar
The adapter slides over the stock studs, it is held one by lug nuts and then your wheel mounts to the adapter just like it did on the stock studs, but now your wheel is moved outward. I guess your could go out and measure how much clearance you have between the outer edge of your wheel and the inner edge of you quarter panel, then you have the maximum size of the spacer you could use without rubbing. You can also get an aftermarket panhard bar to make sure your rear is centered under your car, and you can roll the lips on the quarter panel so it wont cut your tires if they do rub.
Old Oct 19, 2006 | 10:05 PM
I suspect you are running a 275/40-17 tire.
No one can answer your question without knowing the width of the wheels. You need both the width and the offset to determine where the wheel sits with respect to the inner fender and the outside edge of the fender.
Old Oct 19, 2006 | 10:37 PM
NiteRider's Avatar
They're 9' or 9.5' Z06 replica wheels. But I see your point. I'll buy myself some small spacers for now and just see how it looks. Even with a small spacer it should show a little bit of improvment.
Thanks.
Btw, yes, you suspect right. 275/40/17, my bad.
Old Oct 20, 2006 | 03:27 PM
BLK96Z28's Avatar
Question Re: Thickest spacers I can use on rear wheels?
Any pics? Im thinking about running the same size setup.
Old Oct 20, 2006 | 06:53 PM
NiteRider's Avatar
Just wish the back wheels sat out a bit more. I'll try a 1/2 inch spacer and see what happens.
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
dmaastr
9
Jul 1, 2002 02:22 PM
