What is my shift RPM?
Old Jul 26, 2002 | 09:26 PM
96z's Avatar
96z
Post What is my shift RPM?
Dumb question but where in the LT1 edit program is your shift point RPM located? In the transmission section? If so mine says 5700 RPMs...
Also what is normal and hot shift RPM??
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
Old Jul 29, 2002 | 05:06 PM
MichiganSkip's Avatar
Post
You will find the shiftpoint part in the "normal mode Shift points vs MPH" or Performance mode shift points vs MPH.That would be on the first window that comes up under A4 transmission. Kickdown and hot shift (WOT) shift points go by rpm AND mph. Both values have to be met for the trans to shift. Otherwise the trans shifts according to mph and %Throttle position.
Michigan Skip
Michigan Skip's Flamed 95
95Z28, K&N TPIS 150hp NOS & 27mpg!
MSD 6AL, Window switch,Ford SVO 24# injectors,
2.73's (3.42's to come) Edelbrock headers, Flowmaster exhaust
BMR SFC,LCA,STB
[This message has been edited by s_willis (edited July 29, 2002).]
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
Apr 16, 2015 09:57 AM
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
