Comp Cams 230/236 and Emissions ?
LMAO
I wouldn't bet on it, Im assuming you got headers, cats??
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
I have heard of people being able to get a CC306 to pass and the XE 230/236 isn't too far off of that. You will need cats for sure and a special tune that you put on as soon as you pull up to the emissions place. The car will not be able to drive with the tune necessary to pass. (if it does)
CanadianZ
CanadianZ
oldschool
Feb 9, 2016 09:21 PM
