PC to ALDL question, ie. programming with a homeade PC-ALDL cable
Old Aug 5, 2002 | 11:51 PM
MyGreenBabyZ's Avatar
Question PC to ALDL question, ie. programming with a homeade PC-ALDL cable
I found this topic in LT-1 Tech and im not really getting any responces (probably because im "leaching" of the original topic )
Well long story short. I would like to make my own PC to ALDL cable (to save some money) and i was wondering if i could use the interface to do any programming with a program like LT_1Edit.
Topic in LT-1 Tech: Topic
ALDL Schematic in Question: ALDL MONITOR
Edit: What about the 10K Ohm Resistor between A and B? will that be needed for my car?
Thanks alot,
T.C.
1994 Polo Green Camaro Z-28 A4
Modifications - Honker CAI, B&M Trans-Kit, MAC 1 5/8" Shorties, O.R. Y-Pipe, CHM Cutout, MPP2 Electric Cutout Plate, LT-4 KM, !AIR, !TB, !CAT, !TBAF, MSD 8.5MM's, MSD Coil, and a Bunch of Poly Bushings.
Best times: 13.97 at 101.06 MPH w/ a 2.26 60' and a 1.2 RT at Milan Dragway In Michigan
AIM : OneFireForU
My Camaro Site
[This message has been edited by MyGreenBabyZ (edited August 06, 2002).]
Old Aug 6, 2002 | 06:55 AM
kmook's Avatar
Advanced Tech Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by MyGreenBabyZ:
and i was wondering if i could use the interface to do any programming with a program like LT_1Edit.</font>
If you can use it for diagnostics successfully you should be able to use it for programming.
</font>
From the looks of that article you would not need it.
But since we do have a Computer Diagnostics and Programming forum and neither your question or Mikael's question were posted there i think it would be appropriate to try in that forum, so i'll move this there.
Thanks.
Ken
Old Aug 6, 2002 | 05:46 PM
Stock Z's Avatar
Post
I use the "Two-transistor interface" that can be found here:
http://www.andywhittaker.com/ecu/aldl_hardware_cont.htm
Use it for reprogramming and diagnostics, works great.
95 Z28 A4 Stock(for now)
Old Aug 6, 2002 | 06:03 PM
Post
Stock Z,
I think it was fred that said the two transistor interface is not as reliable as the interface using the MAX232 chip. i REALLY REALLY can not fry my PCM, its not in the budget. for now i plan on using this interface for diagonostics and perhaps later for a little bit of tweaking.
T.C.
AIM : OneFireForU
My Camaro Site
Old Aug 7, 2002 | 12:32 PM
94ZRagtop's Avatar
Post
The most commonly used interface for diagnostics & programming is found here:
http://www.mindspring.com/~amattei/aldlif.jpg
You do not need the 10k resistor between A & B. Only MAF TPI cars need it (and others using 160 baud and other software, but let's not go there right now ).
Carsten's interface should work OK on a 94, but I'd be hesitant about using it on a 95+ car. The ALDL signals are slightly different on a 95+, and you can get in to trouble pretty quick. Been there, done that, got PCM guts on my hands to prove it.
As for the 2-transistor, it does work, but it's not a slam-dunk for working every time. That's why I don't use it. The MAX232 based circuit is a slam dunk.
HTH,
Andrew
Old Aug 8, 2002 | 11:29 PM
Post
Thanks Andrew!
by the way. is it possible for me to use Cat5 cable between the rs232 on the computer and the aldl interface? if so what is the maximum length i can go? if i cant use cat5 cable what is the best suited cable for the job?
thanks again,
T.C.
AIM : OneFireForU
My Camaro Site
Old Aug 10, 2002 | 11:46 PM
97Whitez28's Avatar
Post
Cat5 is good up to 330ft, without any problems......I believe Cat5E has better insulation so it might be better to use in a car.....
I don't know if you can use it to make a cable though....??
1997 White Z28
SLP C.A.I
SLP Cat-back Exhaust
Parts Wanted
Mar 17, 2015 11:24 PM
grabbem88
Feb 10, 2015 06:20 PM
edman
Jan 25, 2015 02:41 PM
Jul 4, 2005 05:00 PM
