Auto X ray
Old Jul 19, 2002 | 05:33 PM
dasmoothtalka's Avatar
Post Auto X ray
will an auto x ray perform basically the same functions as a scanmaster will? also is there any difference in the handheld units and the cd program units? the particular one i am looking at is a handhel unit and Im trying to make sure it will work for what i want it for. I need it to figure out what my fuel curves are so i can adjust with a MAF translator. is this what i need? thanks
Old Jul 19, 2002 | 10:45 PM
blksunshine's Avatar
Post
Obd I or OBDII?
Old Jul 20, 2002 | 01:47 PM
Post
OBD II
Old Jul 20, 2002 | 05:46 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by blksunshine:
I am not sure if I can help you because I
have an Obd I and a4. And my auto x-ray
shows these parameters.
1.Desired RPM,E
Engine RPm,
Coolant Temp,
Manifold Air Temp,
A/C Pressure,
Map Sensor (in Volts),
Throttle Sensor(in Volts)
Throttle Angle %,
Batt Voltage
Bar Press (in volts),
L o2,
R o2,
Block Learn Cell,
L block Learn
R block Learn
L integrator,
R integrator,
L Inj. Pulse,
R Inj. Pulse,
Mass Air Flow (in gr/sec)
20.CCP DutyCycle
Idle air Mtr Pos
Learned Idle Pos
Spark Advance
Knock Retard
Knock Sensor
Egr Duty Cycle
Vehicle Speed
Engine run time
A/C clutch
A/C
Cruise control
Park/ Neutral
Brake Depressed
TCC Status
Fan #1
Fan #2
Air Switch
Loop status
Learn Control
I am sure what you want to use it for the blk learns and O2's and INJ pulse widths.
[This message has been edited by blksunshine (edited July 20, 2002).]
</font>
Old Jul 20, 2002 | 07:49 PM
moparman's Avatar
Post
The standard Auto Xray OBDII scan tool only does the generic stuff. You would have to get the enhanced software to really do a good job.
Parts Wanted
May 1, 2016 10:25 AM
drt
Sep 27, 2015 04:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
scottcba1
Sep 8, 2015 09:52 AM
tdigger9899
Sep 7, 2015 10:56 AM
