Opti Question
Old Jul 3, 2002 | 11:17 PM
TazZ28's Avatar
Post Opti Question
i am installing a crank trigger on my 396 stoker. I also purchased the FAST system. I have read posts that you can remove the hi-voltage connections out of the opti and use the remainder for cam senor
Has anyone done this ?
Also what parts do u take out of the opti so there is no more High voltage parts.
Old Jul 3, 2002 | 11:35 PM
kmook's Avatar
Advanced Tech Moderator
Post
First you only need to post the question once
Second if you look a few threads down on the 1st page you see there is a thread that contains some info about this already...
http://web.camaross.com/bb/Forum30/HTML/001074.html
I will close this thread and you can join in on that thread if you'd like. Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • Almost Alive: ?rwhp & ?rwtq Naturally Asperated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Jesel Shaft Mount Rockers,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
