View Full Version : Parts Wanted
- WIper Linkage wanted - 4th gen
- My '89 Iroc Z parts shopping list (I need parts!)
- WTB: Aftermarket LS1 Headers and Y-Pipe
- NEED rear wheel speed sensors for 98+
- WTB: LT1 shortblock in NC
- WTB: 16" chrome 5-star wheels
- Wanted, cold air intake
- WTB Wheels - Tires
- Looking for shorties headers for '97
- Lt1 Intake Wanted!!!!!!
- wtb moser 9 inch 3rd gen housing only
- Corsa 3.5 dual/dual pro series tips
- Wtb: 3.55 Gears, Ls1 Main Studs, 75 Lb Injectors!
- WTB: Carb intake for LT1
- V-belt Parts And 700r4 Cooling Lines !!
- WTB:auto shift plate, top dash pad 93-6 interior parts
- auto crossmember/stock lt1 MAF
- LT4 hotcam valvesprings/retainers/keepers
- 10 bolt cover for F body rear
- 4L60E Tranny in New York Region
- Wtb: Gears!!
- I need a set of lt4 valve springs
- Suspension, tire, 12bt/9", going on a diet
- sts kit wanted
- 58MM throttle body needed
- 3.73 gears
- 58 throttle body gasket needed
- WTB: Chrome or polished Aluminum Rims, FIREBIRD
- WTB: CHEAP mp3 player
- slp loudmouth
- Wide tires?
- wtb:82 scoop (or similar)
- WTB: Re-Loc brackets
- C6 wheels
- stock exhaust manifolds and ypipe
- I Need A Firebird-t/a Dash
- Tires needed (Wide)
- WTB: 98 up Trans Am Taillights
- WTB: Stock MAF 98 LS1, non-ported, PLEASE HELP!
- need a set of 24# stock injectors.
- Need LT1 Intake Elbow
- WTB: LT1 exhaust manifold air tube
- LT1 computer editing softwear
- Shroud
- Fog light switch with bezel
- '93-'95 Y-pipe and cat
- wtb cheap aftermarket t56 shifter
- [WTB] interior parts
- WTB Bumper
- WTB: LT1 engine wiring harnesss and PCM 4L60 E
- looking for rims for 95z28 convertible
- WTB stock 93-97 camaro hood
- Need a complete V6
- WTB: LS1 Front brake upgrade
- 1993-97 WS-6 Hood Wanted
- center caps for a 92 Z28
- wtb anything for a m6
- Zaino Products
- Fog Lights
- 1 peice t5 flywheel
- WTB Dash pad 94 z28
- WTB: MBA 6-speed aluminum pedal covers
- Heads for 1990 350
- Wiring harness 95-96 TA LT1 M6
- 4th gen wing TA
- WTB: Stock 5-spoke wheels
- LS1 performance parts
- Need 17x11 polished zr1's with 36mm offset
- Need 3.5 MAF
- headers/hood
- Stock Crank blancer pulley
- need some interior parts
- need front license plate filler for 98-02 TA
- Ebony (Black) 4TH gen seats wanted
- Various 93-97 Fbody body/suspension parts needed.
- Looking for an LT-4 intake
- WTB 6spd conversion
- Lt1
- WTB: Stock Intake Bellow (b/w MAF and TB)
- Console Pocket
- wtb: hooker LT y pipe.
- parts wanted.....
- Front driver side fender for 93-97 firebird/TA
- Need a 4thgen rear, preferably 3.73's if possible, NJ area
- Nitrous
- Wanted: th350 or th400 conversion
- 4th gen. Camaro/ Firebird dash- complete
- wheels
- In search of single aluminum lt1 head
- nitrous lines wanted, -4 only
- Gears
- Looking for a high flow cat....
- WTB: Stock Muffler + Tips for Camaro
- Door lock switch/power window switchs broke.
- WTB: LS1 Alum Driveshaft
- WTB: 6 spd insert piece for console and shifter knob for 99 Z28
- Anybody have a dual or tripple gauge pod set up for sale .
- Wtb: Hooker Catback Asap!!!!
- Catback
- WTB ss wing for a silver 97 z28
- WTB: T-56 for a LT1
- low mileage LS1 bottom end
- Throttle body plate
- wtb comp 306
- WTB: svo 30# inj
- WTB: DEH-P77DH Faceplate
- single cat install kit slp loudmouth
- I need subframe connectors!!!!
- LS1 fule line
- Looking to buy LT1 scanmaster
- Looking for Fuel Lines
- 94-97 Gas Tank With Sender
- LOOKING FOR 93-97 LT1 Radiator & Dual fan set up complete !!
- looking for a 93-97 Camaro POWER STEERING RESERVOIR LT1
- ZR1 wheels?
- POST ""carguyshu" is a honest seller
- looking for 16" wheels SS style or chrome
- WTB Front QA1 90/10 Coilovers for 93-97 fbody.
- wtb corvette rear panel w/ lites for a 3rd gen camaro please read
- 93 LT1 cooling fan
- WTB: Bose Cd Player, working 94/95 yr
- WTB: torque arm
- WTB - powdered metal LT1 rods
- Looking for Arizona Speed & Marine 58mm throttle body
- Wanted - Borla pipe
- WTB: 93 AND UP CAMARO HOOD!! HELP me please!!
- WTB: STOCK CAt from 93-95 lt1
- WTB Stock '96 LT1 valve covers
- Wanted stock crank and pm connecting rods .
- Stock MONSOON speakers
- Engine and PCM
- Wtb: 1.6rr's and Some Springs!
- Cable for 1995 Camaro from PC to Car
- LT1 k member, steering rack, body panels
- Wtb Monoblade
- wtb:monoblade
- 3.875" 4340 crank!
- WTB: 17" Torque Thrust IIs
- 15" Camaro/centerline wheels
- WTB: TNT wet kit: LID: Headers: true duals: FTRA/SSRA: bolt ons
- WTB : Passenger Side Fog Light
- Looking for a few M6 parts
- 95+ opti harness and vacum port
- WTB: various parts
- need a few parts for '94 Z
- Front WingsWest Piece
- LS1 coils
- WTB Front marker lights
- WTB: Forged parts
- Holley carb nitrous kit wanted
- wtb stock ls1 throttle body
- Wanted: vortec heads
- Boost,AF ratio & air temp Gauges....
- WTB: Keyless entry box / remotes lt1
- 93 Throttle body, 52 or 58
- waterpump/flywheel/starter/prostars/msd
- Need bulb socket IMMEDIATELY
- WTB: 88 and up 700R4
- wtb: a/c delete pulley for 95z28....!!!!!
- GM 847 cam
- WANT TO BUY: cc305 cam (276HR)
- k&n, moroso, lingenfelter CAI
- WTB LT4 castings
- WTB: Leather seats
- WTB: 1le front swaybar & acdeltepulley!!!!
- WTB: 3rd gen body parts
- Stock Throttle Body from 94-97
- 3rd generation stock or aftermarket wheels
- WTB: Hatch panels
- WTB: LT1 block, crank in NC
- WTB TRICKFLOW OR VORTECH Intake Elbow
- need a lt1 short block or long block
- 86 camaro
- [WTB] wheels for a 94 Z28
- WTB: a/c delete pulley for 95z28, and 3 more things
- WTB: 94-95 PCMs and wiring harnesses
- Z06 Frc
- WTB: Lowering springs for my 94 formula
- WTB: center caps
- I want a 97 and up 6-speed center console
- NEED ASAP LT1 6speed FLYWHEEL
- Wanted: LT1 Parts
- WTB: NX Composite Bottle
- Looking for headers,TB,1.6rr for LT1
- wTB 3rd Gen Y-Pipe Or info as to where
- WTB: nice grey steering wheel for a '95 T/A
- WTB: aftermarket torque arm
- wtb: universal dry nitrous setup
- 98-02 Camaro Hood
- WTB: 3rd Gen Pro-Kit lowering Springs
- WTB: Stock LT1 I pipe
- WTB: Lt1 intake and water pump bolts
- Will Trade Slp Loudmouth For Exhuast Pipe That...
- Need a SLP Loudmouth for 93 Lt1
- LT4 Knock Module
- LT1 Fuel Rail Covers
- looking for these..
- Im lookin to trade
- need ls1 stroker engine
- VENDORS....Ford 9" housing with bearings, moser
- WTB LS1 Coated Headers + ypipe
- WTB 93-97 hood hinges
- WTB 8.2" posi carrier for 70 camaro
- the 4 stock TB bolts
- WTB: Relocation Brakets for a Moser 12 bolt
- WTB 3.42 or 3.73 Gears
- Need 98+ M6 console
- WTT: Powdercoated Black 077's for C5 thin spokes
- Vortech Elbow Needed!!
- Wanted !!! Cam For my 95 LT1 Fair $$$ PLEASE!!!!
- WANTED, VORT ELBOW FOR LT1& O2 EXTENDER
- 1.6 rr's NSA
- WTB ZR1 wheels
- Need 98 LS1 6sp ecm
- Needed: 17x9" rims
- lower alternator bracket
- looking for chrome alternator or chrome engine lt1 parts
- Bolster/Lumbar Seat Harness
- Alum. drive shaft
- 94-95 z
- 96 97 ss Parts wanted
- Looking for a Rear SS Spoiler TRADE for super spoiler plus $
- bellhousing
- Wanted: Th400 Th350
- WTB Bare untouchd LT4 heads....
- Need stock manifolds and AIR system
- Zilver ZR1's
- Wanted Gta Wheels
- WTB: Third/center brake light for 98+ Camaro SS
- WTB '96 Camaro AM Hood
- Needed: Stock manifolds and dual cat y-pipe for 96-97 LT1's
- Lingenfelter SuperCold Air Cold Induction Intake
- WTB: Lt1 styled rectangle stanless exhaust tips
- WTB: Headlight brackets/Headerpanel 98+ Camaro
- Need 10-bolt, ..............NOW!!!
- WTB: T/A Rear End Girdle Cover for 10 bolt
- Need one piston ring
- WTB: Bare LT4 heads
- O2 extensions
- re:
- CAI,Headers,catback,shifter
- WTB 2 VISOR for a 94-2002 camaro
- Wheel Spacers Wanted
- Looking for 10 bolt with 3.73's
- Looking for a 93-97 T-56
- 2 Salad Shooter rims
- Wheels
- 93-97 oil dipstick tube
- WTB M6 consol plate for 97+ consol.
- wtb: vortech elbow and o2 wire ext
