PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. need eagle 077 rim
  2. Shocks,lca, Adjustable Panhard, Relocation Brackets
  3. Looking for a Trim Ring
  4. need a 10 bolt 28 spline 3 series open carrier
  5. 68' Camaro Rear End
  6. need a 52 mm throttlebody
  7. Comp Pro Magnum SA 1.6rr for 7/16" stud
  8. WTB: Passenger side t top 98 camaro
  9. In need of complete a/c system out of camaro or trans am LT1
  10. Wanted: Passenger side engine mount that bolts to K-member for LT1
  11. WTB 93-96 instrument cluster harness/plug
  12. WTB: True Duels for 94-95 MAC Headers
  13. WTB LT LS1 headers
  14. longtube headers for lt1....
  15. Need: Monsoon CD Player for 99 Bird
  16. Heads
  17. WTB - Autometer Phantom 5" Tach w/ shift light
  18. HEI ignition system~?~?
  19. Need 275/50/16 Tire
  20. Wheel hookup
  21. wtb: lugnuts/lug nut covers that will work on chrome ZR1's and a couple interiorparts
  22. needed, 4th gen lower a-arm and more
  23. WTB SS spoiler..
  24. Wtb:t56
  25. Tpi Intake Bolts
  26. 93-97 drivers side Trans Am or Formula TAIL LIGHT
  27. WTB: 10" Stealthbox/Thunderform Box - AMP Rack
  28. DS SWitch Panel and Door Handle Bezel
  29. WTB: Tranny cooler & 3.73 gears (for 93 camaro Z28)
  30. K Member for a V8
  31. WTB: Right Side Rear 1/4 panel and Left Side Front Fender
  32. inter, and ext. Parts needed for my car....
  33. 98+ V6 stock springs needed!!!
  34. Center armrest "door"
  35. Cats for 96 Camaro SS
  36. 1 arp head bolt needed
  37. driver side 1/4 panel
  38. Elec. Water pump needed
  39. opti plug!!
  40. AC pulley delete
  41. WTB LT1 Performance parts
  42. WANTED: McGuard Wheel Lock
  43. Headers for 95 LT1 Camaro
  44. looking for a 98-02 RH driver fender
  45. i want blackouts and third brake cover!
  46. SS Springs
  47. 97+ center console, m6
  48. need 2 17's Y2K wheels in silver or chrome
  49. 94-95 lm adapter
  50. wanted, used American TT2's in 17" for 3rd Generation
  51. MONSOON Speakers and CD PLAYER
  52. WTB Z28 Throttle body plate
  53. WTB - lowering springs for the front LT1 Camaro
  54. WTB: SLP Bolt on SFC!!
  55. WTB: 93-97 Camaro V8 Front Struts
  56. 1.6 Rockers LT1
  57. WTB: red undercar lights
  58. WTB: 93-02 Camaro or Trans Am rear body clips ! INDIANA !
  59. WTB: LT1 injectors!
  60. WTB: 93-02 Front Upper A Arm
  61. Need rims
  62. WTB: 10 Bolt Rear End Girdle
  63. T56 wanted
  64. 4.10 gears
  65. WANTED:Chrome Z06 or ZR1 Rims ASAP
  66. 94 z28 drivers seat
  67. two 17x10 ss 10-spoke wheels
  68. dash for 96 z28
  69. Need oil cooler adapter.
  70. 87 Camaro center console lid/ door armrests
  71. 87 Interior panels
  72. WTB: LT4 Knock module
  73. WS6 wheels
  74. ls1 front brakes
  75. BMR Boxed weld in Sub-frame connectors
  76. WTB: egr block off plates (lt1)
  77. spider gear
  78. LT4 timing set
  79. 1995 Camaro Dash Pad
  80. 1995 Camaro Hood Stock Green
  81. WTB: 93-97 Red front bumper cover needed
  82. 17" Rims,Tires and 36lb injectors
  83. 1-pair of P-275-40R-17 M/T-ET Radial's
  84. I Need An Ls1 F-body Oil Pan!!!!!!!!!!!!!!
  85. WTB: '94-97 Fbody fuel rails
  86. WTB: OEM black ZR1 or Z06 Wheels
  87. wtb nos bottle blanket and purge setup
  88. wtb 2 2 and 1 16inch pod gauges
  89. OEM Exhaust tips for 2002 Z28
  90. WTB: LS1 K Member
  91. need factory dual cat y-pipe with working cats
  92. LT1 starter needed
  93. Black Center Console Lid 93-97
  94. WTB G2 Super Springs
  95. Does any body have LT1 edit
  96. WTB Manual shift plate 98+ Camaro
  97. W.t.b. Cai For A 1994 Z28 Lt1
  98. cat back and y pipe
  99. WTB: Polished Valve Covers
  100. PONTIAC LT1 WS-6 Airbox assembly
  101. WTB: Bose speakers, Qtr. panels and bumper cover
  102. WTB-16" Slicks or 15" with rims
  103. Want 1 1995 16" firebird wheel
  104. WTB: tubular k member for 93-97 lt1
  105. WTB: Trailer hitch for '93+ F-body
  106. WTB: Conv. top switch and plate
  107. wtb: 93-96 or 97 up complete dash no blown bags
  108. WTB 98+ 4 channel backing plates
  109. Watned: EGR for '94 LT1
  110. WTB Autometer tach
  111. rear bumper cover
  112. lt1 parts needed asap
  113. WTB Factory I pipes.
  114. 94+ Bose passenger door speaker amp assembly
  115. Dual exhaust 3rd gen
  116. WTB Smog Pump Plumbing
  117. Wanted. Supercharger.
  118. WTB Drivers headlight assembly and brackets for 98+ camaro
  119. Drivers front fender
  120. 99+ fbody gas tank/fuel cell
  121. Needing a drivers side Door Handle Bezel 93-99 firebird/TA
  122. Wanted 94+ Camaro Bose CD
  123. A/C parts needed for 92 camaro
  124. WANTED: 2" lowering springs
  125. NEED T-TOPS for 93-02
  126. WTB: 94 4l60e! ASAP
  127. Needing a rear view mirror and under column lower dash panel!
  128. NEED T56 slave cyl. studs!! And LT1 elec. w/p ASAP
  129. LS1 engine harness.
  130. Random little parts needed, please help
  131. Need a Few LS1 Brake Parts
  132. LT1 fuel rails
  133. WTB: Drag radials or ET streets
  134. OBD1 PCM for 1994 Z28
  135. wtb: chrome c5 y2k rims/tires
  136. wtb: fuel pump for lt1
  137. WTB: LT1 M6 Flywheel
  138. 2001 LS1 Headers/y-pipe
  139. wtb radio trim and tweeter cover
  140. WTB 96 firebird A/C vents
  141. WTB O2 Sensor Extension Wire
  142. WTB:Firebird headlight motor
  143. Needing 93-96 Camaro Dash pad/panel
  144. Want some MAC mid Headers
  145. WTB #22-24 injectors
  146. 98-02 style SS spoiler
  147. WTB: EIGHT 1.7 LT1 rockers for intake valves
  148. LS1 Backing plates
  149. Rear Bumper Cover
  150. optispark wire extention needed.
  151. WTB: LT1 parts
  152. TNT LT1 plate wanted...willing to trade ls1 power ring for it
  153. WTB: Vigilante 3500 stall Converter for 700-R4
  154. Wtb: Ls1 Aluminum Driveshaft
  155. WTB: sweet thunder mufflers
  156. mounted drag rADIALS
  157. ac compressor for a 94 Z
  158. WTB: 3" Electric Cutout
  159. looking for seats
  160. WTB:: OTVC Kit W/ Plug Wires
  161. Transmission brace needed
  162. wtb: lt1 intake elbow
  163. WTB: Hatch Struts
  164. 83 lb fuel injectors wanted!!
  165. 83 lb fuel injectors wanted!!
  166. WTB: SLP dual-cat headers
  167. Help !!!! I Need Interior
  168. WTB: Front ground effect for 94Z
  169. WTB stock LT1 injectors
  170. WTB LT1 part
  171. WTB Mufflex 4" catback
  172. T-56 for 95 camaro needed (no clutch)
  173. Headlight covers
  174. WTB: 93-97 T/A Front Bumper Cover
  175. WTT: Y2Ks for Gray z06
  176. SS Ram Air Kit
  177. WTB: 2 17x11 ZR1 50MM wheels
  178. '69 Camaro rims
  179. WTB cam and roller rockers
  180. Used or Rebulit Posi for GM 10bolt disc brake
  181. WTB: torque converter
  182. WTB intake air temp (IAT) sensor
  183. 98-02 front end conversion
  184. WTB: LT1 intake manifold
  185. Lloyd Elliot/AI Heads and Cam
  186. WTB: Eibach prokit with bilstein shocks
  187. WTB: Line from master cyl. to slave.
  188. WTB-a BLACK passenger side mirror housing
  189. WTB: 1 Salad Shooter
  190. Front lower control arm (a-arm) bushings needed
  191. looking for transgo shift kit and ARP head bolts
  192. NX nitrous kit and accessories needed
  193. Need ARP 7/16 rocker arm studs and guideplates
  194. WTB: Upper Spring Seats
  195. WTB - subframe connectors & strut bar
  196. WTB: 98 Z28, LS1 Parts
  197. WTB: LT1 throttle cover
  198. WTB: CAI..MAF sensor.... LT headers...y-pipe....58mm TB
  199. WTB: Stock 24# fuel injectors - LT1
  200. WTB 75-81 trans am DS fender
  201. WTB New vented opti spark.
  202. WTB/WTT: your suspension parts for my LT1 engine parts
  203. need a few 98-02 camaro parts look inside
  204. Tach with shift light or not
  205. WTB: Throttle and cruse cables
  206. WTB stock drivers side a-pillar
  207. WTB:ory for lt1
  208. Parts wanted - 42#injectors,exhuast pieces&more
  209. wtb: longtube headers
  210. Camaro Center Console 99-02 Manual
  211. WTB Battery tray
  212. Intake rubber elbow
  213. Stock LT1 Valve Covers
  214. wtb 1-2 chrome ss 10 spoke rims
  215. wtb: true dual system for lt1
  216. MSD Module 6400 RPM
  217. I want your stock V8 Exhaust! WS6 or F-Body!
  218. Need T56 and Clutch for LT1
  219. Wtb: Low mile 4l60e (ls1)
  220. Need air box & headers
  221. Weld Drag Lites or Pro Stars
  222. 70-77 Camaro Wanted Running or Not will Pay up to 800.00
  223. WTT: 4L80e for 6sp
  224. Auto shifter and cable
  225. WTB- 315 nittos
  226. wtb chrome zr1s
  227. Firebird wheel center cap needed
  228. 3.42 Gears for Series 2!!
  229. WTB AC line right by Alternator on LT1
  230. WTB: 98 LS1 Parts
  231. WTB: ALDL Cable for OBDI
  232. WTB: LS1 'bird Taillight Harness
  233. {SC} WTB: LS1 front caliper carriers/guide pins
  234. WTB: LS6 intake
  235. WTB - Harlan, Raptor, or similar shift light
  236. WTB: 3 Channel rearend with 3.42 gear
  237. Backing plate for lt1
  238. Body Trim......93-97.....R/S front fender
  239. LE1/LE2 or equivalent heads. Cash in hand!
  240. WTB: White 30th anniv 17" SS wheels
  241. LT1 AC compressor
  242. WTB cheap 12" electric pusher fan
  243. Need 10 bolt Posi rear
  244. WTB:93-97 Black Outs for Front Headlights, and Back Tail Lights.
  245. rear ls1 brakes
  246. cold air intake
  247. Dark Grey Interior Parts......97 UP
  248. Jet Hot y pipe for 97 LT1
  249. Passenger Side Airbag Cover, Silver Fenders and Bumpers, and some more
  250. Oil Pressure Sensor 94 3.4
