View Full Version : Parts Wanted
- WTB: 6 speed console top plate w/ boot for trans am 93+
- LS1 center bolt style valve covers
- a/c delete pully(1le)
- WTB low milage stock Z28 springs for 93-97 LT1 car
- WTB: 58mm Throttle Body, MSD 6AL, Adj. fuel pressure regulator for 94' LT1
- Need an AIR pump for a 94 LT1
- Supercharger
- Wnated!! 58mm throttle Body, MSD 6AL, and Adjustable Fuel Regulator for 94' LT1
- LT1 needed.
- WTB LT4 Composite valve covers
- 98-02 camaro fenders
- Looking for a rear end girdle for my 10 bolt
- Spohn Adj. Torque Arm Needed
- 1le Ac Delete Pulley !!!
- need 99+ rear end e-brake cables and mechanism
- 93-96 camaro shif boot retainer ring
- Air Pump Needed LT1
- 1991 Center hub caps WANTED
- Needed: Power Hatch Motor
- Some parts needed for 95 z28
- firehawk emblem grille, licese plate cover
- K Member!!
- 94-02 Power Mirror Switch...
- '01 Trans Am body/interior parts wanted
- WTB: LH Fog Light for 93-97 Z's
- WTB: '94+ Oil Pressure Sensor
- Wanted: Damaged/Junk LT1 T56 bell housing
- WTB - TPIS Happy Hooker
- 2 front wheels
- used ss hood needed
- wtb AFR 195 aluminum heads/HSR intake
- broken or worn parts wanted
- 94z28 stock exhaust tips. Black rectangle ones
- Rear Bumper Cover
- Cruise Control Cable
- wtb.. ac delete bracket/pulley for my LT1..
- WTB clutch braided line
- Valvetrain parts
- WTB: 6-speed conversion
- WTB: y pipe for shorty headers
- Stock Intake Elbow Air Silencer
- WTB: Alternator Reloc Bracket
- WTB 94 LT1 engine wiring harness
- WTB: 4th Gen Pedals
- 6-Speed Transmission + converting parts
- WTB: 4G63 Shortblock
- Anyone parting out a car?
- WTB 95+ opti harness
- Looking for Drivers side Stealth Box....
- Looking for black (ebony) leather seats.
- Power Steering Pump for 94 Z28
- WTB Factory bose cd player 94-96 z28
- Looking for Grey Leather Seats
- Firebird/T/A parts wanted
- WTB 97-02 Factory Switches & harness
- Need driver door latch for 94 camaro
- WTB: 4thgen ebony REAR leather seats
- suspension parts wanted
- WTB - Replacement Convertible Top - Blk
- Looking for shiftboot, ashtray, and brezel for 95 camaro m5
- Body parts wanted
- I need adjustable LCA's
- Wanted : 58MM, Borla Corsa or GMMG for LT1, EWP, 160*, Suspension Parts LT1
- Looking for t-top shades!
- 3.73s, headers for 3.8
- Suspension Parts wanted!
- Need a tbi 2.8
- WTB Headlight wiring harness
- WTB: LT1 TA pass side skirting
- misc. pieces needed
- Engine Block
- tubular K member
- Strano swaybars
- WTB - Fuel Pump/Sending Unit for 96 Z
- WTB: Parts for a ’95 LT1 Trans Am
- WTB 4th Gen CONVERTIBLE rubber weather stip
- Need 98-02 Firebird/transam Fenders!
- Wtb headers for lt1 96 camaro
- WTB: Next Generation year one Windshield decal
- T-Top Black a-pillar plastic for a 94 Camaro
- hypertech programmer for LT1 1994
- WTB: 95 trans am passenger tail light
- Trans Am 5 spoke stockies
- WTB: 98 ls1 ECM (PCM)
- Accelerator cables
- '93-'96 firebird/formula/TA 6spd shift boot, trim ring
- WTB Supercharger kit for 97 LT1
- Need A Stock Maf Meter For Lt1
- WTB: Stock Exhaust Hanger
- WTB: SLP 2OTL catback
- MAF sensor
- WTB: front strut mounts
- 93-97 Camaro Front Front Hood/nose Bra Wtb!!!
- wtb heads
- 93-02 HARDTOP A pillar covers
- Stock Non Bose CD Player
- WTB: Intake elbow
- WTB: T-56 inspection/dust cover
- need trans bracket
- 4th gen Front Seatbelts
- LT1 crank position sensor
- Body parts... = (
- Wtb: Lt4 Km
- misc convert brackets
- License plate bracket for the front.
- Vented optispark swap parts (used or new)
- WTB: Stock SLP "dual-dual" Firehawk/SS catback
- Steering Wheel
- 97 Camaro Dash Cluster Needed !!!!!
- stock exhaust tips
- Mirror cover (drivers side inside)
- WTB: Front Struts w/ springs.
- 96' Cruise Control Lever Wanted
- WTB LT1 rear caliper brakets
- BMR springs, Koni or SLP Bilstiens
- WTB: Black Carpet and Stock Exhaust
- WTB: LS1 Complete
- LS6 or LS1 intake manifold
- 10 bolt 8.2" POSI carier
- WTB 93-97 Trans Am front bumper and left front fender
- WTB: V-Opti 95 A4 PCM LT4 knock
- '99 SS brake light
- Wtb Cai
- WTB:OBD1 PCM for 95 M6
- WTB 52mm Throttle Body
- WTB: beehive springs & retainers
- WTB: Single Smoked Taillight Cover
- WTB Acellerator/throttle Cable from a 93 Fbody
- MAF and stock CAT
- Any Long tubes, cutout
- WTB rims (welds)
- WTB ram air hood for LT1
- Lt1 Block Needed
- Wanted: Rear hatch glass for '96 camaro.
- Illinois long tubes wanted
- I need a 95 LT1 4L60E wire harness!
- WTB 2800-3000 stall.
- WTB 93-97 Camaro red front bumper cover
- WTB: LT4 valve spring set
- WANTED used camshaft for Lt1
- WTB: 93-96 Drive Side A Pillar
- Need IROC bodykits
- WTB shfter boot for 96 TA
- LT1 Camaro Body parts wanted
- Fog Light
- lt1 oil pan
- wtb: driveshaft
- WTB: Headers & Y pipe for a 94Z
- stock ls1 trans mount
- WTB: LT1 CC306 with great miles and driverside quarter panel in great condtiion!!
- shifter boot and plastic trim
- LT4 timing chain, RR's 1.6 and computer
- Complete LS1 / t56 setup
- WTB LT1 SLP Loudmouth Adapter Kit
- WTB: 4th Gen Stock Upper and Lower Front Control Arms
- WTB: Stock 98-02 Camaro headlamps
- LT1 AC lines
- Need 1986 Front bottom Spoiler & Speedometer
- WTB: Lt1 carb conversion parts
- wtb stealth box
- Wtb Lt1 Stock Maf Mass Air Meter
- wtb pro stars
- WTB: LS1 Front Brake Conversion
- hvac delete plate needed
- wtb:built 4l60e,alum.ds,torque arm,performance heads
- Need Front Bottom Spoiler For 79 Z28
- wtb delteq/ltcc and cam
- Nonvented opti wiring harness
- Need one chrome stock 98-02 rim
- wtb obd2 tuning software
- WTB: woodruff key-modified balancer hub, opti driveshaft
- WTD: Autotap
- WTB: GM LT4 Hotcam Kit
- WTB: 93-97 WS6/Firehawk air box
- T56 Flywheel
- Wtb:obd1 Lt1 Ecu
- Need heater hoses 96LT1
- WTT....TCI Streetfighter converter for......
- WTB nice graphite or black carpet for 96 TA
- tv (kickdown) cable off of a 93 fbody
- Opti Vent Harness
- Wtb:polished 3.5" Maf Ends......
- WTB thirdgen a/c delete box
- need LT1 block, got one?
- LT1 Parts wanted! (valvetrain, elbow, fuel rail covers, exhaust, suspension)
- 93 LT1 A4 throttle body
- Wtb Asap Le2 Setup
- looking for lt1 engine.
- WTT/B Weld front runners, skinnies
- wtb cc305 cam
- wtb :wiring harness
- wtb: LS1 rear
- looking for a new spoiler...not z28 stock
- Lt1 T-56
- Wtb: 16" F Body Rims
- 98-02 T/A taillights
- LT4 HOT CAM and springs
- Need msd ign box
- WTB y-pipe plus header install
- Broken Guage Cluster or Red Camaro Needles from 97-02 Camaro or 97 LT1 Z28 Cluster
- wtb:12 bolt or 9inch
- WTB: AIR pump for '97 T/A
- wtb..brake booster and intake manifold gaskets
- Y Pipe for LT's
- T56 Conversion....
- ********looking for Air-Box Assembly ultra-z********
- WTB LS1 parts: mids/lt's, lid, ls6 intake, etc
- WS6 Emblem
- WTB: Black SS Spoiler
- Mac Header Wanted
- ABS sensor 94 Firebird formula...
- Front Ground Effect
- HPP for 94 fbody
- Oxygen Sensor Extensions
- need posi for 10bolt 8.5 81 camaro rearend
- WTB: LT1 Parts
- WTB: LT1 Valve Covers
- 94-95 PCM / Computer OBD1
- i need lt1 lifters. stock/replacement not comp r's
- Need harness plugs for power seats
- Fuel Tank
- WTB: Rear end TA Girdle
- looking for inline fuel pump
- 85 z28 parts needed!
- headlamps for camaro 1999
- Slp 2otl
- WTB: MAF Rubber coupling
- LTB Back Seat Bottom...
- WTB 95 timing cover
- WTB: LT1 Vortech or Procharger Kit
- hood wanted
- WTB: LS1 T56 Input Shaft
- WTF 30 or 36 lb/hr fuel injectors
- TTOPS... need to buy asap. (4th gen, fbody)
- Wanted, Canton 15-242T oil pan
- If you have LT1 edit please read this forum!
- 1993-02 camaro passenger quarter panel in michigan needed?
- Need lt1 valvetrain parts
- Sub Frame Connectors
- WTB 1998+ Upper Console For 6 Speed
- WTB: Oil Pan for 350
- WTB LT1 Performance
- Driver's side visor, Camaro (grey)
- i need a stock shifter boot for 98+ t/a or camaro
- Wanted Pacesetter Headers And Y Pipe Please!!!!
- Wanted LT1 T56
- Wanted , LS1, 4.8 or 5.3 throttle body cheap
- wtb a torque converter for my 94 z28
