PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96
  1. Wanted: 245/50/ZR16 tires
  2. WTB: 58MM TB & Mass Air & LongTubes ect
  3. WTB: o2 sims
  4. Looking for a 94-97 Z28 near chicago
  5. wtb: AFR 195 or 210
  6. need power tuner
  7. WTB - Corbeau Adj. Seat bracket...
  8. WTB: NOS Brand EFI 58mm Throttle Body Nitrous Plate
  9. WTB: Clear corners
  10. Wtb : Fast Computer
  11. WTB: 2" wheel adapters
  12. WTB: CAi
  13. Anyone have a good cond. stock cat FS
  14. Need driver's side sun visor w/mounting bracket
  15. Sony amp 600w or up
  16. WTB: 52mm TB and underdrive pulley for my 93
  17. wtb: rear rotors and a scan master
  18. WTB: REAL WHITE OVERLAY FOR MY 97's HEADLIGHT PANEL
  19. 58mm TB and cc305 cam
  20. need a few things
  21. in need of 97+ Driver's seat recline adjuster...
  22. Looking for a set of grey 4th gen seatbelts.
  23. Need a set of rims 245/50/16, for Autocross
  24. wtb: stock lt1 balencer
  25. fuel pump
  26. need black interior for 3rd gen
  27. LT1 clutch slave, lines, fittings
  28. *SLP LOUDMOUTH EXHUAST* LS1 01ws6
  29. WTB LT1 Bare Short Block
  30. WTB 5spd trans for '97 3.8L
  31. 3.73 gears
  32. WTB 10lb bottle of Nitrous
  33. valve springs for .550 lift
  34. WTB BMR boxed SFC's
  35. WTB: TA leather shift boot and handle for A4
  36. WTB-97+ stock chrome rims
  37. WTB: M6 console
  38. WTB: A/C compressor
  39. Looking for 93-96 Z28 cluster
  40. Anybody parting a '97+Camaro? or have ss parts?
  41. looking for a phantom trans temp gauge
  42. Wanting To Trade Complete 350 TPI motor with 78,000 miles for a 383 shortblock
  43. Fog lights wanted:
  44. WTB BMR K-member
  45. WTB NX bottle heater
  46. Long tubes
  47. WTB 4th Gen body
  48. Anyone have a couple BFG Drag Radials (preferably used) they wanna sell quick?
  49. Jason Cromer
  50. WTB: wheels with tyres
  51. WTB: LT4 AFR Heads
  52. Y Pipe
  53. WTBstock 95 LT1 oil pan
  54. Need Plug wires for a 93-97 Z28
  55. 97+ 6 Speed Center Console
  56. WTB camaro car cover for 94
  57. WTB / Trade Cam
  58. loudmouth
  59. WTB: T-Top
  60. WTB: Intake elbow
  61. WTB LS1 4 bbl manifold
  62. wtb; ACCEL FUEL INJECTION HARNESS
  63. WTB AKM Cable
  64. spohn torque arm
  65. 2800-3000 stall torque converter
  66. wtb trash lt1 heads
  67. WTB 1994 Z28 shift cable
  68. I NEED A LT1, 383 STROKER, or 355 engine!!!
  69. WTB: Cold Air Intake System for 95' Trans Am
  70. Stock struts/springs
  71. needing a manifold
  72. WTB...Bracket that holds ignition, module and Air pump to motor.
  73. Flywheel dustcover
  74. LT1 Rear Disc Brake Lines w/o Traction Control
  75. WTB: lt1 starter, HM balencer, and some other stuff
  76. Need 12lb Vortech 8 rib Crank Pulley
  77. stock radiator 96Z
  78. LT1 S/C or H/C
  79. 94 headers
  80. WTB: True dual X-pipe setup
  81. Lookin for an intake elbow, anykind will do.
  82. WTB: Stock Black Valve Cover(s)
  83. Pewter Rear Panel
  84. LS1 TA taillights
  85. Shaker Scoop Retaining Ring
  86. need some stock injectors
  87. WTB: 3200+ Torque Convertor
  88. WTB: Stock Rear Axes For 94z28
  89. Parts for 2000 Z28
  90. 2.00 and 1.56 valves....
  91. WTT: My Borla for 1.6rr or nonvent opti
  92. Need 1 rear 17x11 Grand Sport Wheel
  93. SS Spoiler
  94. Wanted: Stock LT1 Exhaust manifolds
  95. Looking For Ss Spoiler
  96. OBDII to OBDI connection for my laptop
  97. WTB: LT1 fuel rails
  98. Looking for a powerglide.
  99. 98+ e brake cables, brackets, and power window switch
  100. WTB: 1LE intake elbow
  101. stock amber turn signals for 93-97 Firebird/TA
  102. 4 gen two tone grey seats near pa,oh,ny
  103. WTB: LS1 Coil Packs (Left & Right)
  104. Black Seatbelts for 3rd gen, front and rear
  105. T-top
  106. Wtb 01-02 Ws6 Rims
  107. Stock CD player
  108. WTB: Interior pieces
  109. Ground effects and ss hood & ss wing
  110. Airfoil nut
  111. Anyone have a stock valve cover?
  112. Wtb: 224/236
  113. alternator for '96 3.8L v6
  114. want a cheap f-body
  115. Interior parts
  116. 93 slp y-pipe
  117. Z28 or SS stock catback
  118. real LT4 motor
  119. WTB 306 or similar cam
  120. wtb aluminium driveshaft
  121. Wanted Loudmouth!
  122. WTB 16 inch DR's
  123. wtb
  124. LT1 Edit
  125. WTT: C5 wheel sizes
  126. 3.5" or 4" catback and/or Y pipe for Hooker LT's
  127. WTB: pro 5.0 shifter 94 camaro, mac headers
  128. 93-2000 timing covers!!
  129. WTB: Stock Rear Sway Bar Mounting Brackets
  130. WTB 4, Real GM 17x11 rims, black preferred
  131. Headers for LT1
  132. LT1 fuel rails
  133. steering column
  134. 1/2 inch Lowering Springs...
  135. 17" and 18" Tires
  136. Need used 4.10's
  137. WTB Y2k center caps
  138. WTB LT1 injectors
  139. WTB: Wheels
  140. oil dip stick
  141. WTB Intake Elbow for a 97Z
  142. LT's and blackouts
  143. could some one please run a car fax for me
  144. Control Arm Relocation Brackets
  145. Looking for LS1 Stock MASS Aif Flow
  146. 4th Gen roller
  147. Driver's side door panel for 3rd gen
  148. WTB: 2 inch spacers to fit zr1's on 3rd gen
  149. Few basic LT1 things
  150. Wanted LT1 SS
  151. SS Spoiler
  152. WTB: CAI for 94 Z28
  153. WTB: NEW Direct Port N20 system...and Ported LT1 Intake, BFG Comp TA 275/17 Tires
  154. i need the lt1 firebird upper dash piece
  155. look i need all these parts for my LT!
  156. i need a rollin chassis"95 Formula"
  157. needed...3" mandrel bent I-pipe
  158. wtb rear diff
  159. Superram Runners And Plenum
  160. Stock CD player for '96 Camaro
  161. TRANS AM Door panals
  162. WTB: Monsoon Door Speakers
  163. WTB: clutch line
  164. WTB: Autometer Gauges
  165. WTB: Upper dash pad 97+
  166. slp y-pipe
  167. slp y-pipe
  168. Looking for Beige kick panels.
  169. wtb: 98-2003 camaro z28 or ss
  170. WTB: T56 conversion kit for LT1.
  171. Need Short Y Headers
  172. WTB Center console lid
  173. i want a set of weld wheels for a camaro
  174. hood needed
  175. Want a T-Top Conversion Kit
  176. Trade my TH400 for your T56
  177. Need a set of rockers
  178. L.E.D lights
  179. 3rd gen left tail light and black seatbelts wanted
  180. '01-'02 Camaro steering wheel with audio controls /M6 console wanted
  181. WTB 21 mm 3'rd gen rear swaybar
  182. nedd some parts
  183. WTB 1 set of 98+ Camaro headlights
  184. wtb lt1 block
  185. need Full thread lugnuts
  186. WTB: Need LT1 Moter Mount
  187. WTB 93-97 T/A Driving Light
  188. damnit firebird passenger door
  189. 93 Exhaust WTB
  190. 93-97 black camaro hood.. good paint..
  191. WTB: Hurst Shift Knob
  192. WTB: stock lt1 crank
  193. SS Style Spoiler
  194. Wtb: One (1) 42.5# Bosh Injector
  195. quad
  196. WTB: lowering springs/ shocks/ struts
  197. wtb: impala heads
  198. Need stock airbox ASAP!!!
  199. WTB: Rear Calipers and Brackets
  200. WTB: 4200+ stall converter, non-lockup
  201. WTB: 98+ Lighted HVAC controls w/ knobs for Firebird/Trans-Am.
  202. 94 AC FAN speed & temp knobs
  203. WTB: Stock black plasic CAMARO grill...
  204. WTB: Rear Suspension bump stops
  205. WTB following interior items (Firebird)
  206. ypipe, simms, and extensions
  207. WTB: 2OTL (94-95 single cat)
  208. Exhaust Tips!!!
  209. WTB: Guages - Fuel Pressure, Nitrous
  210. Wanted: 10 bolt diff, prefer a locker, and a driveshaft
  211. WTB: power window switch
  212. WTB: hurst, B&M, OR pro 5.0 short throw shifter
  213. WANTED 6 Speed shift knob / shifter
  214. Center part of rear spoiler for 91 Convert Camaro
  215. WTB: Several small Items
  216. WTB: OEM CD Player
  217. WTB - Camaro non-power door internals
  218. wtb: mounted drag radials - maple grove area
  219. WTB 30# injectors ASAP.
  220. wtb: broken 93-94 opti
  221. B&M ripper
  222. ILE a/c delete pulley
  223. Need neutral interior pieces.....
  224. Does anyone have Jason Cromer's number???
  225. e-mail me alviebates@webtv.net
  226. SLP Air Intake
  227. Still Need a Z
  228. WTB: interior parts '97+ camaro
  229. FS: Genuine GM chromed 5-spoke (ZR1 style) rims with tires
  230. WTB 3" Intermediate pipe for cat-back
  231. Need GM Optispark 1104032
  232. Need Opti Sensor
  233. Trans Am cowl induction
  234. wtb: v6 fbody rear springs
  235. Racing Stripes
  236. Mac Y Pipe
  237. WTB: LS1 headlights in good condition
  238. Need Hooker LongTubes ASAP!
  239. WTB Trans am ram air box
  240. WTB....AC delete pulley/bracket
  241. 85-90 Camaro Nose/ 2nd gen t/a
  242. lt4 KM
  243. both front door speakers
  244. Cd cover area for LT1
  245. WTB-LT1 Engine&auto tranny in Canada
  246. i need hooker super comp LT (2210)
  247. OEM front tag cover in white
  248. WTB a turbo cam for LT1
  249. SLP Loudmouth Wanted!
  250. WTB:A4 radiator
