View Full Version : Parts Wanted
- WTB: 1LE or Trickflow intake elbow
- WTB throttle bodies, MAFs, and valve covers
- Looking for a pair of stock z28 rims/tires
- WTB: LT1 a/c compressor and passenger side mirror glass
- Mustang II Front end.
- front end,brackets
- Stock LT1 Pass. Exhaust Manifold
- center console needed
- Chrome C5 5 spoke wheel needed
- T56 wanted
- WTB Coil Pack Brackets
- WTB Chrome Wheels!! (C5, Z06, Boyd coddington blasters)
- WTB - 98-02 Camaro front fenders OEM only
- 9" or Stock 10 bolt
- Camaro Seats Wanted
- CAMS! Lets see what you got!
- 9" or 12 bolt
- Eibach Pro Kit for 93-02
- WTB: GMMG for LT1
- 98+ Camaro M6 Center console needed
- WTB 98-02 gray Trans Am door panels
- Cc503
- wtb. longtube headers and y-pipe
- Need 98-02 pass. visor w/ bracket blk.
- WTB Rear Side Markers for 93-97 Camaro
- WTB: 98-02 LS1 Clutch Pedal ASAP!
- 96TA foglight and radiator
- LF: 93-97 WS6 Hood
- WTB: Hooker Super comps for 3rd gen
- Knock Sensor
- firebird parts
- mirrow
- Trans
- need backseats for lt1
- 93 Camaro z28 Oil Dip Stick
- Need An Lt1
- WTB CC306 cam
- WTB Hurst Factory Shifter
- 1997 ss hood wanted
- oz racing monte carlo wheel
- futral F14
- Lt1 t56 clutch fork 93-97
- WTB SLP CME VALENCE (no aftermarket)
- Looking for 1.6rr's and long tube headers for LT1 used or new
- Crankshaft Damper
- 94-95 ECU and harness wanted
- WTB Walbro 255 Fuel Pump Plastic hose
- lt1 air box to maf bellow
- Skip Shift Parts Needed
- Ported heads in Illinois
- Stock working 24lb injector
- lexan/plastic hatch, cowl hood
- WTB autotap + 2 step
- Berger Panel
- Borla Muffler
- WTB black 93-97 camaro hood
- SS Camaro Spoiler
- WTB: 96-97 crank hub
- 5.0L H.O. passerger air intake snorkel
- gear shift boot
- Bell Housing
- Aftermarket Ford 9"
- 94-97 LT1 Throttle bracket
- radiator for 95 ta m6 asap
- WTB: 65lb high impedance injectors
- Richmond 3.73's
- Relucter ring!
- 1997 camaro rocker door panel/cover
- wtb: 93-97 rearview mirror lenses
- need 4 channel backing plates
- wtb alum. driveshaft
- WTB: LS1 coils(8)
- wtb: 1.6 SA rr, valve springs,locks and retainers,valve covers,clutch
- WTB: LS1 Front Brake Conversion, and a few misc things from anyone parting out an LT1
- Looking for a few LT1 things
- WTB: Throttle cable
- 94-95 z28 underhood harness...
- cage & matched injectors wanted
- WTB: Camaro L69 dual snorkel duct/snorkels
- Need metal fuel lines, throttle cable, and gas pedal
- Performance Maf
- Interior parts for a 95 Z28!!!
- Wanted
- [B]01-02 SS 10 spoke wheels[/B]
- JE Pistons 131636
- Interior Parts for 94 Camaro Z28
- Wanted Weld Aluma-star or magnums fronts
- Strano Springs
- WTB Escort 8500 X50
- Crane Gold Self-Aligning, Narrow Body Rocker Arm for Center Bolt Valve Cover, 3/8" st
- 6" door speaker brackets ta
- Power lock button
- Looking for fast xfi of accel gen7 dfi for lt1
- wtb hotcam kit without cam
- 3.73 ring and pinion
- WTB:Cruise Control Cable
- WTB or trade freshly built A4 for t56
- WS6 Hood - Trans Am 93-97
- LS1 98-02 rear e-brake bracket
- 98 up Firebird console lid
- Formula Rear Bumper (93-97)
- WTB LT1 Heads ASAFP!!!
- WTB 6 speed shift plate for center console
- Electric passanger side door in indiana?? also fender
- WTB: LS1 T56 transmission
- WTB Pacesetter headers LT1 long tubes
- WTB- Vortech brackets
- Wanted: Rear Z28 Emblem
- wtb ported lt1 aftermarket heads or really good stock
- Looking for Inner Wheel Well liner
- Chrome Firehawk wheels
- help me finish my camaros interior
- WTB: LT1 Clutch Stuff
- coilover front shocks with springs
- Lid
- Front Speakers, Monsoon System
- Body Control Module Needed
- centerbolt tall valve covers
- WTB: 275/60-15 Mickey Thompson ET Street Radial
- T56 mainshaft, 5/6 driven gear, or complete broken 94-97 T56
- Cc306
- WTB LT1 aluminum flywheel, lifters
- 4th Gen driver's side T-top!!
- WTB: Berger Panel
- Need Driveshaft
- 98 Camaro Front Bumper Cover
- wtb Driver side door 2000 camaro
- looking for used clutch disc
- WTB LT1 motor
- superchargers
- WTB: Fuel pump for 2000 3.8L Camaro
- Need stock intake elbow for 1994 formula lt1
- Wtb:drag Rims W/ Tires Or W/0 Tires
- WTB/NEED: LT1 Intake (ported)/58mm TB
- Need alternator plug with wires...lt1 motor
- WTB: Stall, misc....
- lookin for autometer shift light rpm pills
- good radiator for lt1 camaro
- Need 98-02 TA RIM!
- WTB: Short Stick, Shift Knob, LT4 Knock Module, maybe more stuff
- WTB LT1 Block!!
- Autometer dealers
- H-beam,Pistons
- (wanted) lower air box for a ls1 car
- 94 Camaro Tan Cloth Seat
- Need 93-97 LT1 Accessory Bracket
- 70 z28 gas pedal rod
- SS Camaro hood for 93 - 97 camaro
- How much is a ls1 block worth
- LT4 4 bolt main block
- WTB o2 sensors
- Anybody got a good set of 1.6 SA roller rockers for 93 Lt1
- stock motor mount brackets
- Looking for a set of 315/35/17 drag radials
- WTB: 94 Camaro Z28 engine wiring harness
- Opti bolt
- Steering Wheel w/Airbag
- 98 up firebird parts needed
- WTB: 93-97 camaro front bumper cover!!!!!!!!
- WTB: Lca's
- WTB stock flywheel, lt4 PP and other M6 swap parts
- gears
- SS hood
- Junk LT1 heads
- 1 Torq Thrust II
- Wtb Fuel Tank W/pump
- driver seat 97
- 95 Drivers seat, cloth graphite
- Struck out
- WTB - LT1 parts
- WTB: Harmonic Dampener Hub 95 LT1
- looking for new or used LT1 starter ASAP!
- Anyone have a passenger door available?
- WTB Front QA1 Single 12 way adjustable struts
- WTB Chrome/Polished Valve covers
- need 4 speed trans and 302 chevy motor
- LT1 to LS1 front end conversion parts
- Wanted:1994 z28 wiring harness
- wtb or trade for 350 lt1/ls1
- Looking for BAD 95 up opti
- parts for a 94 forumla opti,air bags,front and rear bumpers
- wtb rear seat deletes
- comp beehive springs
- need 3rd gen rear
- 96-97 camaro SS air box lid.
- 52 mm TB Preferably a Holley
- LT1 Radiator
- wtb older car magazines
- WTB: 1 7/8" LTs
- LT1 Maf
- 93' lt1 throttle body
- LS1 front spindles
- WTB: Wheels! z06, c5, tt2, anything!
- Bose Door Speakers
- Cold Air
- Looking for 99-up center bolt valve covers and seat belts...
- 1993-1996 Firebird 6 Speed Console Insert
- wtb Lt1 intake & heads (stock)
- camaro Motor Mount
- t56
- LT1 fuel rail covers
- WTB: STOCK LT1 intake, and other misc. parts
- 96 Z28 Hypertech Programmer
- I need an on car adjustable panhard bar w/polly ends
- Steering Knuckle
- line lock
- sir coil aka "clock spring" needed
- Msd 6al Plug In Harness
- Panhard Rod and Tranny Cooler
- Need (1) 30# SVO injector
- WTB- Procharger inlet housing
- WTD--> T56 Centerforce clutch etc.
- wtb lt1 air cleaner assembly
- Sportlines for 82-92 Camaro
- WTB: BFGoodrich COMP TA ZR Tire
- WTB: 96-97 WS6 Ram Air intake
- 4l60e parts
- cc 503 on 112 lobe sep
- headliner 4th gen with tops
- Factory Round Leather Shifter Knob
- WTB: 30lbs Ford Red Tops
- WTB: Stock rims for 4th gen Camaro (2000 V6)
- Need LOTS OF PARTS
- 10 Bolt
- Wtb: Nice Dipstick Tube And Dipstick!!!!
- Need 95-97 Vented Opti
- lt1 shortblock wtb
- Looking for 5 spoke chrome 16" Transam wheels
- WTB stock auburn posi 7.5
- fuel level sender
- WTB: LT1 Longtube or Midlength Headers + Off road ypipe
- [WTB]Black LS1 style SS spoiler
- WTB gmpp lt1 carb intake
- Wtb:low Coolant Sensor Thing!!!
- Wtb:throttle Cable Non-tcs!!!!
- OBD1 Data Cable
- MAC Off road y pipe for midlengths
- WTB: 94-95 LT1 Cat
- WTB - Pass side driving lamp lens
- WTB- LS1 ws6 door panels
- WTB: stock power distribution block
- 93-97 lti camaro stock roller camshaft
- NEED TB for 02-Z
- MAC midlenth headers + ORP
- 60# Injectors
- chrome plated 1997 camaro 16" wheel
- 17 inch tires
- ----stuff----
- Looking for 93 - 99 Steeringwheel Airbag
