View Full Version : Parts Wanted
- looking for a set of center caps off 97 z28
- keyless entry
- 245/50/16 tires in wisconsin
- pipe
- LT1 Flexplate Wanted
- Airbags needed for a 01 SS.
- cheap used 3:73 or 4:10 gears.
- hooker headers?
- WTB USB cable for 95 OBDII connector TunerCat
- Wtb: Egr
- 6 speed consol needed
- slp exhaust wanted
- BORLA CAT BACK w/DUAL TIPS for 00 WS6
- I need (2) 275/35 zr18 Eagle F1 GS D3's!
- wtb tunercat OBD II
- WTB: LS1 Bird Tail Lights & Door Panel Piece
- WTB LS steering shaft F-body
- WTB CAI for a 97 Z28
- WTB- Valve springs, stock heads/cam setup
- WTB: 4th Gen Camaro seat
- Lt1 ps resivor,coolant lines,heater hose
- WTB ProForm 1.6 3/8 self aligning Roller Rockers
- WTB ram air hood
- WTB: Rear 02 Simms
- WTB misc for my 95Z
- WTB Hi-po parts
- WTB: Vert Tonneau Cover and Chrome SS 10 spokes
- WTB: Rolling 93-02 Camaro Chassis!
- Looking for 99 ss air box
- WTB - Window Switch panels
- want - for 94 f-bod - PCM data log + tuning set up
- WTB: Some LS1 parts for the Patriot Dream 68 Camaro project
- WTB: Cheap Knock Module
- Wtb Mallory 685
- 97 trans am yoke
- WTB 210 or 200 cc lt1-4 heads
- Wtb 97 Lt1 Crank Hub
- Rear Finish Panel
- Drivers/Passenger Side window switches OR Metal Clips that hold the switch panel on
- slip yoke
- Tight or like new 95 steering column camaro
- WTB: t-top holders!!!
- WTB REAR DISK backing Plates
- looking for 93-97 trans am tail lights
- WTB Drag radials
- WTB '97 Passenger Airbag Cover
- WTB '97 Dash pad
- WTB Vortech 6.66" Crank Pulley
- Gasket Kit for 1994 LT1 Z28
- rear end
- 50 # injector
- WTB-Delco/Bose CD HU for a 96 Z
- cheap exhaust
- T-Top Shades
- Sell Me Your Longtubes!!
- Wanted coated Pacesetter Longtube headers for a 93 Z28
- WTB Throttle Cable
- WTB AFR heads
- WTB Front Shocks & Spring
- Procharger/vortech
- TT II's
- looking for a small block
- ntb passenger t top for 93-02 camaro
- WTB: REAR EradiSpeed Rotors For '98-'02 F-Body
- WTB: ATI Balancer and 60# High Impedance Injectors
- 58MM Throttle Body, Performance MAF, and CAI System
- Need stock MAF
- Need A Couple Of Dash Pieces Please Help !!!!
- WTB: used performance suspension parts
- Needed some LT1 parts
- WTB a set of rims and tires for my 97 Z
- WTB: 2 bolt main LT1 block in the NY area
- WTB: Manual window motor and handles
- WTB: nonvented opti...
- WTB: 3.4 for my 95, engine only
- 4th gen rear seats and belts
- Looking for some 96 LT1 parts
- WTB: SBC/LT1 Turbo/Blower Pistons
- t/b and u/d pullie lt1 bolt ons
- *wtb- Lt1 Powerdyne Supercharger
- 93-97
- 94 code scanner for an LT1
- x Weld prostar wheels
- Wanted: #74 Terminal For Door Lamp Illumination
- Need junk 94= lt1 feul rails
- WTB interior parts (both T/A and Camaro)
- Super Victor Intake 2925
- Wtb: Pcm
- need some parts
- Need gas tank
- 1.6 3/8 NSA CC pro mag RR's wanted!
- WS6 wheels
- Torq Thrust II
- WTB Reverse Coolant Lines LT1
- T56 Transmission LT1
- WTB Window lift motor ASAP!!!!
- cold air intake
- WTB : 98+ Center Console Support Brace
- Block and/or heads - Ohio
- lt1 block and heads
- oz racing monte carlo wheel 17x9.5 chrome
- Wtb Obd1 Pcm
- WTB o2 sensors & extention
- LT1 short block in CT area
- wtb: 98+ camaro headlights
- set of heads
- WTB: nitrous accesories-heater, guage, purge, etc.
- WTB OBD II Computer for M6
- WTB: 17" drag radials
- Need fuel pump for a 93 Z28 ASAP
- Complete LS1/LS2 or LS6
- pass side fenders
- Looking for a hood for 98-02 Camaro - SS or Ultra Z preferred
- '94 Z-28 Remote Keyless Entry Fob
- 3200-3600 stall
- WTB: MAF translator or OBD II edit
- Need a red 93-97 driver's side fender
- 95 timing cover needed
- 93 AC control knobs. charcoal/black cloth seat
- WTB: Interior Peices for '94 Z
- Looking for crappy looking knockoff ZR1 wheels
- WTB: T56/M6 Trans Crossmember
- Dash Pad
- SS Style hood needed! Cash or Trades.
- Front Bumper
- WTB-'94 to '97 LT1 Z28 cam
- 96-97 WS6 Wheels (maybe 96-99 im not sure)
- Looking for stock 3 series carrier for 97 Camaro
- forged crank
- 18" of 3" exhaust pipe to make a "test pipe"
- looking for a 3 series carrier gm 7.5
- Wtb: 94 Obdi A4 Pcm
- Looking for stealthbox or ttop sub enclosure (or dimensions to build)for 98-02 camaro
- Non-vented opti harness
- All Parts for T56 Swap
- Driver side manual seat track 93-02
- Need a bunch of stuff!!!
- 1997 camaro z28 gauge cluster
- WTB: set of 4 Z06 18x10.5 rear wheels
- Flexplate
- slp or borla catback for 97 ws6 dual cats
- Wtb Camaro 93-96 Bose Speakers
- Turbo or SC
- Need a couple of Dash parts !!!!
- I NEED Lt1 Coil jumper wire !!and a few other things
- WTB rear C A M A R O panel (Berger)
- WTB: SLP 2OTL, catback or complete tail section...
- I want to buy two black doors for my 94 camaro
- WTB=Delteq system for my 94 with radiator mount
- wanted a 1998 up ss Spoiler
- trans am hatch and non-vented opti
- JL 10" sub
- I need a 1998 + monsoon radio
- WTB: 4th gen Berger Panel + 93-97 Camaro Car cover.
- Data Cable for 95 F-Body..
- WTB-brand new 3.48 gm crank
- Need lock for glovebox
- wtb tunner cats
- WTB: Oil Pan for 98 Z28
- Wanted - OBDI LT1 PCM 1994-1995
- QTP E-Cutout
- Data/Tuning Cable
- Subframe connectors
- Complete rearend with 342's
- WTB LT1 Flywheel
- 97-99 charcoal Trans Am door panels
- brake and clutch pedal setup for t5
- Wtb: Cc306
- 94-95 Complete Running LT1
- WANTED: Valve Covers for 1.6 RR
- WTB Drivers Windshield Wiper Arm Cover
- Need 95 opti harness & plug/connector 4 coil&module
- LTB 6-Speed Parts/Conversion, ALSO FRONT LTHR T/A SEATS!
- WTB: Aluminum Rad to fit 96 SS M6
- WTB: 93-95 Camaro tail lights
- 4th gen seats
- Weld prostars or draglites
- LT1 Dipstick tube!
- 99 Camaro SS Dash Plaque
- WTB (2) 4TH GEN hood strut
- lt1 block and more
- Seat upholstery
- subthump box w/ decent sub
- WTB: 1 taylor 8mm lt1 wire
- WTB: Camaro 98-02 Hood
- Need a 95 up vented optispark or optical sensor
- Looking for headers with ORY 95 Z28
- WTB: LT1 master brake cylinder!
- 4th gen front sway bar
- wtb: trans am seats
- Need black rear seat belts
- WTB: 94 4L60E Tailshaft/VSS
- WTB 1.6 Roller Rockers
- WTB: P&P LS1 Heads Assembled
- WTB LT1 Block
- Aftermarket torque arm.
- SLP 96-97 V6 Ram Air
- WTB: used LT-1 heads / intake manifold
- waterpump needed in dfw area
- looking for SS hood need it ASAP
- LT1 Oil Pan needed
- WTB: 93-97 Camaro Cowl Hood
- i need a cheap laptop
- Need a LT1 starter?
- Wanna Be LOUD!?
- !!!!!!!oil pressure sending sensor!!!!!!!
- desperate need of a t56
- LT1 caprice a/c lines
- Looking for engine wiring harness for 95-97 LT1
- 93-96 Camaro dash pad
- I need a pair of 245 50 16 tires
- Im looking for a set of black doors
- WTB: 93-97 Ultra Z hood
- WTB: Ebony Leather 98-02 T/A seats
- WTB 95-97 Opti
- Buying Factory Catalytic Converters - Any Type
- 97 Z28 Inst.cluster
- Need a few Lt1 parts
- WTB LS1 engine wiring harness
- WTB: hood for a 93 camaro
- Chrome lug nuts
- 94 Power door lock mechanisms
- WTB : Hooker Aerochamber
- WTB 93 throttlebody
- racetronix injectors
- chrome WS6 17" rims
- 93-97 Xenon Front GFX
- WTB: 93-97 VFN Sunoco Hood
- wtb vortec inter cooler
- WTB: T56 console insert
- 1993 Lt1 Ecm
- Looking for new wheels for 99 TA
- heater core
- 95 Camaro Z28 Black plastic Radio Surround
- NEED: Stock axles for Stock F body rear
- WTT silver ZR1s for Firebird/TA stockers
- wtb:: Stock volume melling pump for lt1
- Parts Wanted
- Stock Hurst Shifter
- wtb crane 10308 lt1 spring kit, or drop in lt1 springs
- lt1 ram air hood
- Rear end or limited slip differential for 98 a4 ls1.
- LS1 Brake Conversion & Rearend Girdle
- WTB. SS or Firehawk Springs
- lt1 LT headers.
- ignition coil wire..
- Need some body parts 95 Z28
- ls1 style 4l60e
- Unvented Style Opti
- clutch master cylinder?
