View Full Version : Parts Wanted
- Need OBD2 Computer
- WTB: Firebird/Formula/TA headrests
- WTB: HOT cam kit, Pro 5.0
- supercharger
- WTB: Lt1 fuel sender (no pump needed)
- WTB rear blackouts for a 93-02 Transam
- F/S camaro 411 gears
- Need Obd2 M-6
- WTB: GM LT1 Timing Chain Kit
- Ds Door Panel 94 Firebird
- WTB: LT1 intake elbow
- WTB overflow tank for 95 formula
- WTB - 30# or 36# injectors
- WTB LT1 oil pan
- WTB: 3000+ torque converter
- stall/Supercharger
- WTT: 18" Budnick Trilogy 3
- Wanted Screws for Ground Effects (all)
- wtb: 15 x7 chevy truck rims
- t56
- Firebird 3rd gen rear bumper cover
- wtb: 50lb MSD injectors
- WTB Short Shifter
- First Gen Convertible Top Frame
- WTB: 95 z28 fuel rails
- wtb laptop cables/program
- ss rims
- axle shaft from 93-97
- Need poly locks for Roller Rockers 3/8ths Stud!!
- WTB: Moser 12 bolt
- WTB: LT1 Air Foil
- Looking For One 17 ' inch impala SS rim
- Wtb Z28
- 4 Torque Thrust IIs 17x9"
- Wtb Muffler Borla ,hooker ++++
- WTB .. aftermarket tail lights for LED conversion
- Looking for Caliper Brackets for LS1 Front Calipers
- Fast Sequential with wide band
- T56 Bellhousing
- TH400 parts needed....
- WTB torque thrust II's 17"
- Side skirts
- WTB: LT1 Engine Complete
- Obd2 For Sale ??
- In need of a 10-bolt with 3.42 and LSD
- WTB: 3rg gen Camaro ASAP around $3K
- WTB: Mufflex or Chambered Cat-Back
- wet kit needed, reasonable price
- WTB camaro ecm for a 95 3.4L m5
- 98+ firebird/ta parts
- 4thgen in dc area
- 1970-1973 Quarter Panels
- WTB : Stock Heads
- LCA's
- WTB: Sway Bars and Wonder Bar
- SFC's
- need door hinge bolt set
- WTB: Trans Am
- NEED : rear brake line 85 T/A
- Chrome 16" TA wheels
- I need a rim......
- WTB 93-97 fuel tank.
- LT1 Intake
- WTB: Factory Hurst T56 Shifter
- Air lids or catback
- Pro Stars, center console
- WTB Drag wheels/tires, LT1 ported heads, LT1 RR's, etc.
- 17" ZR1's with Tires
- 10 bolt/ 3:73 or 4:10 for an LT-1 in CALI
- WTB: 1.6 roller rockers for LT1
- IAC valve
- LS1 Center Bolt Valve Covers
- Coil overs fo the front of a 3rd gen
- Tubular K Member
- GMMG Exhaust???
- WTB 1989 20th Anniversary Turbo TA
- WTB - LT1/Tranny or wrecked car S. Ohio or close
- WTB Sunfire Yellow T/A or Formula
- 2800+ stall converter
- WTB cd player
- WTB TNT or NX N2O Kit
- WTB: hypertech powerchip for a 93 A4
- WTB: 93-97 Z28 or SS
- Blown Opti
- WTB: ThirdGen Project IROC, 91-92 Z28, birds
- Parting Out 1991 Camaro RS
- WTB: EGR tube from LT1
- WTB Mufflex Y
- WTB: Carpet 4th Gen
- Stealthram, 58MM TB, 30+ # Injectors
- Wanted to buy or trade, 3/4" Stage 8 header bolt
- *NEED* RS Side and FronBumper & SS Hood all for 98 /\
- Need LS1 power steering pump
- WTB-stock LS1 main caps
- needed 2002 front/rear blackouts and 94 front blackouts
- WTB LT4 intake
- 95 firebird Tunnel Brace needed
- WTB: Electric cutout
- WTB 58MM Throttle body .....or 52 for less
- BTW T-5 bellhousing, and flywheel
- WTB Moroso Spiral Flows
- anybody need a car?????
- stock LS1 TB w/ sensors
- WTB - AKM Cable
- WTB - 6- speed Short throw shifter
- Y-pipe Wanted
- wtb 2 bfg drag radial 255 50 16
- Stock LT1 Camaro Hood
- lt1 ram air box
- anyone WTT wet kit for dry?
- wtb cheap aftermarket muffler
- 85-90 z25 body parts / vert parts
- WTB SLP COLD AIR and Trick Flow intake Elbow
- WTB- WS6 LT1 Intake (Airbox)! Asap$
- Help! Urgently need 22LB injectors for a 93 LT!
- LT1 Heads
- WTB: Wet N2O kit....
- need o2 senor for 97 lt1
- shortblock
- kick panel's
- Wanted Chrome Rims For 87 Chevy Truck
- Looking for stock parts
- WTB: 96-98 z28 M6
- WTB: stock cat
- WTB: 1LE ELbow
- ĦĦĦĦĦheadliner Needed!!!!!
- WTB: Ebony Seat Belts - Full Set
- WTB PERformance Parts 94 z28 CAI
- Wanted turn signal sucket for 97Z28
- Need a dash for my 97 z (just the part that has the windshield vents)
- 98+ LED 3rd Brakelight
- need stall 2600-3200
- 1le elbow and air foil, and a clutch
- WTB: Rear panal Subwoofer.
- 97+ Firebird non-A/C V6 HVAC (heater) control panel
- WTB: Longtubes
- WTB ARP head bolts or studs
- 3rd Gen Rear Bumper wanted
- Wanted: Driver Side Tail Light Cover...Smoke, '93-'97 Camaro
- 95 opti wanted
- Wanted: stock exhaust hangers!
- Wanted! QA1 front shocks and Electric cutout plate!
- ground effects 2002 SS
- wanted: 94-96 T/A covnertible or T-top car
- posi rear
- stock corvette torque covertor
- Tan Interior Panel
- Hood Stops
- ISO 93-97 Lt1 fuel sender
- hood struts
- WTB: Transmission brackets
- WTB V6 Fuel Pump Assemb.
- 16" Drag Radials
- WTB: Catback
- looking for 2 16" rims
- WTB '93-'97 Camaro
- Hood Thingies...
- wtb shiftboot and plastic around it for 95 M5
- WTB: LT1 Block near Florida
- Wtb. Gm Obd-1 Scan Tool.
- WTB: SLP CAI, and 2800+ stall converter
- WTB: FUel rails for 95 z28
- slp lid needed for 98 camaro ss :)
- Need stock LT1 Injectors
- t56 conversion
- WTB: MSD wires
- Tail Light Needed Asap
- Wtb 93-97 Dr Manual Mirror
- accel 375 plus unit
- WTB zr1 wheels
- 44 1/2" Driveshaft
- need (8) 1.5 or 1.52 roller rockers
- Need dash Board!
- WTB: Mufflex or GMMG exhaust
- DS 4th gen camaro door
- stock 4th gen (camaro) exhaust tips
- Need shifter boot for '95 Trans Am/Firebird
- Need some parts
- WTB: 9" Rear...Partial or complete
- WTB: stock MAF
- need stock springs/shocks
- WTB: Front and Rear blackout covers
- WTB SLP cold air induction
- might need LT1 computer
- WTB: Drag radials
- aftermarket 93-97 Z28 hood
- Stock Chrome Rims Or Even Aftermarket!!
- need ONE stock casting LT1 head bare
- WTB: Fuel Pressure Guage/Setup
- wtb cheap 94 up lt1 intake manifold
- Need poly locks for GMPP 1.6RR!!!
- WTB: 4l60e Transmission
- WTD: LT1 AFPR and FP Gauge
- WTB: Bellhousing
- WTB: Chrome ZR1's for 94Z
- Trade 3rd gen for 4th.
- WTB...extended length plug wires...
- 700-r4
- LT1 aluminum intake elbow
- IN NEED of an older laptop with 9 pin serial port! ASAP
- Last chance to sell your Vortech
- WTB: M6 console plate, stock M6 flywheel, and M6 pedals
- Need Engine
- want wheels or performance parts
- Wtb Headers Asap
- Supercharger for sale?
- WANTED! VSS sensor [M6]
- LCA Relocation Brackets
- WTB Throtle body
- anyone selling a radar detector ?
- WTB, AAM aluminum diff cover from an ss car,
- ISO: 93' harness
- Looking for 02 Z28
- WTB: New Optispark and Meziere Heavy duty Pump
- 1972-1979 Vette chassis motor mounts
- z28
- 98-02 Brakes
- Shortblock
- LS1 Thunder Racing cam
- Need: 3 Inch Y pipe for Long tubes
- ATTN people parting '98+ cars
- WTB induction tube from 90-92 Z28.
- WTB passenger door and fender for a 99 TA.
- WTB: 98+ Firebird/Trans Am speedo bezel
- WTB: 98+ Camaro Bra.
- WTB: Wrecked or Damaged LT1 car
- WTB: Neutral/black Interior pieces.....And other stuff
- WTB--Coolant crossover tube
- WTB: Camaro Iroc-Z
- new an LT1 throttle body
- trunk harness
- WTB: Trans-Go,Tranny Cooler,and Intake Elbow
- Front bumper cover
- WTB: 93-02 Stealth Box
- shorty headers
- WTB V6 front springs
- Wtb:exhaust Cutout Cap
- WTB-Smoke Tinted Headlight Covers-94
- E4 Torx Socket
- ISO: Rims
- WTB: single cat exhaust - stock or aftermarket
- WTB: LT1 Harmonic Balancer
- WTB or Trade my OBD2 PCM for OBD1
- Want to trade my 18&20's for Chrome y2k or z06 wheels in 18"
- WTB Skinnies
- Posi Trac Unit
- Need a Horn
- WTB Opti spark wiring harness
- WTB: Beginner Motorcylce--Ninja 500, Dual Sport, etc
