PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. lt-1 loudmouth
  2. WTB: Factory BOSE cd player
  3. WTB: stock NBM Firebird hood
  4. All Parts Wanted For 94 Camaro Z28 High Performance
  5. WTB TA or firebird door panel parts.
  6. WTB: Camaro Gas Door (Black)
  7. Need some stuff.......
  8. Wtb:cc306
  9. need a used 3rd or fourth gen....cheap!!!!!
  10. want to BUY LT4 valve springs
  11. WTB: Vortec/TrickFlow Alum. Elbow
  12. Need to buy...one LS1 rear caliper
  13. Wtb:passenger Side Ttop
  14. slp loudmout up for trade for quiet exhuast
  15. Need Trans Am rocker ground effects
  16. wanting to trade a 1988 S15Jimmy with airbags & a small block for a camaro (Arkansas)
  17. Need M6 crossmember, opti harness and vacuum harness for opti conversion
  18. WTB: LT1 valvesprings that fit stock seats...
  19. Want to buy: 3rd gen Camaro Z28 grill
  20. Need stock hood 93-97 white would be sweet?
  21. I need interior pieces...
  22. Corvette 2000 or later 5 spoke chrome rims
  23. Cheap rims
  24. Wtb: O2 Sims
  25. HD TA, HD ADJ LCA's, HD ADJ PHB, Mufflex y-pipe, 7/16" RR's
  26. Wires and computer to calibrate ECM
  27. Wanted Looking For Ground Effects/ss Spoiler 93-97 Camaro
  28. I need a HIGH MILEAGE ODOMETER I can trade ya.
  29. Ls1 Stroker
  30. I'm looking for some L98's
  31. WTB: 2800 or 3K stall Converter
  32. WTB 26X10X15 Slicks
  33. WTB Camaro to drop engine into
  34. sticker
  35. Injectors needed
  36. I need body parts!
  37. WTB Fuel pump,Brakes,Shocks etc.
  38. wtb Headlight motor & module
  39. WTB: Opti for 94LT1
  40. WANTED: 1969 camaro project
  41. nitrous kit
  42. Need parts for s-trim
  43. WTB: LT1 Lifters and push rods, LT4 valve covers
  44. WTB ASAP: Stock wheels and tires...
  45. WTB-drar rims with M/T ET Streets...
  46. Wheel spacers for 3rd-4th gen wheel conversion
  47. Parts for SD swap neede
  48. WTB low milage factory hurst shifter.
  49. Need Ls-1 Throttle Body
  50. need lt1
  51. LT-4 valves
  52. i need lowering springs got any?
  53. i need only 1
  54. NEED!, Custom brackets for racing seats in a Camaro
  55. looking for low mileage 24lbs injectors
  56. Wtb Madman manual rack for a 1993-1997
  57. wtb: cloyes double roller
  58. WTB: 96 or compatible LT1 engine harness
  59. wtb:LT1 dipstick tube
  60. wtb headers for 97 LT1 camaro
  61. WTB Stock Valves
  62. WTB: AKMCABLE for 94 LT1 for use with datamaster
  63. Need drivers side window switch
  64. WTB: 2 Stock 16x8 Wheels
  65. Wtb Cc306
  66. WTB:LT4 hotcam, waterpump, egr, opti, MAF
  67. WTB: electric waterpump for LT1 ASAP!
  68. Need A/C compressor clutch
  69. WTB: LS1 with T56 or whole parts car….
  70. WTB two nitrous wet nozzles
  71. wtb:: Hooker muffler 3in and Dual 2.5 out!!!
  72. Wtb: Stock Camaro Spoiler!
  73. WTB: Front and Rear Springs
  74. wtb: TIPS
  75. shift boot retainer ring for LT-1 M6 console
  76. WTB: LT1 Harwood Cowl hood
  77. wtb headers
  78. Looking for parts for Dual Snorkel Air Cleaner..
  79. WTB: 97 Z28 bezel and cluster
  80. WTB - Complete Rear End - Posi 3.42 - 93-97
  81. WTB: 3rd Gen Camaro Steering Wheel and/or Airbag
  82. I Need A Cc306 Or Similar Cam!!!
  83. WTB tires 275/45/17
  84. Beware of KatFish Racing
  85. Looking for a mild cam,Z06 preferably
  86. WTB: Fuel pump bucket (or cheap used fuel pump)
  87. WTB: Full charcoal interior from a Formula/TA for 98+
  88. WTB: All interior plastics for Camaro
  89. Need 93-96 TA A/4 console
  90. Wtb:gm847
  91. wtb: short nitrous line
  92. wtb: nitrous bottle bracket
  93. LS1 Bolt-Ons.....
  94. WTB: Cowl Induction Hood
  95. wtb- LT1 STALL CONVERTER!
  96. 2" wheel spacers
  97. lt1 wet kit
  98. WTB: timing set, electric waterpump and 7/16" studs
  99. WTB: AfterMarket hood For 93-97 CAMARO
  100. WTB: LT-1 Block in florida
  101. Looking for a Crane 227
  102. Need A Y-pipe!!
  103. Borla Exaust
  104. WTB: Front shock dustcover
  105. WTB--Gray Shifter boot for 6-Speed
  106. WTB: 4th gen rolling chassis
  107. Steel lt1 drive shaft
  108. WTB 4th Generation Suspension/Chasis Parts
  109. Looking for Red Drivers Side Door for 93 Camaro.
  110. WTB - stock rear housing
  111. Wtb 98+ V6
  112. Need 4bolt block and 95 6speed PCM
  113. LT4 knock module
  114. wtb: cutout, aftrmrkt shifter, lower springs, ls1 tail lights, lt1 fog lights..
  115. WTB 93-97 dashpad
  116. WTB stock Cd head unit
  117. WTB Borla tips
  118. 1.6 Roller rockers 3/8 stud
  119. WTB: Muffler
  120. 1993-1995 Front Bumper Cover (silver)
  121. WTB: LT-4 Hot cam kit
  122. WTB shifter knob
  123. Wanted: Cut-out
  124. wtb short throw t5 shifter
  125. WTB: scat or eagle crank.
  126. WTB: Eibach Pro-Kit
  127. I'm looking for the following for my 93 z28
  128. Wanted: 98-02 Camaro Z28 Rims
  129. MAC Offroad Pipe
  130. WTB: 3rd Gen 16x8 Rear Wheels
  131. WTB: Aftermarket Hood for 94 Firebird
  132. WTB: Chrome 17x9.5" ZR1 wheel(s)
  133. wtb: B&M Ripper, pro5.0, or Hurst Comp....
  134. I need a 94-96 Z28 center console!
  135. Black plastic lug nut cover
  136. WTB FAST 90mm intake & TB
  137. Wtb: Slp 2otl
  138. WTB Pillar Gauge Pod
  139. WTB LS1 axles
  140. WTB 700 & 4L60E cores
  141. WTB stock rear coil springs
  142. Rear Lower Control arms
  143. WANTED: Good used 88-93 700R4 Trans
  144. Exhaust Tips
  145. WTB: 99 and up fuel tank
  146. WTB: Injectors .. 42#
  147. LT1 rear calipers
  148. Will trade brand new z06 rims/tires for...
  149. SLP Loudmouth
  150. 94-97 intake manifold
  151. Need 3inch Y pipe for Longtubes,Lt1
  152. wanted 93-97 camaro ground effects west wings
  153. Wanted 93-97 Ss Spoiler For My Z
  154. Need cam, water pump, and oil pan
  155. Brand New HotCam, still in ACDelco box, trade for bigger cam (ie cc306, gm847)
  156. Hypertech programmer
  157. WTB: Rear Calipers (LT1)
  158. Looking for First Gen
  159. 26x10x15 Slicks (not DOT quicktimes or ET streets)
  160. WTB: 94-95 MAC Headers w y-pipe.
  161. WTB Chevy 302 block
  162. Looking for a CAI
  163. WTB: Flowmaster for 94Z
  164. WTB- 30+lbs injectors for LT1
  165. WTB: Taylor OTVC Set and Fire Sleeves
  166. Connection from Laptop to Car
  167. WTB: LS1 complete interior minus seats
  168. WTB: Master Cylinder U-Bolt.....
  169. WTB: LT1 Rear Brakes
  170. WTB: 3rd gen beater
  171. WTB:Hatch Area 98-02 Ebony Speaker Grilles
  172. WTB: Cadillac Northstar ignition module and coilpacks
  173. 2300-2600 torque converter
  174. i need a 58mm throttlebody
  175. WTB throttle body air foil lt1
  176. Headlights
  177. wtb: front shock
  178. need cat for a 94 z28
  179. NEED Stock Cat for a 2k1
  180. WTT: DMH for 3" Alum Driveshaft...pls cash
  181. WTB: BOSE front door spkrs..
  182. Wtb:ati D-1sc For Ls1
  183. WTB: Scat Crank
  184. WTB B/W 9 bolt rear end for third gen
  185. Looking for pass. window regulator and glass for 95 Z28
  186. WTB: decent 10" sub
  187. Driverside Power Lock Accuator
  188. WTB CAI on 94 z
  189. SS 98 + wanted
  190. need T-5 Borg warner 5spd Transmission
  191. WTB 3.42 w/ carrier
  192. y pipe for lt1 long tubes
  193. Tires for 17" zr1s
  194. Looking for a cam
  195. WANTED USED TIRES TO FIT STOCK 16" Z28 RIMS. NEED ASAP
  196. front clip or parts wanted
  197. wtb: CUTOUT, zr1's, shifter, tips
  198. wtb: misc. small stock parts
  199. ATI Intercooler for an LT1
  200. OEM SS spoiler
  201. WTB: 3rd gen camaro
  202. WTB: Stock 4thgen rear-end (local)
  203. Wtb- Pcm 1998
  204. Want a Good cond Z28 Lt1 in Bay Area
  205. Looking for stock 93-97 rs side skirts
  206. AFR Hydra Rev Kit for 95 Lt1
  207. drivers Window switch
  208. need 02 ws6 wheel only one
  209. need tubular k-member for a 95 Formula(only in Houston Area)
  210. 96-97 Engine harness
  211. WTB: O2 extensions for '95 Z28
  212. wanted : aluminumn drivehsft for 98-up camaro
  213. Texas Speed LS1 Lid
  214. WTB: Brake hardlines that go on K-member from master cylinder (lost mine)
  215. WTT: 1998 4L60E w/4400 vig,Deep pan,cooler,Complete auto setup
  216. wtb: 1.6 roller rockers
  217. WTB: Wrecked/Damaged LT1/LS1 F or Y cars
  218. 3.5" Alum. Driveshaft
  219. WTB - 1993 6 speed
  220. I need injectors for a Lt1..
  221. ElmScan Tool
  222. Need driveshaft ASAP! For Camaro 98 SS Hopefully in Houston area!
  223. I Want to Trade my Wrangler for your Z28
  224. wanted 93-97 rolling chassis
  225. WTB: Front Bumper Cover (93-97 Camaro Black)
  226. looking for a pro 5.0 stick only
  227. NEED a non vented opti
  228. WTT: My K&N CAI for a SLP CAI...
  229. wheels(ws6 or 95 firehawk)
  230. Help need a motor
  231. 3" cat weld or bolt-on
  232. Lowering Springs Needed Badly
  233. Adjustable Panhard rod
  234. Oil dipstick
  235. For those parting out 96-97 LT1
  236. 93-97 Z28 Front bumper and FL corner panel and...
  237. Need 93-97 TA front bumper
  238. WTB: set of Forged Pistons .30 for LT1
  239. WTB: ABS wheel sensor
  240. ***WTB 98-02 Trans Am ram air hood***
  241. NEW and USED CARS/TRUCKS FROM $100!!
  242. WTB: Stock CD Player
  243. WTB: Fog Lights
  244. WTB: Trans-Am emblems
  245. WTB: Flat 4-pin O2 Sensor Extensions
  246. 3" single cat cat-back exhaust
  247. smoked passenger side turn signal cover
  248. smoke fog light covers
  249. WTB GM 1.6 LT4 rockers ONLY NEED 2
  250. WTB: Maroon LS1 TA WS6
