View Full Version : Parts Wanted
- Sway bar kit...35mm/25 or 21 mm
- Need a driver's side mirror, black, non-power
- WTB: 98+ Firebird headlight COVER
- Need a clutch..reasonable
- 2 17x11 Chrome ZR1's
- need used/cheap 22 lb injectors
- Needed: 96/97 Slp Ss Hood. $$in Hand
- lt4 km
- ovtc wire kit
- 93-96 dash pad
- stall speed wanted
- ***WtB hood***
- LT4 intake
- Flywheel cover / shield
- 96-97 Rear SS Spoiler
- Camaro Driver Side Door
- Stock Throttle Body
- 96-97 camaro SS factory intake
- LT1 T-56 Entire Assembley needed
- msd plug wire... asap
- lt1 gaskets (all) and 1.6 pro mags 7/16 studs NSA
- WTB now, cut out
- Comp Cam 503 (XE 224/230)
- Drivers Side window needed!!
- WTB 2 Potenza RE910 235/55R16
- LT1 block
- Rims and Tires
- LT4 Knock Module
- NEED NOW: '95 Z dash board
- wtb bov
- a4-m6 parts
- WTB: Rear blackouts and clear corners
- Lt1 Motor
- WTB - Chrome or painted 10 Spoke SS rims
- WTB or WTT, for a 93 Z throttle body
- Need 94-97 Z28 hood
- WTB LS1 intakes
- 52 mm throttlebody--blades
- head light motor
- WTB: M6 torque arm mount
- WTB: LT1 Granatelli MAF sensor.
- WTB : Speedo/Odo calibration unit for 93 LT1
- Comp Pro Mag 1.6 NSA RR's
- Need 1980 camaro seats
- WTB: Rear rotors
- WTB: Light grey sunvisors for 93-97
- ls1 performance
- NEEDED: grey carpet and full console for a 94 Z28
- t56 vss harness (speed sensor harness)
- Alternator support LT1
- 93-96 slanted double 5 spoke wheel
- Electric cutout
- Aftermarket 94 camaro z28 underdrive pulley
- 94 z28 body extension, billet stuff, rear end gears, aluminium billet door, lower kit
- sub frame connectors,shocks , struts 99 ls1
- custom true dual exhaust
- ss spoiler
- LT4 Valve Covers
- Wtb: Icm
- SuperCharger for 1999 Ls1 3.8L v6.
- Looking for 98+ driver side tail light
- WTB: Aftermarket Shocks
- WTB: "S" pipe
- WTT or WTB 97+ painted 6 spd console insert for a graphite insert.
- wtb.. good 3,000 or higher stall, 1.6rr's nsa and great cam..
- WTB: 93-97 Foglights
- WTB: 93-97 Center Console
- need 98-02 firebird/TA front support bar!!!!!!
- WTB: OEM 93-97 Camaro Front AND Rear Bumper Cover
- K&N filter RF-1015
- WTB: T56 conversion for 94 LT1
- LT1 Cam
- 83# Low Impedence Injectors
- wtb lt1 non traction controlled throttle cable
- Slave Cylinder Spacer For LT1 T56
- WTB: 17" SS or WS6 wheels x2
- WTB:lt1 Flexplate
- WTB LT1 valve covers
- WTB Oil filter adapter
- WTB 97 camaro ss hood and spoiler
- Vortec Gaskets!!
- Hooker Driver Side Slip On Tube
- 93-97 red bumper cover
- WTD: new rag joint illiminator...
- WTB: Passenger side fog light
- K&N RF-1015 Filter Wanted
- WTB: Timing cover for vented opti ('95-'97)
- WTB SLP Dual/dual rear section
- WTB: (2) 17" and (2) 18" tires in good shape
- anyone have any chrome salad shooter wheels they wanna sell in good shape?
- WTB: looking for slp eibach springs
- Need 95-up Timing Cover
- oem front bumper cover
- CAI for 96 z28
- WTB Broken Comp R's!
- WTB Fog light(s) for my 3rd gen
- plasma cutter for trade for t56 complete conversion
- wtb alternator 95 lt1 140 or 200
- WTB Passenger widown switch and rear interior screws
- wanted lt-4 intake
- WTB: 93-97 Trans Am/Formula Tail lights
- 93-97 camaro foglight
- Need 94 Z28 parts hood, headlight assem, marker lights
- wtb master clutch and secondary cylinder
- WTB: '00 V6 Camaro misc. parts
- wtb fiel rail covers
- Center console - Whole or parts, I need it all
- parts
- wtb Performance parts!!!
- M6 Clutch pedal Assembly w/ master cylinder WANTED!
- Wanted-RPM Air Gap
- Perfect condition charcoal grey leather parking brake handle
- long tubes, y pipe
- Lt1 Maf
- Wanted Lt1 Performance Parts
- Wanted 3rd gen chin spoiler
- Need gage cluster for 95 Formula/TA
- Shifter Cable and Torque Arm mount
- wtb.. good 3,000 stall for LT1, sfc's and LCA's
- WTB 85 TPI Performance Chip + 52mm TB
- LT1 exhaust manifold
- 98 Camaro Repair Manual
- Morel Lifters
- WTB LT1 oilpan and timing cover bolts
- 10 spoke ss wheels in chrome
- a few 98+ firebird parts needed!!!!
- wtb used pace setter lt for lt1.
- Need An Lt1, Now
- L98 083 Heads Wanted
- gm847
- clear turn signals
- WTB: 91/92 trans am tail lights
- Wanted Gas Tank!!!
- Wanted: Passenger and Driver Side Switch Bezel
- Wanted: Passenger and Driver Side Sun Visors
- Wanted Fan knob for 93z28
- Stock LT1 shortblock WTB!!
- N2O Purge Kit
- Black Leather Seats for 96 z28
- wtb Ported heads and maybe cam
- 58mm Tb
- manual fan switch
- rims
- WTB: '95 Trans Am Oil Pan
- Need Trans Am pieces
- WTB: HAL Rear Shocks
- Wanted 1998to 2002 camaro gm used parts
- WTB:Motor Mount Clam Shells
- WTB: Rear interior panel for 95Z
- need dash pieces for 78' Z28 camaro
- WTB: Electric 2 1/16" Ultra-Lite Fuel Pressure
- Wtb: Front Drag Skinnies
- wtb: msd dis-4
- Lt1 Pass steering knuckle
- Seatbelt loops
- Lt1 dark grey M6 leather shifter cover and shifter knob
- WTB: Drivers Side Door/Rear Quarter (95Z)
- WTB headers for a 93-97 camaro
- hatch pulldown motor and rear seat.
- LS6 intake manifold
- Slp SS center mount valence
- Rear 3 channel ABS harness and sensor
- 2800-3200rpm Torque Converter
- WTB glove box/wiper arm covers
- WTB Black Interior Pieces.
- Twin 58mm throttle body.
- Comp pro mag 1.6 NSA's 7/16 stud, beehive springs.
- LT-1 Engine Wiring Harness
- WTB: 1 pair of silver painted 17" ZR1's
- Wanted: Front Shocks
- WTB 1LE Intake Elbow
- LS1 calipers + caliper carriers
- Firebird LT1 gauges
- MAF sensor.
- Taillights.
- WTB Power Antenna
- Camaro Export Taillights Wanted!
- WTB input shaft (T56)
- LT1 alternator
- Hey Anybody Got A ......
- WTB: Aftermarket hood for 94 Camaro
- WTB stock lt1 cam
- WTB: OEM Fog Lights for 3rd gen 82-92 Camaro Z28
- relocation brackets
- Looking For A Good Hood To Buy!!!!!!
- WTB: lt4 Spark Module
- WTB: TPI/LT1 performance and stock parts or trade for LS1 parts
- t-56 98-02
- WTB: pacesetter non-coated LT's
- Several parts needed -
- WTB - LT1 intake
- (trans) Help Me Please!!
- WTB: Stock LT1 rear disc brake
- Springs
- WTB OTVC Wires
- Jet hot or Kooks headers
- wtb stb,sfc
- In need of a bad Opti-Spark unit
- Need stock LT1 spring locators
- Need Lt1 Shortblock In Mia,fl
- WTB - 2 Comp 3/8" NSA 1.6 RR's (1318)
- Wtb 2 Stock Firebird Rims
- wanted : CC305 & springs & timing set
- needed: vats module
- WTB: Enkei Win rims...
- WTB: LS1 T-56 6-speed or LS1 motor with 6-speed
- Lt1 Heads
- Need stock LT1 head(s)
- keyless entry remotes
- WTB:Trans Am Door Panels (Black)
- Wtb T/a,firebird Ls1 Rims
- Mint condition charcoal grey firebird/ta interior passenger door panel 93-02.
- TA Monsoon System Wanted
- lt1 body cowl hood
- s10 transmission
- Need 93-97 Passenger fog light
- cheatR cam for 2000 m6 ss
- 93-97 Right Rear caliper Lt1 fbody
- WTB AC Compressor
- WTB: Hood Blisters
- Scanmaster Lt-1
- WTB: LT4 KM and E-Cutout
- Third gen t-5 parts needed
- Camaro 1994 Keyless entry / Aftermarket Exhaust / Audio Equip.
- WTB LT headers!
- mac headers w/ y pipe for 95 camaro?
- CC503 cam, Crane 10308-1 Springs
- Need Adjustable REAR Shocks For A 99z
- Air intake 02 ta ws6, Around long island for pickup!
- LT1 Flywheel, 6-speed shiftplate
- Need LT1 block
- WTB: T56 tranny crossmember
- PaceSetter LT's USED CONDITION
- wtb eibach pro kits
- WTB: LT1 hardened pushrods, ARP head & rod bolts
- WTB - LT1 Headers, Shifter, 17" wheels
- WTB- relocation brackets
- wtb:comp305cc cam
- Ss Hood And Rear Spoiler
- LT1 flywheel m6
- 3.4L cam
- WTB: Front bumper assembly from a 91-92 Camaro
- WTB: Gears or E-Cutout
- Spider gears, Series 2 POSI Carrier
- draglites/prostars
- Opti - unvented
- Needed Asap Fuel Pressure Regulator!!
- WTB midlength headers
