View Full Version : Parts Wanted
- WTB camaro dash pad
- Crank Hub
- 1996 A4 Engine Wiring harness and PCM
- Looking for a 98-02 front clip
- LT1 Catback or true duals
- WTB: 94-96 Camaro Factory radio
- Need accelerator cable holder.
- 1981 camaro z28 tail light needed
- 93-97 TA right fender
- 94 camaro z28 mods.....?
- WTB: 96-97 LT1 timing cover
- Timing cover needed!!!
- 2 coil packs, DBW gas pedal
- looking for a starter
- wtb 3000 stall
- WTB 97-02 center console lid button
- 10 bolt
- WTB: Upper Dash Pad for 97 Camaro
- 95-97 Timing Cover
- 97 motor
- WTB: 98 Camaro Mirror Trim
- Wtb Cc306
- WTB 94-95 wiring harness
- Keyed Balancer / hub
- wtb ignition retard box for my 6A box
- Ashtray lid=name your price, PS BLK floormat
- WTB: 97+ Camaro Medium Grey M6 shifter Plate & other pieces + Boot, NOS Wet system.
- WTB - Drivers side manual mirror
- WTB used LT1 oil pan
- wtb or wtt lt1 stock maf
- WTB: Pass side Mirror in gloss black
- WTB: AC Compressor for a 94 LT1
- Radiator shroud/support needed
- WTB (2) 275/40 r17 tires & 1LE Elbow
- Need factory correct CD player? Non-working OK?
- Sheetmetal needed
- A pillar trim
- WTB: used lt1 ported heads
- wtb weld wheels
- WTB: Trans Am Black Drivers Door
- WTB Neutral(light tan) colored interior pieces....
- Tail light covers, blackouts - 93-02 Firebird
- 94-97 Z28 or Trans am roller cam wanted
- Wtb '94 4l60e
- Stb
- WTB: Set of 17" wheels
- Need a power passenger door mirror for '94 Camaro?
- WTB: mid-length headers
- 1LE Intake Elbow
- WTB T56 shifter boot
- WANTED Iron Headed LT1 Drop out
- need a 1995 ss hood
- WTB Black seat belts
- wtb cat-back
- Whisper Lid
- WTB--> T56 Parts
- wtb lt1 engine
- WTB: Set of Aluminum LT1 heads
- WTB LT1 plug wires
- looking for a hitch
- WTB Headliner for Z28 Non TTop car
- WTB 15" x 10" Weld Draglite XP's with 6.5" backspacing
- WTB Vortech Mondo Bypass
- need ls1 rear brake setup ASAP
- WTB LT1 M6 Console Insert
- WTB: lugnuts from 97-99 camaro w/ 5stars
- 79 lb/hour high Z fuel injectors (or equivalent)
- WTB 93-96 Camaro Dash
- WTB 98-99 stock y-pipe
- WTB: stock exhaust for 1998-1999 z28
- WTB stock rear springs on the cheap
- LT1/LT4 parts, supercharger, rockers, pcm
- WTB - LT1 WS6 "Pontiac Ram Air" box/lid
- M6 Shift Place
- '98-'02 firebird/trans am (4) Headlight Brackets and pigtails (female side)
- Factory radio
- LT1 Dipstick Tube and Stick + Drivers A-Pillar
- T56 Parts
- WTB> Weld in SFC's.
- WTB ARP head bolts lt1
- stock ls1 injectors
- WTB LT1 Catback
- WTB 1997 LT1 hypertech programmer
- rear end and driver door needed.
- graphite t-top shades
- clutch allignment tool.
- 10" x 15" rims for F body( 2)
- LT1 Power Steering Reservoir!
- Looking for 93-02 Camaro Passenger Door and SS Style Spoiler
- y pipe for hooker long tubes
- WTB Transmission Perform button/cover.
- Stock Dual Cat Y-pipe
- WTB - Delteq Opti-Box
- Parts wanted
- ZR1 Rim
- WTB MSD 8.5mm S/C plug wire
- WTB Cone filter
- ls1 Lower Air Box
- Lingenfelter CAI filter cleaning/recharge kit
- Rubber grommet for opti vent
- WTB: LS1 coils
- Wanted Pass T Roof to UK
- WTB: Stock Catalytic Converters - $80 EACH
- flexplate, 97/98 vette fuel rail, injectors, throttle cable/CC cable FRC's
- Driver,s side headlight
- -4an nitrous line and fitting
- 96 6 Speed Center Console & Pillar
- WTB. MT Radials/Nittos/ET Streets.
- coolant crossover pipe for LT1 97 Z28
- WTB: CC503 Cam
- Bumper Support and Body Control Harness
- WTB - LT1 T56 Bellhousing
- 98-02 Ground Effects
- 9" or 12bolt CHICAGOland or Indy
- Needed! Lt1 F-body Water Pump Housing!
- 93 radio headunit harness
- WTB: Throttle Cable
- WTB: Autometer shift light pills - 6200-6500rpm
- 93-97 LT1 C5 brake adapters
- Weld Prostar 15x10
- Wtb: Lt1 Maf
- Stock LT1 cam
- WTB #60 injectors
- WTB stock radio/CD player for a 95 T/A
- stock LT1 airbox
- LS1 airmass meter
- looking for a T56
- Custom driveshaft for M6 with 9"
- wtb v-6 springs
- WTB Black passenger fender 4th Gen
- LT1 Engine Harness!
- Passenger T-TOP NEEDED
- WTB: LT1 Long Tube Headers & Off-Road Pipe
- Wanted: 93-96 Camaro Center Console (Manual)
- Set of struts/shocks for a 93-97 f-body stock springs
- WTB: lt1 stock flywheel.
- WTB 93-97 hood NORTHWEST
- WTB 3.73s
- WTT F13-112 for a ZO6 cam
- WTB shorty 94-95 headers with y pipe.
- LT1 Valve Covers
- Torque arm
- WTB SLP header for 97 trans am
- WTB: LT1 heads
- WTB LT1 exhaust manifolds
- need used intake gasket and 58mm TB gasket
- WTB auto trans for 96TA
- WTB: rear Camaro brakes for 98-02
- WTB LT-4 Composite valve covers
- White leather front seat(s)
- WTB 3.73s
- wanted ram air injection system
- 93-97 LTI CAI or full piping/air filter setup
- WTB: various bolts
- Wtb: Grey Carpet/black Frt Dash Pad
- WTB: '98-up black center console and power window switches+harness
- 95 camaro parts...
- Lt1 Cai
- WTB: (2) ZR1 rims!!!!!!
- WTB: Your Used LT1 Water Pump
- WTB: 4th Gen Leather Seats
- Need Ignition Module For '94z Asap
- WTB Catback. Magnaflow, Hooker, or Loudmouth
- Good, cheap non-vented opti ASAP!
- Wanted: your used LT1 lifters.....
- WTB Crane 104227 or 109821 cams
- Modded Short Block
- ntb bumpstops
- Looking for a 94-95 ecm
- i need a torque arm please help
- wtb le2 cam
- i need a passenger side fog light for a camaro
- Camshaft- 503, le2, 306, 847
- WANTED: 3200-3600 STALL for LT-1
- stock Y pipe
- WTB lt1 short/longblock/complete
- Pushrods
- 93-97 Drivers side/Left Fender - Black?
- WTB: Stock LT1 fuel pump
- COWL induction hood
- Wanted: 4th Gen Charcoal Leather Door Panels/Kick Panels
- Wanted: Stock lt1 Intake elbow.
- 96/97 4L60E for LT1
- Wanted: LS Intake Manifold
- 98-02 Hood
- 94 M6 LT1 motor harness and pcm
- WTT: My gauge cluster for yours...
- WTB: 94 Windshield Wiper Plastic Cover
- WTB: Boost/Vac, Volt, and AF Gauge
- exhaust manifold bolts
- MAF Screen Only
- WTB Pass Side Mirror Power
- WTB: Shifter for T5 (3.8L)
- WTB: Hood insulator pad for 1995 Z28
- WTB: LT1 Fuel Pump
- WTB: LS1 Coil Brackets
- Control Module Ignition 95 camaro
- heads ready to go on or come with new parts
- stock exhaust manifolds
- WTB 12 bolt or 9 in
- LT-1 Composit Valve covers :)
- wiper arm
- gutted catalytic converter
- Bright Red, Power Camaro mirrors
- WTB: 1305-16 Comp SBC Pro Magnum Rockers 7/16 Stud 1.6 Ratio
- lookin for a couple parts..
- Water Pump
- 95 Camaro Door Switch
- 93-03 mirrors
- Slp Loudmouth
- WTB: Car Cover 98 Firebird
- Need 36#+ Injectors, LT4 Timing Chain, 225L Fuel Pump,160* T-Stat,Oil Dip Stick 95Z28
- LT1 Supercharger crank pulley.
- Original GM Wiper Blade Frames for '97 T/A
- Rear end wanted
- WTB: Stock 94 MAF w/screen
- WTB: Lowering Springs
- parts needed
- WANTED: ebony sunvisors
- Camaro passenger door needed
- WTB drivers side exhaust manifold 94 95
- Y pipe
- wtb c5 front brake calipers
- WTB: 94 LT1 stock hood
- WTB: 93-02 Driver Side Ground Effect TA
- Clear Lid for LS1
- WTB LS1 Front Brakes
- front license plate bracket
- WTB : Front QA1 or Afco Shocks
- LT1 Heads for #441 or #462 Heads
- WTB: White Headlight door for 2000 Firebird/Trans AM
- WTB: used BBC parts
- LT1 Long tubes and ORY
- Lambo Doors
- Stock LT1 Alternator
- 1994 Z28 LT1 T56 Cat Exhaust Mount Brackets
- TTS Datamaster License Wanted
- 10 bolt rear (NY)
- cold air kit
- WTB:LT1 Bellhousing
- pigtail
- wtb: obd1 m6 pcm/ 48lb or so injectors
- I Need a Radiator for 1994 camaro lt1
- wtb forged LT1 internals
- WTB Complete 3.4 Engine
- WTB lt1 MAP sensor and/or harness
- WTB (1) bf goodrich comp ta zr 275-40-17
- wtb slp headers 95-97 lt1
- Headlight Knob
- wtb lifters
