PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
  1. WTB: RF Mirror Prefer red but any color
  2. LT1 Battery Cable harness , cooling fan part
  3. 97 Steering column
  4. WTB:stock 16x8 firebird wheels
  5. WTB: Chip for 95 Z28 and a driver side mirror for 95
  6. WANTED: NEW DRIVER Door latch Mechanism
  7. WTB: 58mm TB
  8. Supercharger for LT1
  9. WTB:3" True Dual LT1 Set up/LT1 Stall
  10. LT1 Radiator
  11. Need Dash!!!
  12. WTB fuel pressure gauge
  13. WTB: 1LE Intake elbow
  14. WTB: Comp 7/16 stud Promags and LE2 Cam
  15. Need Console for auto
  16. WANTED: Stock 487 Heads
  17. camaro passenger side mirror
  18. Mint condition charcoal grey leather steering wheel for a TA.
  19. WTB Torque converter
  20. WTB: 95 timing cover, WP
  21. WTB LT1/M29 Clutch Slave Cylinder
  22. need a limited slip
  23. 3:73 gear
  24. Wtb.2nd Gen Parts
  25. wtb front drop springs& shocks
  26. WTB: Camaro Driver Door
  27. Alum. Driveshaft
  28. injectors 32-38 lbs lt1!
  29. LT1 Trans Am/formula taillights.
  30. B&M Ripper Shifter
  31. WTB : 3.8L Camaro 5sp transmission
  32. WTB eibach lt1 prokit
  33. WTB: aftermarket lt1 hood
  34. WTB: 97+ tail lights or trade
  35. WTB: Power Antenna
  36. Tires
  37. Camaro SS convertible parts
  38. Comp Cams 306 'CC306'
  39. Wtb: c5 calipers
  40. SLP ss grill wanted
  41. looking for a 10 bolt housing in the mass/RI area
  42. Pedal Set
  43. WTB Comp 918 Springs
  44. stuff to get rid off or its gone!!!
  45. mufflers
  46. coilovers
  47. anyone got any blizzaks for sale
  48. wtb: More random LT1 parts I need
  49. 95 Trans Am body parts...
  50. Front cup holder trim cover (round) (97-99 Firebird, 97 Camaro) = 10288510
  51. WTB GOOD 58mm TBody Cheap???
  52. Speed sensor plug
  53. WTB LQ9/LQ4 short block and LS1 crank
  54. hypertech power programer
  55. Ground effects
  56. LT1 PCM wanted!
  57. slp loudmouth catback
  58. 12rib Procharger pulley Wanted
  59. front 93-02 fender moulding
  60. wtb ebony carpet
  61. WTB: LT1 Coated pacesetter lt's and breslin header bolts
  62. WTB SS hood for 00' camaro
  63. 93-96 Camaro Upper Dash pad
  64. 93-97 Camaro Console lid armrest
  65. WTB 1993 Fuel Rail Setup
  66. Spohn T56 crossmember
  67. WTB Abbott Cable X Box
  68. WTB: Leather Seat Covers
  69. Stock SA Rockers
  70. WTB 94 Z28 Fuse/Relay box
  71. LT1 windage tray
  72. Bottom of an engine?
  73. Wanted Casper Electronics 02 Sims
  74. WTB: 94-97 58mm TB & 30 lb injectors
  75. WTB Long tube lt1 headers
  76. Cam Kit? does ne1 have one for sale
  77. WTB internally balanced flywheel
  78. WTB: LT4 Hot Cam
  79. look for 36lbs fuel injectors and firebird front end
  80. WTB Pro stars
  81. stock springs
  82. WTB: Square connector o2 sims.
  83. WTB w68 firebird side ground trim
  84. 10 Bolt Needed
  85. WTB 93-94 Firehawk Wheels or Center Caps
  86. WTB or trade
  87. lt1 block wtb
  88. WTB...whole lotta stuff...LT1 cam, ebony interior...
  89. WTB 98-02 Ramair hood grills
  90. WTB electronic air pump for 95 Camaro
  91. Few LT1 parts
  92. WTB: water pump coupler, crank sensor, timing cover...
  93. Forged rotating assembly wanted?
  94. Wanted: ZZ9 Cam
  95. 95 Z M6 engine harness wanted
  96. LE3 Cam
  97. wtb 15x8 pro stars
  98. perf parts
  99. Need a Vented Optispark
  100. WTB: LT1 intake manifold 94 to 96...
  101. WTB: LT1 maf 3.5 inch
  102. 3.5 inch MAF wanted cheap
  103. WTB Vortech Supercharger Head Unit
  104. WTB: opti and 1.6 rr's
  105. 2 aluminum salad shooters needed (east texas pref.)
  106. Need emission tubing and related parts for 94 lt1
  107. Passenger side 93-96 tail light
  108. 1998 Z28 Exhaust manifold + cats + piping
  109. Console shift plate for M6
  110. WTB: 16inch ZR1 Rims!!!!
  111. pistons
  112. wtb: cc pro-mag 1.6rr
  113. Jack Secure Screw
  114. LT1 Longtubes, Michigan Area
  115. WTB or trade for LT4: LT1 knock modules
  116. ABS Sensor (Top of Rearend)
  117. 93-95 camaro two tone charcoal grey cloth seats
  118. Wtb: Lt1 Maf
  119. Will Work For Parts
  120. wtb 92-95 crank hub
  121. wtb stand alone fuel system for lt1
  122. WTB L&R front shock/strut assemblies...CHEAP
  123. WTB: 98-02 Longtube headers/Mac-mids
  124. WTB LT1 SS ram air box
  125. WTB: Series 2 Carrier
  126. LT1 trick flow heads
  127. WTB: '94 lt1 PCM for 4l60e auto
  128. Electric Water pump and Victor EFI for Gen I SBC
  129. drivers side manual mirror 98 camaro
  130. WTB-9.5 LT1 Vigilante 3000 stall with lockup
  131. WTB LT1 aluminum heads #'s 374 or 643
  132. Looking for a cc306 for an Lt1???
  133. WTB Used Dead/Broken 94 PCM
  134. 93-97 camaro Ram air hood and air box
  135. WTB:SLP Ram Air Setup and 1le elbow
  136. Camaro SS Spoiler LED Light
  137. LT1 Rear Caliper and bracket (passenger rear)
  138. WTB everything BMR
  139. WTB: Hot cam kit + PORTED LT1 Heads
  140. WTB: Dash pad and center console door
  141. Fog Lights
  142. SLP TOTL Catback
  143. WTB: Convertible specific interior part
  144. motor mounts for a sbc to bolt to a lt1 kmember
  145. WTB: 93-02 used 10 bolt 3.42 or 3.23 complete rear
  146. Wtb-rods And Pistons Lt1
  147. WTB: LT1 aftermarket heads
  148. need 15x4 cragars
  149. rs ground effects
  150. 12 bolt rear WANTED
  151. Rear End for 98 z28 6 speed
  152. 02 long tubes
  153. Need LT1 things...
  154. Wtb Clutch
  155. LT1 Throttle cable bracket
  156. Rear-end POSI + Disc wanted!!
  157. Lookin for a clear LS1 intake lid
  158. WTB: LS1 Stock Air Box Assembly '01 Trans AM
  159. 99+ LS1 Engine
  160. WTB:2000+ camaro interior stuff
  161. WTB Stock cats for 2000 Z28
  162. WTB: SLP cam 51006
  163. cold air intake.
  164. new exhaust
  165. WTB - EGR tube and manifold fittings
  166. WTB pass side LT1 T/A taillight
  167. WTB: LT1 Short Block, MICHIGAN Area
  168. WTB: exhaust hanger
  169. WTB: silver outlined SS emblems
  170. WTB-pass wiper arm from 96Z
  171. WTB solid motor mounts
  172. WANTED: 98-02 FRONT (2) RS Fascias ground effects
  173. leather seats
  174. wtb: sfc's for convertible
  175. WTB: F-body 3.5" LT1 MAF for my 96 Impala
  176. wtb hatch release button
  177. LOOKING FOR ANY LATE 4TH GEN (ls1) PARTS
  178. WTB weld wheels (draglites)
  179. WTB rims for my Camaro
  180. Brake Control Module - '96/'97
  181. WTB: 1LE Elbow
  182. WTB Center caps for these Rims Pics inside
  183. 82-92 Camaro 4in cowl Hood F/S or Trade??
  184. WTB: LT1 Pacesetter LT race headers
  185. Aftermarket Shifter
  186. 58mm throttle body
  187. Wanted - LT1 Stock Crank Pulley
  188. WTB: FUNCTIONAL fuel level gauge sender (in the gas tank)
  189. WTB 4l60e for a 95 Z28
  190. WTB:IAC Valve
  191. Rear Backing Plates Needed
  192. WTB a Comp 305 cam
  193. pcm for 94 Z
  194. WTB used c5 corvette rims n tires
  195. intake boot
  196. Wanted: stock, unported, unmolested LT1 MAF
  197. WTB aluminum intake elbow
  198. LT1 bose Delco CD head unit
  199. Whisper Lid LS1
  200. Eibach Sportlines for 96
  201. WTB stock elbow
  202. WTB 97+ camaro ASR switch
  203. WTB T56 in Northeast
  204. Factory breather hose LT1
  205. 94-96 Camaro shift indicater trim piece
  206. Torque Converter
  207. Steel braided line from clutch master to slave.
  208. black lense GTO headlight covers (?)
  209. WTT: 52mm TB or 58mm TB...
  210. need tubular k-member
  211. WTB: Tires
  212. Center console hinge 94 Z28
  213. wtb lt1 harness
  214. WTB 12 bolt!
  215. WTB: Ported Heads
  216. wtb Hot Cam Kit
  217. wtb aluminum inlet tube to TB
  218. WTB. ASR/Traction control electrical plug
  219. 93-97 t/a / firebird MYSTIC TEAL drivers fender
  220. wtb lt1 direct port
  221. wtb ls1 long block
  222. 93-97 upper dash pad
  223. wtb a few parts for 96z28
  224. will work for parts
  225. WTB: 98-02 Camaro front body parts (SoCal)
  226. Stock shifter stick.
  227. WTB stock wheel
  228. Vented optispark
  229. wtb: external fuel pump for lt1
  230. wtb: fuel cell
  231. wtb: LT1 block huggers
  232. WTB: complete accessory bracket w/ accessories
  233. WTB Passenger fender 93-97 Camaro
  234. pcm w/ egr delete tune obdII ---
  235. stock trans am wheels
  236. WTB: A/C Compressor or A/C clutch
  237. WTB: RF Mirror Prefer red but any color
  238. stock tq. arm mount &...
  239. WTB 9bolt posi disk to disk
  240. WTB EGR sysem for dual cat LT1
  241. Aluminum LS1 driveshaft!
  242. WTB Coated LT1 longtubes!
  243. 97 Z28 Dash Cluster
  244. WTB Wheel Dollies
  245. WTB Used 10 bolt 3.23
  246. 93 - 97 WS6 Ram Air Hood
  247. Wtb Lt1 Cai
  248. WTB stock exhaust for '96 LT1 Formula
  249. WTB: Carpet! 4th GEN.
  250. WTB: driver side rear brake caliper
