View Full Version : Parts Wanted
- turn signal housing-left
- WTB: 58MM TB and 36+ Lb injectors
- WTB: LT1 Intake/Fuel Rails
- chrome roll bar for a vert?
- LS1 Car wanted
- Need little plastic thingie that bolts in distributor hole for LT1
- Need some 15x10 rims with 5.5" backspace
- WTB: 2 16' Nitto Drag's And Cheap Rims
- A Good way to look for parts
- WTB- Performance SHOP Banners and stickers
- Looking for 99-02 Camaro Z28
- WTB EGR, Dynomax Muffler, Carsound Cat
- LT1 A.I.R. Fittings Needed
- WTB Hooker LT's
- 1.6 pro mags and lt4 springs thanks
- WTB. center console lid
- Wtb Borla
- WTB: Mac Midlength Headers and Y-pipe for LS1.
- WTB:lt4 Valve springs,retainers
- WTB: Afr Rev Kit
- Wtb Nitrous System
- 98+ WS6 Hood
- WTB: CHEAP CHEAP set of valve stock LT1 valve covers!
- WTB: Eibach Sportline Kit Springs
- Trick Flow or Vortech Intake Elbow.
- WANTED: OBDI connector, and Subframes
- top dash piece
- 52mm TB, and pass side mirror and window
- WTB: BMR Strut Tower Brace
- Carrier Housing
- E-Mail address, Duh!
- WTB BBK 58mm TB.
- passenger mirror
- 4th gen Z28/formula/trans am M6
- WTB LCA relocation brackets
- intake
- Stock speaker
- WTB: BMR K-MEMBER, Pro 5.0 Shifter, and more
- WTB: new or used Pro-Kit for 93-97 Camaro
- 94 lt1 airfoil
- Looking for a LT1 T56
- WTB: 4-channel amp!
- WTB: factory axles from 90-92 f body
- WTB: 4th gen gray cloth Trans Am seats
- Lt1/lt4 timing kit
- WTB- mangled, rusted, destroyed LS1 headers!
- WTB EGR valve for 95 firebird
- I need 3.73's for my stock 94 T/A
- WTB: LS1 and/or 6-spd
- Bare 350!!
- WTB stealth box
- V8 Dirve Shaft
- WTB: 58mm TB -89TPI, ECM's
- WTB 3.5 " Pro Stars
- WTB: Gray thirdgen interior parts
- WTB: 98-02 Parts
- Passenger door..?
- PCM4less or LT1Edit
- wtb-alt brkt
- WTB:17x11 Zr1's
- Anyone have a used Magnaflow or Borla cat back ???
- WTB- 28 spline axels for a thirdgen
- Torque Arm Mount For TH350???
- wtb stock 94 z y pipe
- Need a rear!!!!!
- Trade Built 4L60E for T-56
- Need a 3.8 Pressure plate/flywheel + clutch
- Lt-1 Maf
- NEED 93-97 small Front End Parts
- 3rd or 4th Gen leather seats
- lookin for 1LE or stock elbow
- Wanted LT4 heads & intake
- Camaro 30th Anniversary Floor Mats WANTED
- WTB - Billet Grill for 98-02 Camaro
- Street twin .. or other VERY STRONG clutch
- WTB 58 MM Tb
- WTB--98+SS or Z28 roller in nice cond.
- WTB, Cheap aftermarket catback
- TORQ THRUST 2's
- WTB: TTop A-Pillars for 93-97 Camaro
- short throw shifter
- WTB: WS6 LT1 Ram Air Box (factory air box)
- P1sc pulley 3.2-3.4
- c5 wheel
- need 2>>>275/40/17 good shape
- WTB Lt1 cam
- WTB: stock cat
- Lt1 trans am ram air duct
- ls6 intake and ssra
- WTB: T/A seats
- WTB: Ford 9 inch posi rear
- WTB ASAP: 1998 LS1 Engine Harness & Dash Harness
- T56 close to Midwest please
- WTB: 1.75" Coated longtubes
- WTB: 12 Bolt
- Stock Muffler Or Stock Exhaust
- WTB:stock ported 52MM TB
- Vortech S or T trim kit for 4th gen
- Cheap Heater Box
- Rear Blackouts For 95 Formula Firebird
- wtb hot cam or trade
- wtb: 58 mm tb
- Firebird tail light filler
- WTB: LT4 HOT Cam
- LT1 Block
- 96/97 LT1 Harness
- 1.6 NSA roller rockers
- WTB: NX (Nitrous Express) Purge Kit
- 93-97 LongTube coated headers!!!
- E-cutout!!
- Need LS1/T56 for swap..
- 245/50-16 Bfg Kdw
- wtb SLP loudmouth
- WTB LT1 heads
- WTB ignition coil plug wire to opti-spark
- wtb tubular k member for 93-97
- WTB stock cat
- stock LS1 throttle bodies! I need alot..so sell me your stocker :)
- WTB: new or used LT4 knock module
- Siberian Huskey
- Trans Am door
- LS1 T-56 transmission wanted
- WTB: Black 6spd center console
- WTB: fbody, lt1 or ls1....
- zr1 rims
- WTB: 98-02 Camaro SS Spoiler
- WTB: Torque Converter/ET Streets
- WTB: O2 extensions
- Any and all 4th Gen Camaro Taillights
- Wtb Ltcc
- WTB: nose, door
- WTB: ALOT OF PARTS 93-02 and T-56
- Wtb: Aftermarket 350 1pc Seal Crank, 3.48 Stroke, Eagle, Scat, Lunati
- TA A4 Shift Knob
- WTB ENERGY SUSPENSION tranny mount
- WTB or Trade Tranny T-56
- need 3rd gen power door lock actuator
- T-56 for A4 to M6 swap.
- WTB: lt1 6 spd (conversion)
- wanted, forged lt1 shortblock
- WTB: 93-96 RK Sport Console Gauge Panel
- Need 94-97 Trans Am passenger tail light!!
- Front 2-bolt main cap
- broken vented optispark
- looking for: 3rd gen 16X8 iroc front rims
- wtb: stall
- WTB: 3rd gen fiberglass cowl hood
- Looking for 98-02 SS Spoiler Artic White.
- Looking for 98-02 SS Hood Artic White.
- WTB: camaro z28 93-97
- 3rd brake light
- WTB Under glove box piece
- WTB: 97+ tail lights for Camaro
- WTB: Aluminum Driveshaft
- Z28 emblems
- im lookin for rally sport or vizage body kit for 93-97 camaro
- WTB: 98-02 Camaro Parts and SS
- WTB: Eibach or DMS lowering springs-94Z
- WTB LT1 heads and/or intake
- WANTED: 1989 stock TPI set up
- Wtb: Ls1!!
- WTB: HAL QA-1 Front shocks
- WTB or WTT for: Turbo Grafx 16
- WTB skip shift eliminator
- WTB: door panels, trans am, formula, firebird
- WTB: 25th or 30th Trans Am seat!!!!
- wtb: bmr or similar quailty panhard bar
- In the market for 95' cover + vented opti
- WTB: T/A rearend girdle and stud kit.
- WTB: 82-02 Seat belts
- 4l60e
- WTB or WTT for: Nintendo games
- Need 3:73 gears
- Nitrous parts wanted
- LT1 Block
- GM origingal 3.42 gears for 3.23up carrier needed
- WTB: shift boot for manual
- Used CAI intake needed/NIce cat back also
- Radio Trim piece : from 98+ Camaro
- Y pipe for hooker Long tubes
- 4th gen radio
- WTB BMR or Spohn LCA's
- WTB: 3.42 Gear 10 bolt and APHR
- WTB: Air Intake Elbow
- WTB 3.5" MAF - sensor only
- Wanted-Ground Control fr.set-up for 3rd gen
- WTB: Interior
- WANTED: 98-02 SS spoiler
- wtb:laptop
- WTB: Cloth Firebird/Formula seats and LS1 rear calipers
- Door Monsoon speakers for Camaro
- '95 Z28 MISC parts NEEDED
- WTB: 1 255-50-16 drag radial
- WTB: Wolfe 6 pt. Bolt in Roll Cage
- WTB: Stock Chrome wheels for Camaro
- WTB: Firebird Gauge Cluster
- WTB: 97+ Upper Console for A4
- Wtb 98-02 Frontend
- WTB: Vortech T-Trim for LT1
- WTB: cheap W-Body wheels for beater car
- wtb: eibach proline springs
- WTB: 36# Injectors, SFC, LCA-RB, Pocket Programmer & Adj. PHB
- Wtb Used Blower!!!
- WTB-Longtubes...
- WTB: 4th gen Rear Window Louver
- Wanted, Mufflex y-pipe
- Aftermarket Hood and Grille
- lt1 timing set, comp lifters, 7.3 pushrods
- Desperate for 2 WS6 rims (newer style)
- wtb!!!! 3rd gen. cowl hood
- WTB: Y pipe for AS&M headers
- WTB: !2 Bolt Rear
- WTB: Mac mid-length headers w/ y-pipe
- LT1 Pistons
- WTB: LT1 Heads/Intake
- Wanted - 93 to 97 camaro fenders
- 6 speed ****er plate
- WTB: 93-96 Tail lights, + 98-2002 Headlights
- wtb 98+ headlight assembly
- 35th SS wheels wanted
- TRADE MY fresh 4l60,flywheel,console torqe arm for a t56 setup
- Stealth Box wanted
- 94 engine wireing harness
- WTB: LS1 Cat back
- Interesting projects for sale
- WTB NX wet kit & Prostars
- WTB: Drivers side Power window motor
- Wanted 4th Gen F Body
- looking for zr1 chrome centercap. Help me out please!
- wtb: zr1 chrome centercap(s)
- Does anyone have a chrome zr1 centercap sitting around? One of mine got stolen
- WTB: 17" rims
- 88-92 IROC, Z28, Trans-Am Wanted near Denver
- wanted 94-7 fuel rails
- Front 93-03 front susp. MIDWEST
- Wanted Ram Air Intake
- Dash bolts
- Headlight assembly - reply again
- WTB:poly motor and trans mounts
- Suspension Parts Wanted!!
- Wanted M6 4th gen fbody, chicago
- WTB Longtubes or Mids
- WTB:6 Speed Tansmission
- WTB: throttle linkage cover
- WTB: Dual Pillar Pod
- WTB: 98-2000 LS1 WS6 or SS around TENN!
- WHITE hurst shifter knob
- WTT: my 98-02 tailights for you 94-97 clear tailights for T/A
- I need transmission lines!!!!!!!!!!!
- WTB: t-top conversion parts
