View Full Version : Parts Wanted
- WTB CC 306 or similar cam
- lt1 t56 wanted. any ltx 6-speed will be fine
- stock rocker nuts
- 3 3/8 inch tach
- ASAP i need a USED STOCK LT1 lifter ASAP
- WTB: 1995 Bose CD player
- Header Panel - LT1 bird (headlight bar/mount)
- lt1 main cap
- WTB gm847 new or used.
- black leather ta seats
- 97 + camaro tail lights
- 98 up ram air style airbox for ws6 car
- WTB Stock Springs
- trc-2 timing retard & misc. supercharger parts
- Need 10 Bolt 3 Series Carrier
- suspension parts needed
- Honeycomb taillights, what a surprise!
- LT1 Formula / T/A tail lights....
- Wtb 4 275/40/r17
- 97-98 Corvette Fuel Rail
- lookin for 18" rims
- wtb 3rd gen wheel adapters
- Still looking for a stock 93-97 speaker!
- want ONE C5 rim
- WTB: Camaro center console lid
- need 17 inch torque thrust 2 or eagle 211
- wtb ram air style hood for 93-97 trans am
- WTB Elbow
- WTB few stock SA rocker arms
- 1997 camaro dash
- 93-97 camaro fog lights and SIR coil for driver air bag
- WTB: Driver Side Tail Light assembly (3 colored) for 1997 Camaro - just the housing
- 96 camaro need carpet hood ...
- 1998 camaro SS engine
- WTB 1 or 2 16" SS Rims (convertible model) Grey
- WTB: 93+ camaro side mirrors
- Lifters, Pushrods
- Camaro floormats
- WTB aftermarket v6 parts
- WTB v6 cam
- Need a CAI , Cold Air, Intake
- Need exhaust manifold from 87-92
- LS1 camaro tail lights
- WTB: 95+ opti harness in Canada?
- LS1 Front Brake Conversion
- WTB: 93-97 Interior/Exterior Parts...
- Intake Gasket for LS1 needed
- wanted 1 1997 stock camaro ss rim
- 1996 Firebird Part-Out + Paintball Stuff
- Harlan Shift Light
- WTB: LT1 Z28 Cam
- WTB: radiator,e-wp,hotcam kit,zo6/zr1 wheels
- Autometer carbon fiber guages
- Stock 95Z stereo
- wanted: weld centercaps
- wanted LT1 t-56 transmission
- WTB: 255LPH Walbro and 30# injectors
- WTB E-Brake cable '88 IROC
- WTB - Adjustable rear shocks
- Ramair Box
- WTB - Stock Strut Assembly
- Wanted: Gears for 9 Bolt Aussie Rear end 3.73 or 4.10
- Ss Wheels
- Front speaker
- WTB Worn hood struts.
- 3.4 Factory Wiring Harness
- 2400-2800 12" Torque Convertor
- Broken/bent Input.cracked Case T56 Borg Warner!!!!!
- WTB: 4L60E High stall converter..for a 1994 Z28
- cigarette bezel
- 94 Z28 hood wanted
- Wtb 94 Engine Harness
- 1995 z28 155mph speedometer
- 98+ camaro OEM fenders
- WTB Stall Converter for 4L60E
- WTB: 396 pistons .030
- stock lt1
- ss hood airbox
- LS1 WS6 hood
- WTB Original Floor mats 200 z28
- Need some LS1 coils!!!
- LT1 crank hub
- Parts NEEDED ASAP!!! SENSORS ETC
- Need 1.6 RR for Lt-1
- WTB: Tubular K member for 84 camaro
- WTB:LT1 Headers and other LT1 parts
- WTB Power Antenna
- WTB shorty headers
- I need a flat bed car trailer LOOK INSIDE for what I have to offer for it
- Stock LT1 Shortblock
- WTB: Tubular K-Member for a LT1
- WTB: E-cutout
- WTB posi & gears for 7.5
- wtb 94+ fuel rails
- WTB: 98+ Camaro Dash
- WTB Stock Cats ASAP!!
- exhaust
- WTB: Trick flow elbow and lt1 edit or tuner cat
- WTB: Comp 987 springs, hardened pushrods ( Need them right away )
- 396?
- 98+ camaro fenders and other
- factory cd players
- wtb: 383,396 motor
- PBR brake setup
- wtb 92-93 lt1 intake manifold
- WTT or Buy:Aftermarket Rear End, Moser, 9'' etc.
- 96 ta rear hatch pannels
- Dash Pad...
- Slp Cai...
- Ringer Gear Spacer
- 98-02 Black Halo Headlights
- WTB 93-97 TA dark green left front fender
- 1,6 rockers for lt1
- Valvetrain stuff (edited)
- WTB LT1 ignition and vats
- Front Strut Mounts Needed
- lt1 engine craddle
- WTB LE2 Heads and cam
- 4th gen rearend in Ohio/Indiana/Michigan
- supercharger or turbo setup
- Looking for 2 tires 275/35/18 285/35/18?
- ss ram air kit
- WTB Stock Working CD player
- stock 24lb lt1 injectors
- valvetrain stuff..
- WTB: Drag slicks w/ or w/o wheels
- LT1 heads
- need front speaker for passenger door
- Ultra Z hood or VFN sunoco cowl for 99Z28
- spoiler
- Pushing the envelope... 95-ish camaro SS hood and spoiler
- WTB: SLP 20TL cat back system
- WTB: All parts for a t-top conversion
- WTB: Lt4 hotcam springs
- procharger for lt1
- Red Plastic LED Cover for 98 SS Spoiler!!!!!
- 93 to 97 red body parts
- 94'-'97 rubber seal that goes from plastic intake tube to MAF
- t56 built w parts for conv .good shortblock
- I Need A CAI & Intake Elbow *Have Cash*
- Lt1 Hub Need asap!!!
- LT1 Exhaust Manifolds
- 98 Z28 Red Right Rear Body Side Molding
- TT2's
- Wtb: Composite Valve Covers
- Wtb Laptop!
- NEED ASAP- Camaro 93-96 Interior parts
- NEED Cheap T-56 or 4L60E in MA (BOSTON) area
- New manual driver's side mirror and front passenger seat belt buckle!
- WTB: LT1 Header/Exhaust (TX)
- LT1 sensors needed
- Need 98-02 PS lower A-arm and spindle
- pacesetters headers
- WTB:seatbelts
- Crane TRC-1 Timing retard control
- Need A Rear
- ls1 hydraulics wanted!!!
- Wanted- Stall Converter
- WTB Stock Red Hood for 98-02 FB or TA
- WTB pushrods
- Longtube headers
- need some 42lb injectors
- 79-81 z28 fender louvers
- 97+ power antenna
- 93-newer T/A wing
- 3 pod pillar
- wtb
- 91rs bumper
- WTB - Borla Plates
- WTB: full pillar gauge pod for hardtop 97-02
- WTB:LT1 Short Block, and low mile Opti
- WTB~P600B 1st Gen. SBC Brackets for blow-through
- lt1 tail light harness
- 10 spoke ss rims
- 1.6 roller rockers for LT1
- swap items needed
- WTB: chrome SLP badge
- wtb some ported lt1 heads
- WTB: Complete LT1 motor
- wtb t56 bellhousing for lt1
- strange request: seat parts not seats
- ls1 t-56
- random stuff needed
- 383 or396
- WTB: Torque Thust 2's
- WTB: LCAs
- WTB: Bare 350 Block w/Main Caps
- Trans Am Fog lamp
- WTB: Manual Drivers mirror,Upper dash cover 99
- wtb 99 to 2002 ls1 engine harness
- WTB X or Y pipe! Help me out!
- Front 12 way adj Qa1's & 275 springs WTB
- rims
- SLP Loudmouth Exhaust for 02 WS6 T/A
- transmission 98 z28
- WTB: 94-'97 T56,clutch hose,pro 5.0, FL
- CAI....and aftermarker intake elbow
- LT1 SS Intake
- WTT LT1 A4 for LT1 M6 conversion
- T56 Inspection cover/after market ls1 ram air lid
- T56 input shaft
- air bag sensors for 95
- Wtb 94 Opti
- Clear Turn Signals 93 Z-28
- WTB: Coolant temp sensor
- WTB: Manual doors and interior panels for 96z
- WTB: Entire Air pump system
- need rear end
- WTB: A Piller plastic, fan shroud/rad support
- wtb long tube headers w/ypipe
- wtb any 94 lt1 performance part
- rear end parts
- WTB pair of skinnies
- WTB: LE2 heads or stock lt1 heads
- 93-97 camaro ss hood
- Gunmetal Z06's
- WTB: LT1 timing covers
- WTB: Prostars 15x10
- Need a boot ring for a 94 ta
- bmr or umi k member
- hood and convertible light bar
- Need a 3.8 engine in the AZ area...
- WTB RkSport Dual Gage Cd Console Pod
- Wtb:hurst Billet Pro Shifter For Lt1 T56 Complete!!!!
- t56 dust sheild
- Need OBD1 pcm auto lt1
- wtb mac y- pipe
- wtb stock z28 rims
- 98-02 camaro front end!!!!!
- WTB/WTT 3inch electric cutout
- Wtb: Lt1 Complete Air Box Assembly
- Wtb A Set Of Chrome Z06 Wheels
- WTB...LS1 Front brakes and spindles
- Lt1 headers and ORY
- WTB lt1 cam 94-97 z28
- WTB:Wheel spacers and stock lugnuts.
- csi waterpump
- WTB: 4l60E for 94 Camaro in NC, or SC
- WTB: cat mount/support for T56 transmission.
- Need a Tail Shaft for my 4L60e
- 95 opti harness
- Need 6spd Console 93-96
- driver side spindle/knuckle for 93-97 LT1
- WTB 12 bolt Moser
- need a maf meter
- WTB.160 Tstat for LT1.
- anyone have Tunercat calibration file (TDF) for 96-97 LT1?
- WTB: 93-96 camaro manual console trim piece
- OTVC wire looms...LT1 cut to fit wires
- Manual Shift Knob
