View Full Version : Parts Wanted
- Trans Am Side Skirt Needed
- looking for a decent 94 formula steering wheel
- Black Wheels Wanted
- Dash cover part# 10269102
- need taillights for a firebird
- 92 bose front amplifiers
- WTB: 96-97 SS Hood
- Firebird CD head unit
- looking for 93-96 camaro shift plate for t56
- Need a trans Crossmemeber for 700r4 3rd gen
- Dual/Triple Pillar Pod
- 1996 Camaro z28 wheel
- shorty headers for dual cat
- Cruise Control Cable
- WTB Shift plate with ash tray for 6 speed
- WTB: AC Delco Oxygen Sensors part # 25312184
- 95 camaro z28 Vented optispark
- Z28 parts wanted
- WTB: Aftermarket Parts for 00' WS6
- need 97 WS6 interior parts
- Need cam dowel pin in Dallas Tx. Area!
- 93-96 camaro driver window switch
- 315/35 tires
- 93-96 M6 center console for Firebird/TA
- WTB: Gears
- wtb ram air intake, brakes rotors lowering spriings
- WTB 96-97 timing cover
- Wing/Spoiler Brake light cover (93-02 TA)
- Emissions Parts 95 Z28
- Lt1 Short Block
- 94 parts needed
- GTech Pro
- LSX/LQX Centerbolt Valve Covers
- WTB:Cigarette lighter panel
- Hurst shift knob and boot needed
- Strano springs/Koni SAs
- WTB 93 LT1 AIR/EGR tube
- WTB lsx 90mm tb and Trans Brake Switch
- wtb: pacesetter y pipe
- WTB: smoked headlight covers for 93-97 Camaro
- WTB:LE1 or LE2 Cam, timing set, hardened pushrods (can be stock from 94-95 LT1), ect
- T-56 Hydraulics and Pedal Assembly for 95 lt1 camaro
- Stock LT1 Cam for vented opti
- Wtb:arp Bolt Kit And Le2 Cam
- Ttop Brackets/Holder
- Hood for thirdgen
- wtb pcm/ecm
- 93-97 Console / Batt. Positve Splice Cover
- 9" Differential...
- Wanted: LT1 long block
- WTB: Bad (stripped gear) electric antennas
- hood/passengers headlight door for green formula
- wtb 98+ driver's side ta tail light
- Need 94+ lt1 fuel rails with an fittings welded on.
- WTB: 93 detent cable and throttle bracket
- Need wheels for a 94 formula
- WTB T/A passenger tail light
- WTB: Gray T-Top Shades
- WTB Pace setter long tubes
- WTB Ultra Z hood for 99 z28
- wtb lt1 flywheel and lt4 clutch, and pedals
- WTB Pacesetter Longtubes Coated
- ss hood
- Need A Few Parts For 99 Fire Bird
- o2 sensors
- LT1 N2O kit
- 30lb svo injectors
- WTB..LT1 shortblock
- wanted a low miles 96 LT1
- Wtb: 94-95 Pcm 16188051
- Ac Delete
- Need WORKING A/C Compressor for 97' V6 camaro
- Trans Am spoiler
- WTB. Serpentine Belt Set-up
- WTB 93-02 Passenger Quarter and Rocker Panel, taillight wiring
- looking for a stainless works ORY for stock manifolds
- Complete rearend
- passenger door
- Looking for Camaro RS or RS-Like ground effects!
- Dual Fans and Balancer
- I need compete A/C setup for 97 TA
- R compound tires
- t-top conversion items and airbag clock spring
- 18" Eagle alloy 077, OR ZR1 style wheels
- LT1 longblock, shortblock, or rotating assembly
- need a cowl hood cheap
- wanted y pipe long tube headers
- stock trans am radio
- 9" rear near Connecticut - up to 5 hr drive
- Wtb 93-97 T56
- drivers side a pillar cover
- WTB: Valve spring micrometer
- Hand Brake Handle, '94
- WTB: console (93-96 camaro), grey/black 4th gen seats
- wtb: pacesetter long tubes
- 95 Engine/Transmission Wire Harness
- wanted body kit for 1995 Camaro
- WTB: cheap muffler under $25
- torsen diff
- 94LT1 CC305 or LT4 Hotcam
- O2 sensors for 94 z28
- WTB 93-97 Rear Axle Tube
- WTB two stock wheels "salad shooters."
- WTB: Many LT1 Camaro Parts
- Looking for a 3" electric cutout
- WTB Hotcam/lt4
- WTB: LCA, Rear shocks, Adj PHB
- need z28 parts
- Low Impedance injector box.
- looking for 52 or 58 TB
- 3000series2 v6 upper intake and valve covers wanted
- WTB: Hatch Cover, Trim Pins, Console Base, Jack, Speaker Grill, Antenna, CD changer
- lt1 anything
- WTB- Hood
- TC inspection cover
- WTB - elbow and MAF set up 94 LTI
- WTB LT1 Acc bracket
- Aeromotive A1000 Fuel Pump
- Pigtails:
- camaro font clip 93-02
- 6.0 block
- WTB: CAI, tuning laptop-software-cable
- wtb: passenger side motor mount mounting bracket
- Need 3rd gen Paxton parts...
- LT1 corvette composite Valve Covers
- WTB accufab 4150 TB
- Wtb: Chrome Moly Phb W/ Rod Ends
- TA tail lights
- WTB LT1 6 speed conversion CASH IN HAND
- WTB: Hooker muffler for 00 Camaro SS
- WTB Driverside Outer Headlight/bucket
- WTB 93-97 Ram Air Hood
- WTB: Interior Pieces
- wtb - go fast goodies for 96 lt1
- Bose door speakers and amps
- Water pump drive gear
- WTB SS Wing 98-02
- need a/c delete pulley
- WTB. Serpentine Belt Set up + electric fan
- Need 95 lt1 wireing harness and elec.fans
- Wtb: Ltcc Setup!!!
- Clutch assembly
- A few 2K camaro things
- wtb: long tubes
- WTB: LT1 Nitrous Plate or Nitrous MAF Housing!
- WTB: Parts for cam install...
- WTB LT4HC Springs
- WTB: Console Lid & Horn buttons...
- WTB: LT1 Shortblock
- WTB: Radiator for 95 Z28 Cash-in-hand
- LS6 intake
- x-pipe
- WTB accessory bracket
- shift plate for 98+ fbody (manual)
- Need LT1 waterpump housing ASAP!!!
- wtb ltX crank
- WTB Mallory 685 and Fuel Pressure gauge
- Accel dual sync dist.
- Still need AIR fittings!
- 6-speed Transmission
- WTB 1LE springs
- MAF screen
- WTB/WTT:SLP Dual Dual stainless muffler trade for Hooker Aero Chamber muffler
- Wtb 93 Ecm
- WTB: 93-02 scissors jack and lug wrench
- WTB- Hardened input shaft for TH-400
- 6-spd Camaro Console (93-96)
- wtb opti rotor
- LT 1 parts needed
- WTB lift off LT1 cowl hood
- LE2 h/c
- WANTED cold lt1 cold air intake YESTERDAY!!!!
- WTP:383 rotating kit
- Set of tires...
- WTB Front bumper cover 93-97 Camaro
- Badly need air injection assemblies!
- WTB- 24lb injectors for LT1
- Camaro- AC Vent Trim Piece
- WTB: Rear bumper, and panel under the tails
- 95 T-56 Pigtail NEEDED!!! $$
- WANTED!!! 4th Gen Rear
- WTB:LT1 Motor / Stock or built
- WTB: 96 LT1 Windage Tray
- WTB: Clutch fluid reservoir cap.
- WTB - $$$$ for catalytic converters , cats
- WTB: VSS for T-56 transmission
- WTB: LT1 block, or motor, pref. in western canada
- WTB: Front bumper cover
- wanted t56 transmission for LT1 + all parts
- WTB: passenger side motor mount for LT1
- MAC products?
- baby lt1 cam
- WTB: 95 wiring harness, Passenger door panel, Dash, ac ducting, more...
- WTB : Vortec Heads
- Wanted- Race seats
- camaro z28 transmission
- WTB: Long tube headers and y-pipe
- WTB Reverse Lockout Solenoid Housing T56
- In need of 02' upper "manual" console *trades too
- wtb 3.8
- WTB-Intake Runners & 24lb injectors
- WTB pull put engine w/ harness/pcm
- WANTED-WTB:Camaro Factory Shop Manual-98-02
- Borla or SLP Large Diameter Y-Pipe for stock manifolds
- wtb delco bose spaekers
- wtb slp dual dual rear exhaust hangars
- Looking for LT1 engine in Chicagoland area
- torque converter
- WTB/WTT: 15" Rims (2)
- wtb stock exhaust manifolds
- WTB : 305 TPI heads.. or equal
- Long Tubes
- WTB : used lt1 cam
- LT1 Nitrous Kit
- wtb opti rotor
- passenger side mirror
- 93 LT1 block needed in Central NC
- wtb lt1 head
- ls1 upgrade brakes/ front clip
- 95 center console armrest needed
- WTB Aluminium Intake elbow
- 30lb to 38lb Injectors
- WTB - M6/T56 Cross Member/Transmission Support
- 98-02 SS hood grille
- WTB - Trailer Hitch
- Ls1 engine! What do you guys have!!
- Looking for some parts
- WTB: Water Pump to Block COUPLER
- WTB - 96 Spd Console for Camaro
- WTB: LS1 Rear Brake Setup
- 1993 - 2002 F-Body Manual shifter boot (underconsole)
- drag radials 16" or slicks
- WTB NON TCS throttle cable
- WTB ash tray lid
- 95 camaro z28 transmission dipstick tube
- WTB:LT1 F body parts (Radiator, A/C compressor and lines+)
- WTB... AFR LT4 heads
- 1994 Hpp
- 4th gen rear seats and belts
- 3.73's rear end center section
- Vortech intake tubing
- white rear bumper cover
- SLP 2otl
- WTB: Exhaust Tips
- WTB: LS1 steering shaft linkage
- WTB SLP CAI, Chrome/Polished LT1 stuff...
- Camaro Center Console M6
- looking for black ZR1s.
- WTB 10 bolt rear end
