View Full Version : Parts Wanted
- Wanted: Stock LT1 Throttle Bodies
- wtt/wtb 4" cowl hood
- NEED-cowl hood, rims, lowering springs/kit, pro5.0
- WTB LTI flywheel
- OK Im in need of the Z28 T56 Shifter Hydrolics!!
- 4:10 gear
- WTB working stock LT1 short block
- TNT Nitrous plate with fogger nozzles wanted
- Wtb:borla And Ory For 93 Lt1
- WANTED: Stock MAF....need asap.
- I Need Parts From 94/97 Ta?
- t56, clutch, headliner non-t-top, shifter, wheels, tires, leather seats, ft sway bar,
- wtb lt1 underdrive pulley
- WTB: 2 CHROME 17" CAMARO SS 10 SPOKE RIMS
- WTB LT1 distriutor shaft peice
- Need a hood, pass. fender and front bumper and rear bumper cover 93-97trans am
- Tach needed
- Wanted: T56 Conversion Parts
- wtb: built t56
- Pro50 short shift (t56)
- Body kit
- WTB 10bolt cover
- LT4 heads and intake
- I need a short shifter for my 2001 Camaro V6.
- I need Eibach Springs.....
- WTB: Vented Optispark
- LT1 T56 Bellhousing
- WTB: Bra for 95 non RS
- need a wiring harness for a 1997 dash harness
- wanted: jet hot long tubes, pro 5.0 shifter
- FLP Cats
- WTB: 350/355ci LT1 shortblock
- WTB Stock Cam for 94 LT1
- I need a 98-02 Camaro SS wing and hood.
- used 82-92 iroc hood good shape NEEDED!
- 92 camaro 350 TPI factory computer chip
- I need some lt1 heads
- Dual Cat Y-pipe Stock or Aftermarket
- need 02 extensions for an LT1
- WTB LT4 Composite Valvecovers for LT1
- Wtb 3.4l(pa)
- Have tuned port will trade
- WTB: MSD RPM Pills 3000 and 5800-5900
- WTB: Manual Fan Switch for LT1.
- looking for some headers for my single cat lt1
- 98 Formula
- WTB rims - IROC 16x8 or??
- 93-97 firebird header panel
- aftermarket keyless entry/alarm system
- Shorty Headers for 93 LT1
- Third Gen Parts
- ford 9in housing for 4th gen
- WOLFE 6pt Cage
- T56 Good or BAD
- 93-97 Power Window And Door Lock Switch
- Euro lights wanted for 1994 Firebird
- Wanted: Stock LT1 MAF
- Throttle Body needed bad
- Computers / Proms needed
- NOS fuel pressure shut off
- Need T56
- Looking for SLP 2OTL muffler and tailpipes
- WTB Leather Camaro Seats LT1/LS1
- wanted Lt1 t56
- WTB: horn buttons for 95 Camaro
- wanted exhaust and cold air intake in or around NJ
- dash panel 93-96 camaro
- WTB: leather seats front and rear!
- wtb: 96-97 ss hood ram air box
- gm 847 cam
- Looking for 1 Firebird AC Vent
- 1350 yoke for 4L60E
- Wanted: Stock Cat-back system from 96-02 Carmao Z28(In IL area)
- WTB: red front bumper cover for 98-02 Camaro
- lt1 clutch hydraulics
- WTB chromoly PR's, ex612's.......
- WTB: LT1/LT4 4 bolt main block!!!
- 93-97 Center Console
- Lt1 Performance Parts For Sale !!!!
- Need LT1 throttle body Elbow!!
- O2 simulators for my 99 z28
- WTB: Two rear wheels
- WTB - Comp Cam NSA 1.6 Pro Mag's
- WTB fog light cover for a '97 Z
- WTB radiator
- need 93-97 body parts
- Hood hinges, Hood latch bracket, lower a-arm
- Obd1 Pcm
- WTB: Vented Optispark.
- fuel injectors, 36-42#
- Boost/fuel press gauges 2 1/16"
- T-Top Conversion Kit Needed
- WTB Bare LS1/LS6 bare block
- WTB DMH e-cutout
- Need VIN from a wrecked or salvage 98+ Camaro
- I need one stock crome 5 spoke for.....
- WTB 93-97 Foglight(s)
- WTB: (4) 275/40/17 tires used or new
- WTB Corsa exhaust tips
- WTB: LS1 and tranny
- Wtb Holley Stealth Ram
- Ls1/lt1 Bare Block Needed
- WTB: 1-10 spoke SS wheel
- WTB CD Player
- WTB Transmission
- wtb: lt1 y-pipe or s-pipe
- LT1 Block Needed
- Custom box and subs
- Anybody have the back half of the T56 wiring!!
- wtb: trans am drivers door red
- Weld Prostar XP Series
- WTB LS1 block or short block
- WTB...LT1 radiator, camaro RH mirror, other misc parts
- WTB T-56 Flywheel
- WTB Stock 94 4L60e converter
- 97 Z28 rims... read on
- WTB: Torque converter for 94 LT1 f-car
- ZR1 Center Caps
- WANTED=97 firehawk LT4 Heads $200.00 cash
- wtb: 93-97 camaro fender
- DRL socket part #
- Spohn adjustable torque arm
- 93-96 camaro z28 gauge cluster wanted
- 98+ 4l60e core
- Lt1 K Member
- Trunk lid
- WTB LT1 intake, fuel rail and injectors
- Vortex exhaust cone, cut out, DHM cut out...
- stock manifolds needed
- Wanted Gta Seats
- gm 847 cam
- WTB LT1 heads
- 95+ timing cover
- WTB: LT1 heads/Intake
- Driver Side Stealth box
- Built T-56
- T-Tops/T-Tops with conversion stuff
- WTB: Charcoal Trans Am Leather!
- two 17" rims that will fit a tire 275-295 wide
- looking fot a maf for a 95 z
- WTB: Nitrous express jets for a shark nozzle
- WTB 97-02 SS Spoiler
- WTB: Stock Camaro EXHAUST and HEADLIGHTS
- WTB: LS1 complete brake upgrade (IL)
- Wtb: throttle body and intake manifold
- Anyone with an M6 break their console?
- Im Need of the Y Pipe for the Edelbrock Shorty Headers HELP!!
- wtt: cc305 for cc306 or something equal!!!!
- console plate
- Top Inst. Panel Upper Pad 93-96 Camaro
- Wanted: Two 17in rims
- WTB: Solid LT1 motor mounts
- 97-02 leather seats
- 97 dodge dakota parts wanted
- LS1 K-Member and A-Arms
- LOOKING for a lt1 block, in GOOD condition
- WTB Steering coupling shaft
- Need Lt1 97 Fuel Line Bracket For Rear On Manifold
- Still looking for a shortblock 350
- WTB: aftermarket torque arm, LT4 Valve covers
- WTB: misc. LT1/LS1 Z28 parts
- WTB: LS1 3 and 1/2 inch MAF
- Need: Pair of O2 Sensor Extensions
- WTB: 2 stock silencer tubes for stock LT1 rubber elbow
- WTB: 94 camaro body parts
- WANTED ASAP LT1 Wiring harness for the T56 PLEASE!!!
- WANTED: 10 spoke SS wheels (00-02)
- Headlight actuators
- WTB: LT1 Longtubes
- WTB: Moser rear, LS6 intake
- FLP headers and Y pipe
- Looking for strut tower brace and vented opti spark
- WANTED 95 Dash Cluster for a Z28 Please
- 93-02 Firebird or TA side skirts
- Suspension parts/ spark plugs/ o2 sensors...
- Lookin for Afermrket Heads for a 94 LT1.
- Stock 4th Gen Camaro Wheels + Tires - Portland, Oregon
- Wanted: Brad Brand Intake Tube for S-Trim
- 17x11 ZR1s, and a laptop
- List of parts
- Interior Stuff
- 97 exhaust setup!!!!!!
- Need TPI Wiring Harness from 86-92 Firebird
- NEED LT1 Alum Heads .
- Comp Pro Mag 1.6 NSA 7/16 rockers
- Wanted: T56 or 6spd Tranny
- Want To Sell Your Delteq/Dynaspark/LCA's RELOC BRACKETS/Adj Panhard?
- looking for tires 275 40 17
- Looking for heater hoses for 94 LT1
- Posi rear end
- LT1 Radiator needed asap!
- I need a 4l60e tranny for 95 z28!!!
- aluminum heads
- WTB: 12 bolt, or 9" center section... asap
- W.T.B 93-97 camaro fog light
- L98 heads
- Need LT1 Trans-Am parts
- WTB T56 stuff. Bellhousing/Flywheel/clutch stuff
- Wanted ! LT1 GM Carb Intake
- Black Carpet
- WTB carbon fiber DS or trade aluminum+$$
- Wtb: Manual Trans
- misc '97+ Camaro taillight lens and driver's seat belt bracket
- ls1 parts
- 86 camaro door panels
- lt headers
- Need F- Body MAF ASAP
- wtb gray and red 4th gen seats or trade
- WANTED: 93-96 camaro M6 center console
- Need LT1 intake accelerator cable bracket
- Need Head Gaskets!!!
- stock 4th gen exhaust tip
- 4L60e 98plus core needed
- seeking ls1 parts
- WTB: Leather Seats
- WTB: right side t top for 2000 camaro
- WTB...HPP3, LS1 Edit Or Similar For 02 M6 Z28
- Need 93-97 TA Bumper and foam (black)
- Wanted....Longtubes With Y-pipe
- Need lt1 engine
- looking for an SRI Coil
- wtb ls1 coils
- WTB : Stock 95-02 T/A wheels locally DFW Texas
- 95 T/A drivers fender and inner panel wanted
- WTB: Catted Y pipe for Pacesetter headers
- WTB Spare tire, jack, and tie down.
- WTB:Aluminum Driveshaft
- 93 Cntr Console Part.
- looking for a LS1 front brake conversion
- Dash Pad
- Wanted: 265/40/17 tires, 30# injectors
- WTB: Lt1 gasket set GM, or Felpro
- WTB: Crane 10308 valve spring kit
- Need LT1 A/C delete pulley...
- wtb a lower shifter boot
- Need tires, All kinds of gaskets, Aftermarket crank, pisotn rings
- 3rd gen Water Pump
- WTB: 93 - 02 Trans Am Spoiler and Firebird Mirrors
- wtb: stainless rear hoses new or used 4 lt1
- 95 Engine Harness
- SBC for sale? Anyone?
- 2 Weld 15x8 Prostars 5.5" Backspace
- body kit wanted!!! 93 camaro!!!!
- Spring isolators
- supercharger
- 93-97 SS Hood
- 91-92 145 gauge cluster
- WTB: LS1 Driveshaft
- WTB 350 shortblock
- 98-02 WS6 Front end
