NOS fuel pressure shut off
Just like the title says, if anyone has a fuel pressure shut off to use with nitrous that they want to sell let me know. Thanks in advance.
Re: NOS fuel pressure shut off
Now this is for an LT1...right. what is the max and min pressure. Don't get me wrong, I still want it, just want to make sure it's the right one. I can have the money done today, with paypal or something else, if it's the right one.
http://www.nitrousexpress.com/Images...ingDiagram.htm
Above is a link to the diagram for wiring the switch. This is the same one I have on my LT1, It is a NX wet kit w/ a shark nozzle. Below is all the info I could find on the switch. Give me a call. Thanks, Bok
EFI FUEL PRESSURE SAFETY SWITCHPN 15718 This “Next Generation” Safety switch is designed to protect your engine from a “lean” condition caused by low fuel pressure. It is pre-set at 35 psi however it is adjustable in a range of 25-60 PSI. To adjust, remove rubber plug form the top of switch. Insert the proper hex wrench, turn clockwise to increase set point, counterclockwise to decrease the setting. A pressure gauge (P/N 15512 0-100PSI ) must be used for accurate adjustments. The blue manifold should be directly attached to the fuel solenoid (no sealer is required on this A-N style fitting) with the fuel supply line attached to this manifold. The electrical diagram should be followed exactly for the proper operation of this devise. Note: Follow the wiring diagram exactly, this is a low amperage switch and is not designed to carry the full amp load of the solenoids.
Cool man, I'll take it. My address is:Chris White
29 Harrison Dr.
Hurlburt Field, FL. 32544
Let me know how you want to do the money, I have paypal that I use alot, so just let me know.
29 Harrison Dr.
Sorry it took so long to reply. I want the piece but with the uncertainty of products now a days, it's hard for me to send someone money and then wait for the product to show up. I have personally been burned and I try to make it a habit of only happening once. If there is anyother way to do this then let me know.
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
