View Full Version : Parts Wanted
- WTB: 355 or bigger LT1 Engine
- WTB new shifter boot 94 6spd
- Looking for cores
- Lookin 4 Hoods And Body Kits!!!!!1
- WTB:Stock 4th gen Harmonic Balancer
- wtb: thirdgen 10 bolt
- interior parts for 95 trans am
- Looking for good car cover
- #5 (rear) main cap...
- Dynomax Ultra Flow 3" Mufflers Wanted!!!
- WTT:Brand New T/A Rear End Girdle & Used GM 4:11
- WTB 12 bolt rear ASAP!
- WTB: LTCC ignition
- WTB Brakes
- WTB Driveshaft loop
- lt1 scanmaster
- VFN Trans Am Fiberglass ram air lift off hood
- WTB:: Clear or Smoked lid!!
- WTB : 1995-2002 16" T/A wheels in DFW area
- WTB: LT1 bellhousing
- WTT: transmissions
- LS1 driveshaft
- SLP COLD AIR and Flowmaster 80 series
- WTB: AIR Tube, Pass side Exhaust Manifold
- WTB: rear bucktes in ebony leather
- WTB ls1 brakes
- LS1 A-arm
- WTB - 17" OEM Wheels
- 1994 FBody Service manuals.
- 93-97 TA Front Bumper Cover
- Sub box
- WTD: Console Parts
- WTB:Two 15x10 Weld Prostar for 4th gen
- WTB: stock LT1 torque converter ASAP
- need borg-warner axle
- 96-97 Front Black Power D and P Seats
- fuel level sending unit
- WTB : SLP Ultra Z Hood
- ls1 short block and other thing
- LS1 caliper mount brackets
- HOOKER LT Headers and Y for 95 LT1
- wtb master cylinder
- Wanted: LT1 dipstick tube....
- LT1 T-56 Bellhousing
- WTT 400sbc for 4th gen rearend/rims in OR
- WTB Stock lug nuts and caps
- stock coil and ignition module bracket
- wtb
- Complete LT1 long-block
- 1LE Intake Elbow
- WTB: 4th gen F-Bird Doorpanels to Germany
- aftermarket lt4 style heads...
- WTB: Bilstein springs and antenna
- Looking to buy a rear end.......10-bolt, local if possible
- 3rd Gen Brake Handle...
- gears,lsd& whisper lid(v6)!!!
- WTB 1 02 Sim
- WTB:97 A4 Computer (PCM)
- WTB: Hooker Headers and Muffler
- WTB: LT1 Short Block or Bare Block in NJ/NY Metro Area
- wtb 6 speed lt1 flywheel
- wanted: LT4 composite valve covers/w hardware
- wanted 6 speed parts
- WTB: Oil Pump Drive Gear
- WTB: Trans Am seats
- Y Pipe, H Pipe or X Pipe
- I need a non-vented opti!!
- lt1 heads
- WTB: LT1 condensor and fuel rails
- It is almost xmas and it is time for toys
- WANTED: O2 Sims and extensions
- WTB - ebony kick panels
- In Need Of A 10 Bolt for F-BODY
- 4th Gen Rubber Jack Mounts
- wtb power seat switch for 93 Z
- WTB: ZR1 17x9.5 and 17x11 Wheels
- WTB: Rear Tail Light Panel (Black)
- WTB: Z28 SS floormats
- LT-1 heads/intake/cam, rockers cheap please
- looking for parts to finish my car
- Thirdgen 10 bolt
- Lt1 K&n Cai
- need to fill my xmas list early. lt1 stuff
- y pipe for hooker long tube headers
- Various interior parts
- Anyone got some heads?
- looking for a CAI, SLP, K&N, etc
- firebird foglight switch
- 35mm Front sway and SLP Pro Kit WANTED
- Stock keyless entry (just the remote)
- WTT: Mufflex Y for Hooker/JetHot Y (Longtubes)
- Power Window Motor
- camaro rims
- LT1 ac delete pulley
- WTB stock 4L60E
- IROC air filter box
- WTB stock LT1 cam
- wtb: 92-94 optispark
- WTB: GM High Tech Performance October 2002
- WANTED 96-97 SS Spoiler
- Wtb: Cc305
- pacesetter ory pipe
- WTB: LE ported heads or similar H/C
- WANTED!!!!LT1 shortblock 383 or 396
- Wanted: Eagle Alloy 077 18x8
- WTB: 93-97 Front Leather Seats
- WANTED! LS1 or 1LE alum driveshaft!
- WTB: LT4 valve cover trim kit
- I need 4th gen interior parts!
- WTB: Accel DFI Gen 6
- WTB: LT1 Rear Disc Brakes
- WTB: ACDelcos front O2 sensors
- WTB:LT1 Heads
- WTB: supercharger
- WTB: Painted 10 Spoke SS wheels w/ decent tires
- LT1 stock lifters
- wtb lt4 kncok module
- looking for k&n filter, #33-2037
- WTB: LT1 Intake Elbow
- WTB:58mm TB & 95 Opti Electrical Harness
- WTB Seat Belts
- wtb sensor
- WTB: Driver's side power mirror
- I need bigger injectors
- WTB: Hot cam springs
- WTB: Leather Seats and Shift Plate for 6 spd.
- 17x11 silver zr1s
- WTB 96-97 Mid length header setup
- WTB:Lt1 carb intake
- [WTB] 1997 LT-1 Aftermarket Parts
- looking for body parts
- 93-94 Driver's Side T-Top
- WTB 96+ timing cover
- WTB: Ebony LT1 Z28 6-speed console
- WTB: ProMag 7/16" NSA Rockers, Cold Air, Aluminum Intake Elbow, AFR Hydra Rev
- subthump box, v6 go fast toys, headers,exhaust
- Cold Air intake & Sunvisors WANTED
- Need M6 Torque arm bracket...
- Stock Exhaust Manifold Bolts
- alternator
- WTB LT1 Long Tubes and Y pipe
- Wanted SLP 2OTL tailpipes
- NEED door wire warness
- NEED: K&N sleeve for 93 SD cai....
- iroc dash pad
- looking for a ls1
- wtb: fourth gen rear
- LT1 Race Ready Short Block
- 98-02 Z28 or SS instrument cluster
- wtb: mocal pump
- WTB: DataMaster, Tunercat, or Equivlent
- I need pedals!!!
- 4l60e harness
- interior parts--cigg lighter plate, with the pwr hook up still on--
- need injectors
- Desperate Need...Seat Cover 2 tone Gray
- WTB: peformance suspension
- wtb: electric water pump
- New Wheels Needed Badly.
- Seatbelts
- Need a T-56 crossmember
- 315/35/17 tires
- WTB rear backing plates and calipers for 98+ rear
- wtb injectors
- wtb long lt hooker y pipe
- In need of a rear bumper
- Alternator bracket - not what you're thinking...
- WANTED: 3rd Gen Speedo/tach
- I Need Fog Lights For My 3rd Gen
- wtb: DANA 44 DANA 44 DANA 44
- Need: RH Arm for 96-02 Conv Top.
- wtb wide band O2's for lt1
- wanted 2 or 4 mint salad shooters
- Wanted Goodyear Eagle GSC 245/50/16 tires
- WTB-12 bolt for 4th gen
- w.t.b wireing harness 95 lt1 a4
- Car Parts
- Wtb 4l60e 95-96
- WTB motor matbe lt1 lt4 ls1 for swap v6
- WTB: K&N Filter for 96-97 WS6
- WTB two 17 X 11 black grand sport wheels
- WTB: 4TH Gen Interior for my 3RD GEN.
- WTB 5 point harness
- Wanted- Gear Drive for SB Chevy
- 58mm t-body
- 1992 Tpi Slp Cold Air Intake Setup
- WTB: 3.73 gears for 2 series carrier
- Need a driver side floor pan
- wtb- dual fan housing
- WTB: 93-96 t-56 Shifter Plate
- Wanted: LT1 aftermarket cam, springs, roller rockers, pushrods, lifters
- WTB 60-72 lb/hr injectors
- WTB:Right tail light smoke out
- I need LS1 fans!
- Wanted!
- Front Shock Mount
- 3.42 w/posi hub-to-hub North GA
- WTB Pair of silver WS6 wheels
- WTB 3" exhasut I pipe
- Sun visor for 95 z28
- slicks
- Firehawk Wheels
- 3.73 gears for 10 bolt 7.5
- want to buy 93+ Camaro Rims in So Cal
- WANTED-Decent used LT's for LT1
- I need camaro wheels!
- wanted good working 93 opti spark
- Buying LT1 blocks in central US.
- wtb -ebony trans-am /firebird door panels
- WTB blow off valve for n20 bottle
- Wanted: 95 LT1 long tube coated headers, and y pipe
- 66 chevy truck cab or front fenders
- WTB : 1LE Driveshaft!!
- need exhaust tips!!
- power or manual seat slider for driver seat 4th gen
- Need an opti
- 70 Camaro Duct Work and Vents
- WTB-Manifolds, y-pipe, t56 shifter
- wtb 2- 17" wheels
- FOG LIGHTS, SLP intake
- WTB 1.6 Crane Gold or GMPP roller rockers
- Wtb Worn Worn Worn Nitto Drags
- need obd1 outta 94-95 z28 or T/A
- Stock LT1 Short block wanted
- Stock 02 Camaro antenna mast
- Headlight mounting hardware for '95 Z
- WTB under dash panel Passenger side
- wtb 10 bolt housing
- bmr rear suspension
- 86 camaro dash pad
- WTB underdrive pulley
- Need black door panels
- WTB LT1 airfoil
- WTB WS6 TRANS AM WHEELS (96-02?) THE 17X9s
- looking for 95 t/a drivers fender
- oil press. sensor
- 700r4 valve body
- WTB: SS hood scoop grille
- WTB Black headliner
- WTB Rear Disc LS1 Backing Plates or Complete Set Up
- WTB: 93-97 fuel gauge sending unit/sensor
- WTB: 2 cheap borla tips...
- WTB: Chrome C6 Rims
- WTB: 00-02 e-brake assembly with EBONY leather wrap...
- Leather Interior!
- WTB guages and bottle heater
- wtb- trans am gauge bezel
- WTB: LT1 Fuel Rail Covers (Corvette)
- 97 camaro Leather pieces
