LT1 Race Ready Short Block
Re: LT1 Race Ready Short Block
I have a pretty nasty 383 LT1 motor for sale...
383 solid roller LT1 motor = This motor should make around 475rwhp. has a custom solid roller Cam Motions camshaft, Cloyes double-roller timing chain, B&M flexplate, ATI Super dampner, Callies 3.75 Dragonslayer fully forged crankshaft, Lunati 5.85 Pro Mod Rods, JE flat top forged nitrous pistons, Clevite H series main and rod bearings, Callies 4-bolt billet splayed main caps, ARP main studs and ARP rod bolts, Brand new freeze plugs and cam bearings. The block was hot tanked, bored and honed with plate, decked block, line bore, line hone, clearance for the stroker, rotating assembly is internally balanced, pistons and rods were honed, and everything is assembled. I have 1220 in machine work, a 800 crank, 630 rods, 500 pistons, 80 main studs, 19 cam bearings, 11 freeze plugs, 65.00 flexplate, 80.00 timing set, 400.00 super dampner, 110 main bearings, 110 rod bearings, 200 main caps, 400.00 custom ground cam.
So that is 4625 dollars in this shortblock. No expense was spared. I will let it go for 4000.00
This is a great street/strip motor that is going to go very fast in the right car. I have all receipts on this motor from parts to machine work.
I have pics available if you are interested.
Let me know
Let me know
F'n1996Z28SS
Aug 23, 2023 11:19 PM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
Decromin
Aug 18, 2002 10:11 AM
