View Full Version : Parts Wanted
- WTB T 56 shifter Cup
- looking for daytime running light module for 97ss
- 2 c6 wheels
- LT1 Catback Wanted
- intake manifold
- WTB CC503 or similer cam
- WTB: Stock Exhaust Manifold(s)
- Spohn spacer block for t56 to turbo 400 conversion
- WTB: Accessory bracket for LT1
- 93-97. Central console lead needed
- Stock rear springs
- WTB Stock LS-1 MAF
- Broken Dash Pad...
- LT1 Clutch slave cylinder
- Picture help..
- WTB: New or low miles stock lifter for '97 LT1
- 8 36lb or 42lb injectors bosch ford style
- Rear Wire harness for abs
- 96-97 LT1 timing cover
- WTB Rearend bump stops
- 58mm tb
- wtb rear axle for 95 TA no trac control
- WTB ZR1 wheels
- Wanted : Locking clips for spare tire trim
- WTB: Dash Panel
- WTB LCA Relocation Brackets (Bolt-On)
- Stock Flywheel
- C.A.T.S. OBDII Tuner
- 93-97 Camaro hood
- Need 4.10 gears for 2 series carrier
- WTB 97 Fuel Rail
- WTB: LT4 Hotcam Kit
- wtb mallory 685 box
- WTB rod for T56 slave cylinder
- gm 847 cam
- wtb flowmaster or magnaflow
- wtb cai and lt headers
- WTB/WTT 6.0 Connecting Rods
- power steering pump
- wtb cheap a4 trans
- 1978 Z28 Black Wheels
- WTB: Throttle cable bracket for 96-97 LT1 WITHOUT TCS
- WTB: quasar blue metallic hood
- ***4th gen LT1 Camaro tail-lights WTB***
- m6 center consule insert for 93-96 camaro
- wheels
- 95 z28 Black Door Panels
- Bose Drivers Side Speaker
- 94-97 LT1 Throttle Cable w/o TCS
- Looking for Short Sparkplug Socket
- Looking for BORLA pipe
- 98+ headlight adjustment bracket
- Exhuast hanger, Visors and more...
- I need a clutch for my 96 z28
- 3'' y-pipe no catts
- Programmer
- 94 4l60e Valve Body
- 98-02 Eibach Pro Kit Springs Wanted
- WTB LT1 blower cam/fuel/more!
- Front End Cover *Bra* for 1995 Z28
- Interior Parts
- Wtb lq4/lq9/5.3l or lsx
- Fuel Injectors
- WTB: x-pipe, other exhaust parts
- 10 bolt near SLC Utah?
- Factory monsoon headunit
- Stock lt1 cam cheap.
- Exhaust tips
- Used/Partial MSD LT1 Plug Wires
- has anyone seen..........?
- used LS1 Engine Block or Shortblock
- looking for some help wtb: hub or lug bolts
- LT1 Adjustable fuel pressure regulator.
- need a t56 cross member for a th400 swap
- Ash Tray Door Flap
- Wtb: Exhaust
- some m6 parts needed
- wtb ford 9 inch
- i need a m6 center console
- want - big sway bars for 95 w/ 9" rear
- Used Long Block for a LS1 Mod 1998 V8
- WTB: Looking for Someone Parting out a 6 Speed car
- WTB: (LS1) T56 trans
- WTB: 18'' tires
- WTB: low mileage factory 93-97 springs
- Wanted:ECM, injectors and your broken Opti.
- WTT: My Fastburn heads for an LT1 T56
- WTB driver side Fender 97 TA (maybe bumber cover too)
- Line lock
- shortblock needed fast!!!
- Need Stock intake
- 1997 owners manual
- stock plastic fuel lines
- alternator bracket
- 94 LT1 harness needed
- Ignition
- Wanted cold air intake!!
- wtb csr electric water pump
- WTB: Interior Door Panels, Seats *F & R* RED
- WTB: 97 Z28 150 mph Cluster
- Firebird Fender vents
- WTB stock lt1 motor mounts
- Need some stock LT1 CORVETTE Exhaust Manifolds
- McLeod Clutch Master Cylinder
- wtb Head-taillight covers
- Need 7 5/8' gear set.
- WTB LT1 Crank
- Looking for a dash and speaker cover
- Need CD or tape deck for 94-96 Camaro
- WTB 96-97 LT1 timing cover
- 95 lt1 stock ac delco plug wires
- wtb:arp engine bolts, 4bolt block, caddy lifters, timing chain, gaskets
- 1996 Replacement Headlights??
- WTB: LT1 Heads
- comp pro mag/guideplates/studs
- Front pair of drop springs
- looking for a complete black interior
- WTB: Hard fuel lines
- WTB: 98+ Firebird Headlight Surround/Bezels (DS & PS) As the title says, I need the
- wtb lt1 355/383 short block
- LT1 T56 Conversion
- Looking for a set of stock rear springs!
- OEM SS spoiler
- WTB GM847 Cam
- stock plastic ignition wire holder, dipstick
- Wtb reluctor ring for 3 ch abs
- WTB, Injectors, BIG
- wtb lt1 camaro rolling chassis
- Graphite 4th Gen T/A door panels
- Y-pipe for RK Sport mid-length headers
- SLP Dual/Dual catback
- Hop-up parts for 94 TA
- Factory radio / stereo for 1996 camaro
- WTB Driver's side T-Top (dot matrix) 4th gen
- Parts wanted 94 Camaro
- WTB: LS Whisper Lid
- WTB: Misc. Interior pieces
- shift boot and ring
- maf screen
- WTB Silver ZR1 Wheels
- LT1 T-56 bellhousing and clutch pedels
- 3.73 3.42 ring and pinion
- 2:73 limited slip gear set and carrier wanted
- NEEDED ASAP - front seats in good condition MD area or close
- SLP Tri-Y headers & Y pipe, single or dual
- wtb headers
- WTB LS6 intake
- stock shifter handle
- 3rd Gen T-top handle
- delteq opti-box
- Wtb: Red 93-97 tock camaro hood
- WTB-4L60 non-e..or 700 modded for 93z
- Complete M6 Swap for Lt1 Camaro
- Wanted Bose
- WTB--Hood release cable
- Need security light retainer in dash
- wtb: cc503 cam, 1.6 roller rockers, and valve springs
- WTB: Shifter boot with retainer ring
- WTB:2 17x9.5 ZR1 /SS rims in good mechanical condition paint condition doesnt matter.
- Crashed my 01 Z, need info. and many parts.
- Passengers side rear brake caliper (93-97 4th gen V8)
- NTB: MSD Rotor
- Ntb: Lt1 parts!
- WTB: Factory LT1 fuel sending unit, with or without working fuel pump.
- 93 - 97 transam bumper
- LS1 SFI Approved Flexplate
- WTB: LS1 front brake calipers
- WTB Piston
- Wtb: Lt1 cai
- WTB: White/Orange SS Emblems
- WTB Hid kit(s)
- needed good heater core 97 f body
- WTB 94-97 Axle shaft
- Looking for a complete LT1 Fast XFI setup.
- O2 sims needed
- wtb: Plastic gas tank from LS1 f-body
- LT1 front brake hoses/support brackets
- WTB 2-Centerline Autodrag
- wtb 42lb injectors
- 94 z28 waterpump
- OEM intake bolts, valve cover bolts, hardware ect...
- 94' Data Cable
- WTB: Intake elbow
- WTT:T56 for A4
- Need solid 4l60E for 1996
- WTB Tail Lights
- WTB: Gray sunvisors
- WTB: 97 LT1 Wiring Harness
- WTB: SILVER Zr1s with good tires
- WTB:L99/Accel TPI/LT1 intake base/1x 062 Vortec head
- WTB: Neutral(light tan) interior panels
- need an after market intake elbow
- Day running lamp module for a 98 firebird needed.
- o2 sims
- WTB/WTT 92-96 Corvette LT1 Fuel rail
- LT1/LS1 complete motor and trans
- WTB: LT1 Camaro T56 exhaust hanger
- Stock LT1/LS1 Lifters
- I need a stock LT1 block
- 94 4l60e
- I need tires 245/50/16s IN or MI
- scanmaster
- Stock 98+ SS Spoiler
- WTB: 4th gen 1LE or SLP level 2 springs, 35mm swaybar
- WTB: LT1 turbo friendly cam or Crane 2050 powermax cam # 104241
- wtb injectors
- Shifter Boot
- WTB:96 camaro console lid
- wheels
- wtb:stall for 700r4
- WTB pedals and hydraulics 4th gen T56
- Stock Fuel Rails
- WTB-96-97 Camaro SLP SS Hood
- Do you know this part number
- LF: Interior Stuff
- need stock/mild tc, manifolds/CARBheader, AIR pump system
- WTB air dam
- WTB: 96 LT1 Fuel pump assembly
- Wtb 98+ Ta Rolling Chassis Or T56 Conversion For Ls1
- WTB Axle shaft non traction control
- wtb long tube headers for 95 lt1 camaro/ hooker shorties f/s
- WTB SUb frame connectors 94 trans am
- Firebird Seat Wiring Harness
- WANTED: 1991-1992 z28 Hood (Just the Hood Not Blisters)
- Need 93 opti
- 4l60e
- WTB: LT1 Stall Converter
- WTB: 58mm Throttle Body
- WTB: LT4 Knock Module, T-top shades, Antenna, and more...
- Looking for 1997 Z28 Guage cluster
- Fog Lights 93-97 camaro
- Park Light/Signal Light Assembly for z28
- Cc306
- 4l60e Stock Converter 94
- LT1 Clutch
- Wtb T-trim Lt1
- WTB:LS1 Hurst Shift Knob
- WTB 94-97 Stock Exhaust
- Stealth Box
- WTB: Stock LT-1 Black Exhaust Tips
- WTB: small LT1 cam
- wtb 4l60e/possible six speed swap
- Fast xfu
- 6 speed console
- WTB: Misc Firebird/Trans Am LS1 Parts
- WTB 93 lt1 emissions equipment
- Need parts to make a 95 into an "personal SS"
- LT1 OEM exhaust bracket...
- Cleaned up bare stock heads LT1
- WTB 94/95 F car headers
