View Full Version : Parts Wanted
- WTB sun visors for ta (black)
- foglight, wheel, visor, other odds and ends
- t56 conversion for lt1 camaro
- Rear floor mats wanted - Med. Beige
- stock 24lb injectors
- need a laptop
- Adjustable panhard bar
- lt1 driver's side door
- K member for lt1 needed 4th gen
- WTB: Clutch release bearing t-56
- Passenger Side Mirror, Hatch Struts, and Factory Silver Camaro Hood
- Traction Parts Wanted
- Passenger Side T-Top
- Front Bumper Cover and Front Fenders
- Headers and Catback Exhaust
- WTB: 98+ Camaro front bumper (TX Preferred)
- WTD: 1997 Brake control Module
- Wanted: Procharger Pulley
- sealed beam HID conversion
- passenger side cat
- 95 Z28 emblems and leather seat
- Power steering rack and pump
- WTB: One (1) Pro Magnum Roller Rocker # 1318
- 95 z28 parts wanted
- tan sun visors
- Fog lamps, lt1
- IAC Needed
- need a 1997 Interior wiring harness
- 94/95 obd1 pcm
- Center caps
- Looking for stock dual cat y-pipe
- looking for a taillight harness for a 94 trans am
- Trade you my flywheel for yours!
- WTT Vented MSD Cap Rotor/GM Opti for...
- I need an LSX clutch that can hold 450hp / 500 tq
- Auburn posi parts
- 94 lt1 auto wiring harness
- WTB: (1) One SS Centercap
- NSA rollers...
- LT1 After market hood
- Wireset wanted!
- WTB:LT1 fuel injector
- WTB: 95 camaro shift boot and mounting ring
- Best place to get a SS Style hood, 97 Z?
- WTB T56 LT1 bellhousing
- WTB: 4" cowl hood for 93-97 camaro
- Looking for 383 parts..
- WTB SBC parts
- Upper strut mounts
- 24LB injectors.
- Fuel pressure Regulator
- WTB good running LT1 engine in Iowa or near
- WTB: 93-96 Firebird Center Console (Still looking)
- WTB- Driver's side rear quarterpanel.
- Dash pad for 96 camaro
- WTB: LT1 Fuel Injector Clips
- 85-92 foglight
- WTB: 95 Altenator
- WTT: t56, new clutch and master for built A4
- Z-28 Rims
- 1993-1997 camaro z28 front bumper
- hooker LT headers
- Full D1 procharger kit got LT1!!
- wtb maf screen
- WTB LT1 hooker y-pipe
- WTB: LT1 SS airbox
- WTB SBC 350 parts
- Console / shift knob
- Stock 96-97 Y-Pipe
- WTB Passenger side power mirror z28
- WTB LT1 Fuel Rail Cover (only one side)
- Need a LT1 engine wiring harness
- 93' bose
- Wanted V6 3800 headers
- I need a lt1 shortblock
- wtb dark grey door 93 camaro
- DRL Blinker Part / Number?
- Shifter cable, heat shields...
- rag joint
- OEM MAF Sensor Wanted!
- wtb Manual mirrors for 95' z28
- wtb ford 9 inch rear
- Wanted switch clip
- keyless entry pad for 96 camaro
- Maf
- Wanted 93-97 Camaro hood
- seat belts
- WTB: MAF screen
- WTB 93-97 WS6 hood
- 95 Camaro Z28 Parts Wanted
- trade my 1.6's for your 1.5's
- WTB Seats 93-01
- WTB or WTT: SLP loudmouth 2 bullet muffler
- WTB billet grille
- Wtb ss hood
- WTB 1998 camaro console lid
- 2 Center caps for ZR1s
- need a rear end please!
- Wtb. Lowering springs,cowl hood,any performance
- LT1 long tubes and y..
- stock F-body MAF broken or working!!!
- wanted :summit bucks or coupons that you wont use.
- Accessory Bracket and Front Marker Lenses
- Flywheel!
- 93 LT1 Fuel Rails ASAP
- Looking for nitrous stuff..
- wtb eibach pro kit
- WTB '96-'97 throttle cable bracket
- WTB '95 LT1 Cruise control cable
- 95 LT1 Serpentine complete or parts!!!!
- Shift knob
- WTB: chrome ZR1 wheel
- 93-95(96?) well kept interior.
- WTB: 93-97 Aftermarket camaro hood
- 52mm tb
- hardend Pushrods
- 95 z28 rearend
- 10 bolt for 4th gen
- WTB: 93-97 K-frame mounting bolts
- I need a posi unit
- 98-02 front end parts
- WTT/WTB: replica zr1's for SS rims
- Meziere LT1 water pump
- Graphite non t-top headliner
- Trunk Panel Brackets
- Firebird Dash Pad
- Firebird Graphite Door Panels
- 1997 LT1 4L60e Transmission
- w/p needed
- Weird odds & ends - for a '95 firebird
- WTB - 02 Extensions for 96 LT1
- 93-96 Black Leather Seats
- P1SC Procharger
- Looking for door and shiftplate courtesy lights for 1994 camaro z28
- ttop holder
- 3rd gen rearend NEEDED
- balancer hub
- WTB : T56 Torque Arm mount w/Hardware ASAP
- I need this braket???
- data cable
- Need Parts for Repair. 96 SS
- WTB: O2 simulators
- 94-97 Convertible top switch
- WTT: Loudmouth muffler for XR1, bullet muffler etc
- Grill Guard for a 97 F150/Expedition
- WTB: LT1 Fuel Rail and MAF
- WTB: T Top conversion kit
- WTB Stock flywheel
- Throttle cable from a non traction control car
- Wtb; 3.23 r&p
- 95 rear inner hatch trim panel
- Need A TTop Now!
- WTB: 94 firebird Cowl hood
- WTB: ECM for 1993 6-speed LT1
- WTB: Magnaflow Cat-Back
- Need to buy... Lt1 intake elbow, and all parts for big cam set up any performance
- Wtb 94-97 maf
- 1993 LT1 ECM for an automatic...
- WTB: Upper A-Arm Mounting Brackets - 4th gen f-body
- '98+ T/A/Formula OEM WS6 hood in Ohio
- WTB 17" or larger damaged wheels
- Console
- '98+ T/A front bumper cover in Ohio
- Turbo 383 Rotating Assembly
- WTB: F-Body MAF
- 1.6 Rockers
- NEED Part ASAP
- part needed ASAP BY SATURDAY 22 OF AUGUST
- WTB: ODB 2 Tuner for 96z
- Autotap Scanner?
- Lookin for a new LT1 255 IPH fuel pump and Fuel Pressure regulator
- wtb cassette holder from 94 console
- complete 10 bolt
- WTB msd pills 5100 5300 and 5500 ASAP
- Looking for a Catback
- Need more power
- LT4 Knock Module?
- NEED HELP-Need trans for 94 Camaro 3.4L V6
- 4th gen black seat belts
- Stock Lifters
- WTB One Chrome 10 Spoke SS Wheel
- wtb lt1 battery cables
- LT1 Kooks, LPP, FLP longtubes
- LT1 O2 Extensions
- 96-97 LT1 AIR Fittings and Valves
- Rear end - stock/low-performance/2.73 or similar - New Hampshire or MA
- Stock exhaust
- LT1 Balancer Hub
- Looking for some stock parts and mods
- empty nos bottle
- Wanted; 98 camaro stock cat needed
- 95 pcm
- Coolant reservoir for 95 camaro
- intake
- WTB lt1 stall converter
- Wanted: 6 Speed manual trans for 94 camaro z28
- Tail light wiring harness for 1997 Camaro SS
- Wanted: 98 - 02 MATCHING Taillights
- wanted: ls1 carb manifold
- LT1 Parts wanted
- TTop shades
- WTB: 10 bolt posi unit
- wtb front seats
- WTB: LT1 / T56 engine wiring harness.
- Gaskets,Bolts,STOCK CAM
- Happy hooker
- wtb fpr for 93 z28
- 4l60e
- hood
- WTB: 93-97 Camaro Header Panel
- WANTED: LT1 Clutch Fluid Cap
- WTB: gts smoked driving light covers
- Wanted: driver's side rear side marker
- WTB - 02 Sensors & Extensions and Firebird Clear Corners
- 95 camaro upper dash
- Snow Tires / Wheels near chicago for 98 Camaro
- LS1 spare tire
- Need Camaro Hood/Bumper Coverfor Friend
- WTB: Stock LT1 injectors
- 94 z28....oem optispark
- WTB Silver ZR1 wheels
- WTB: 93-96 Camaro Window Switch Bezels
- 99+ Ls1 harness perferably A4 but dont care
- some ls1 parts needed
- 96 fan and ac
- wires/ and plugs wanted
- red top injectors, LT1 7qt oil pan, LT1 K&N CAI, and LT1 COMP CAMS roller rockers
- LT ORY Y-Pipe needed
- WTB LT1 Longblock
- 4th gen suspension parts wanted..
- WTB center console bucket that goes near the ashtray
- 02 Sensors and Extensions
- wtb red 93-97 front bumper
- Wanted 95 Formula Tail Lights
- WTB: MAS screen
- Lt1 pulley
- bilstien struts front
- WTB: pigtail for LT1 oil pressure sending unit.
- 93-96 Gray Sun Visors
- Wtb: 1995 lt1 pcm.
- WTB LT1 AIR pump hose
- Need radiator/bought one from here and it was sh**
- Lt1 BBK underdrive pulley and 96 lt1 tensioner.
- t56 and some other parts
- LT-1 stock fog light switch???
- WTB gm847 and 918 springs
- need a tranny for my 95 a4
- 96 stock y-pipes
- Stock Y pipe
