WTB: water pump coupler, crank sensor, timing cover...
Wanted:
LT1 Water pump drive coupler (attaches the water pump drive shaft to the water pump).
Passenger side LT1 motor mount bracket (not the mount itself, but the bracket that goes between the mount and engine)
either a '95 timing cover
-or-
crank position sensor and bolt for '96-97 timing cover (doesn't need to work, just needs to seal the hole)
-or-
Wanted:
-or-
-or-
Did you see my thread with the other parts?
I'm honestly not sure what mount/bracket you need but I've got BOTH sides, driver AND passenger side - both of which bolt directly to the block.
http://web.camaross.com/forums/showthread.php?t=475104
See this thread for the mount and the timing cover...
http://web.camaross.com/forums/showthread.php?t=480689
See this thread (post #2) for the other mount...
Wanted:
-or-
-or-
http://community.webshots.com/user/solid95z
