View Full Version : Parts Wanted
- parking brake ?
- WTB: 1 2002 WS6 wheel, or 4 of any 17x9 wheel
- T56 Inspection Cover
- WTB: Lt headers
- WTB 93-97 drivers side t-top
- WTB Fuel Pump Bucket
- WTB: exhaust and intake system
- K member, torque arm
- WTB: 98 or 99 air baffle/silencer (between OE lid and MAF)
- LT headers
- WTB: Center Console lid for '00 Z28
- MAF Translator
- WTB: LT1 Throttle Cable Cover
- WTB: Slp intake and exhaust and gm maf
- 94 Lt1 auto engine harness
- Stealthbox, subs and speakers
- WTB: from vendor brand new injectors
- Wtb 94 Z28 stock Bose Speakers
- gm 10128334 water pump coupler
- WTB: T56. I got robbed!
- 93-95 Camaro Crank Hub
- WTB: 93-97 Camaro front bumper cover and t-top headliner
- WTB: Tan sunvisors
- Lt1 parts
- looking for LT1 Alternator and Power Steering Relocation Kit
- WTB: 96-97 LT1 Timing Cover
- Ohio: LT1 Factory Exhaust Manifolds and Y-Pipe
- WTB rear bumper cover and sunvisor's
- Oil pan, M6 console, LT1 engine? for 94 z28 camaro
- wtb mass airflow
- Aluminum driveshaft other than LS1 or 1LE
- 94 T/A Fog Light
- LT1 Oil Pump Drive
- WTB: factory programmed 96 PCM for an M6 car, with no speed limiter
- WTB: SLP LT4 Exhaust Manifolds
- 1998 Trans Am guage cluster
- WTB: ATI hub ONLY
- WTB LT1 crank and con rods
- WTB 1LE intake elbow (for vented opti)
- WTB: LT1 WS6 complete airbox assembly
- WTB: 93-97 Trans-Am front bumper cover
- WTB: T56 conversion kit
- WTB: TORQUE ARM for lt1
- WTB: lt1 throw out (release) bearing
- WTB: 2pc rms external balance t56 flywheel (383, 400, 454)
- WTB LT1 Water Pump Drive Coupler
- LT1 Power Steering System
- WTB: Exhaust system for 94 z28
- WTB: Drive side wheel hub
- WTB 68 chevelle rear coilovers
- Need leather seats!!!!
- WTB: LS1 Lower Steering Shaft.
- 1970 Z28 LT1 Engine Parts
- Kirk
- ls1 oil pan
- WTB LT1 alu heads
- 1 ROH ZS 17x9.5"
- WTB: stock 94 Camaro interior parts
- WTB: '98 or '99 1LE/WS6/SS parts
- WTB: stock lt1 fuel injectors, vent fins, m6 center console parts
- WTB: Parts For My 98 SS
- M5 trans for 2001 Camaro V6 3.8 needed
- 10 bolt rear end girdle/brace
- 95 z28 convertible parts wanted
- WTB Chrome 17x9.5 ZR1
- need good condition trans for 94 z28
- WTB: Stock/OEM LT1 Camshaft
- WTB: 1996-1997 Camaro SS intake
- 01 SS Plastic(T-Tops)
- 93-94 optispark driveshaft
- WTB 1994 Camaro Z28 (6speed) Full Body Harness
- 99 Camaro tail lights
- 1996 z28 parts wanted
- Exhaust hanger
- 68 396 4 sale
- 94 or 95 LT1 HARNESS
- WTB FACTORY LT1 Dipstick and Tube.
- 96-97 Crank Hub and Balancer
- driver side lower control arm
- wtb 1995/6 camaro/trans am parts
- Lighter bezel
- Black 4th gen carpet
- 1970-1978 Camaro Parts needed!!
- looking for a built t56. 1994 lt1 camaro
- wtb 700r4/4l60
- want: 1.6 roller rockers 3/8 stud or with 7/16 studs together
- Wtb full set of seats and center console
- WTB Ground Effects.
- WTB OEM 20" wheels and tires
- Wanted!! Wanted!! Need parts for my plymouth!
- wtb: torque arm
- WTB: SLP LT1 Smog-Legal Headers
- supercharger discharge pipe/tube
- WTB: 93-97 Formula/Trans Am RH taillight
- LT1 headers Mids or Shortys
- Wanted: '01 - '02 Camaro LS1 PCM - GM# 12200411 and mounting bracket ...
- Need Complete Set of LQ9 Coils
- Wanted: '96-'97 LT1 Timing Cover & Hub
- WTB: 96 t/a wiring harness, abs module, panhard bar , and lt1 backing plates!
- WTB- Longtubes w/o EGR & AIR
- WTB: 5/16 7.150 pushrods
- 1996-97 OBDII Knock Sensor
- WTB TPI ported runners and LTs
- WTB 1997 3.8 camaro oil filler cap
- WTB: 98-02 Driver Side Exhaust Hanger
- WTB:1999 Camaro V6 catalytic converter
- Glove Box Latch & other interior
- SLP 2OTL Intermediate Pipe
- ls1 intake bolts!!
- WTB: 1996 lt1 parts
- WTB: LS6 Intake
- 17 or 18 inch wheels and tires
- Want to buy or trade. Looking for powerdyne or other S/C
- HELP!!! BBC intake manifold
- WTB C-5 front disk brake conversion/parts
- WTB 12-bolt with 3.73's
- WTB Procharger D1SC or Vortech si tuner kit
- WTB... T-Top pieces (2x at front and rear)
- WTB lt1 t56 drivetrain + other parts NNJ
- 96-97 LT1 OBDII Knock Sensor
- WTB VFN 3 inch SS Hood
- WTB: 95 Z28 Fog Lights
- WTB: LT1 waterpump
- WTB LQ4/9 bare block
- LT4 knock sensor to work with 95 T/A
- WTB: Front Bumper Cover
- Alternator bracket bolts
- lt1 centerbolt valve covers
- 1993 Fuel Tank Unti Harness
- In severe need of an ls1 alternator bracket
- Computer
- WTB:93-02 Trans Am Leather Seats
- Z28 camshaft
- 93-97 Rear bumper cover stud plates
- WTB: Tan/Neutral T-Top Shades
- WTB: LS1 Accessories for a 5.3 Swap & LS1 Intake
- WTB: 98-02 camaro taillight harness
- wtb: 93 z28 catback system
- Ebony Leather door panels and Trans Am Seat Control
- Wtb stock low mileage cam
- WTB Alarm shock sensor 96 Z28
- 95 camaro m6 leather boot frame
- 91 92 camaro door pannels black with power window option
- WTB: Drive shaft loop
- LT-1 Computer 1994 Needed
- wanted middle section 1994 convertible top boot
- WTB: 93-97 Fuel Sending Unit Assembly and/or Gas Tank
- WTB: Headers
- t56 hydraulics and clutch fork needed!
- needed: built t56. 1994 lt1 camaro
- Need a set of 15" rally wheels ASAP
- WTB: 94+ fuel rail and Aluminum heads
- WTB Ignition coil and ICM for 96-97 LT1
- WTB: Cam kit LT1
- WTB OEM IROC Z RIMS - Detroit Area
- WTB: 96-97 OBD2 Knock Sensor & Dipstick Tube
- WTB:LT1 auto trans dust shield / DS loop / Plug wires / Helmet
- 1969 Camaro Z28 B.U. Coded rear end
- WTB 1997 medium grey camaro seats or upholstery that has 30th anniv. on headrest
- WTB: your old Lt1 air intake
- Eibach pro kit rear springs
- 1994 6 Speed Engine Harness
- 2002 Camaro parts wanted
- WTB 1.6 Roller Rockers 3/8
- 1996 - 1997 SLP OEM SS Hood
- Wtb/wtt
- 8.5 posi rear
- Stupid part wanted
- z 28 cosmetic parts
- Dash top
- WTB: 60lbs injectors for tpi
- WTB: Beehive or Patriot springs and 1.6 self aligning rockers
- WTB: March Pulley kit, 30# injectors, LT1 timing set
- Wanted:LT1 Fbody water pump
- wanted: stock cam from LT1
- wtb 93-96 gauge cluster lens
- WTB 4.030 forged pistons and i beams and some hardware
- WANTED: NSA 3/8 1.6 LT1 Roller Rockers
- Looking for some LT pacesetters with emissions
- DELTEQ Coil jumper, used in 92-95 LT1's
- 1995 Z28 Emblems Needed
- WTB: 1994 Wiring Harness.
- WTB Lt1 23X / 23X Duration
- Wanted opti. Cheap!
- wtb: dip stick tube for 4l60e
- WTB: LT1 ABS motor/proportioning valve
- WTB PROCHARGER for LS 5.3
- WANTED NOS 302 Pistons
- Wtb: rear caliper
- AMP Rack
- 2011 DOME LENS COVER h e l p
- WTB STOCK 96 LT1 Muffler with LT1 tips Alabama-
- wtb a/c delete pulley
- CC306 wanted
- LT1 blower cam ~230/242 @ .050, .585"/.600" 114 LSA-HR
- Drivers Side Stealth Sub Box
- WTB 1 16x8 chrome 1997 camaro rim
- WTB: LT1 Trans Am passenger tail lights or a set of 98 and up tail lights
- in need of an ss hood and 4l60e transmission
- 1996 or 1997 SS oem hood (red)
- WTB: LT1/4 corvette offset oil filter adaptor 10215675
- LT4 Knock Module
- WTB clock spring
- 1.6 rockers and valve springs
- WTB lt1 adjustable master cylinder
- WTB: Part #12177553 Trans Am Seat/Air harness
- WTB good used LT1 oil pan
- 95 firebird m6 shift boot and ring
- Side View Mirror - 95 Camaro
- wtb a pair of 17 inch vette wagon wheels
- 98-02 Trans Am driver seat controls
- WTB: Throttle cable, 97 without TCS
- WTB: LTCC setup
- Link bow#1 L and #2 R 96 Camaro Conv Z28
- WTB: posi rear end, 3.23 or 3.42 (maybe 3.73)
- wtb: Mass Air Flow
- Sun visors
- Wanted: LS6 Intake & SS spoiler.
- WTB Black BMR tubular K
- need a good stock lt1 crank
- lt1 ss hood
- wanted: exhaust, cutouts, wires, etc
- Stock chrome Or polished exhaust tips
- Borla Adj FULL BLOCK OFF PLATE wanted
- Air injection hose and cat conv hanger
- WTB--Pressure Plate Bolts
- Underhood Chome Polished LT1 Goodies
- need lt1 f-body accessory bracket
- WTB Set of Z06 or ZR1 wheels for my 95z
- Need a passenger rear tailight assembly & door lock switch for 94 Formula
- 145 mph instrument cluster for 92 camaro
- PCM Bracket
- WTB: 1994 M6 leather shift knob
- WTB Hurst Short Throw Shifter
- WTB-LT1 EWP, 1.6 rockers ect
- 69 Original Dash pad
- front end conversion trade?
- Need 96 or newer Ac Delco opti
- Rubber intake elbow/ducting
- Need a ten bolt rear end
- Wiper Motor Cover
- 95 formula fuel pump bucket
- Looking For 93 - 96 Camaro Upper Dash Panel
- intake boot
- wtb 32/19mm sway bars
- Springs
- wtb mcleod lt1 t56 bellhousing
- WTB 1997 3.8 long block that is rebuildable!!!!
- 3.73 Posi
- Looking for 88-92 V8 WC T5 for parts
