View Full Version : Parts Wanted
- tpi for 3rd gen
- wtb: headers and gears
- WTB: Shaner or Bo White TB
- Need factory LT1 lifter
- WTB LT4 Knock Module!!
- Looking for a set of headers
- WTB any thirdgen brake upgrade
- I need a lower front coil spring seat.
- WTB: Body Control Module 94 Firebird LT1
- wtb used cats
- WTB: LT1 oil pan
- Need early 6 speed 4th gen console.
- T-Trim Vortech
- Wanted:Programmer and headers
- WTB: 5 spoke rims
- NEED: fuel lines and brake line
- WTB LS6 intake
- WTB: crank 3.75stroke,5.7crod
- WTB BCM new or pellet value 11.8k ohm
- Wtb Two Tone Grey 94 Camaro Front Seats
- WTB: LT1 Lifters, hardened pushrods, guideplates
- LT1 spark plug router
- Dash pad 93-96 camaro(top piece along windshield)
- Where can I find? (LT1 question)
- Looking for 96' Z28 Parts
- Stock bushings for susp. 94 Formula M6
- le 2- le3- or le4 cam wanted!!!
- Fuse panel cover
- Fan switch for 93 Camaro Z28
- passenger side front door molding
- 93-02 Center Console (m6)
- quasar blue parts wanted, hood rear bumper.....
- Trans Am/Firebird driver side taillight needed
- SLP Muffler, # 31020 SS Replacement w/3" Inlet, 2 X 2.5" Outlet
- WTB: OBD 1 LT1 PCM and '95 timing cover
- 96-97 WS6 hod..
- WTB Lt1 Heads
- stuff needed immidiatley
- Wtb: Lt1 Edit!!!
- 1.6 valve covers
- 17x11 ZR1 wheels
- WTB: large AFR LT1's and 4 bolt LT1 block
- trade- eibach springs for stock springs
- Lt1 motor
- Grey or black carpet
- WTB: ported intake for LT1
- 35th Anny Wheel
- C clips for injector plugs
- Need stock roller 305 engine near LA
- WTB: LT1 OEM SS hood.....
- WTB VIN Locked Hypertech Programmers
- 4L60E Filter Seal
- 97+ camaro tail light
- Cluster Bezel... 97-02 Firebird..
- WTB: Trans Am 3rd Brake Light
- Some Lt1 parts I want to buy
- WTB: new front license plate bracket
- 93-97 lt1 K member
- caliper
- T56/AC Parts needed (slave cylinder spacer,rear compressor bracket)
- looking 4 a 98 and camaro aftermarket hood
- ls1 spindles
- WTB: Cam, Rockers, suspension, ect. LT1
- Need MISC LT1 Parts
- shift plate for a 94 auto
- NEED sbc headers
- WTB 98-02 radiator shroud
- WTB: LT1 Stuff
- Forged Crank 3.480
- supercharger
- WTB: Magnaflow catback/y pipe + lid for '99 LS1
- WTB: shifter boot
- i want maf sensors
- procharger d1sc or magnacharger LSX
- WTB SS 10-spoke rims
- I need seats
- WTB: 93-96 firebird shift boot or full 97+ center console
- WTB L98 Heads
- fORD STERRING COLUMN 1995
- WTB: Stock Injectors
- WTB: LS1 brake conversion
- WTT: 1.6s for TB
- WTT: 98-02 TA Honeycomb tailights
- WTB: 93-96 TA foglights
- WTB: LT1 Transmission Parts
- Need some parts ASAP!!
- WTB: Supercharger
- Anyone Parting out a car
- pully system
- 96-97 LT1 SS spoiler
- WTB: shifter boot
- 93-97 rear end brake backing plates
- camaro seats
- WTB CME valence
- 95-99 chevy cavalier cdplayer
- 95-97 lt1 vented optispark
- WTB LS1 lid,rad. support, hardware
- Need rear spring spacers!
- sway bars
- WTB: Ford AOD
- Stock ls1 seats, retainers, and locks
- WTB: 1.6 S/A 3/8 roller rockers
- Need Camaro dash Pad
- LT1 Exhaust Manifolds
- Need Some Bolts
- 93 Z-28 A/C Compressor
- rear "camaro" panel. (for berger panel)
- Grey trans am steering wheel
- Aftermarket heads....58+cc 210cc+
- WTB: Sportline Springs
- WTT 17x9.5 for 17x11's
- WTB - GM 1LE A/C Delete Pulley
- WTB: Adjustable Torque Arm - 3rd Gen.
- Need 97 Ss Hood Shock
- **WANTED** SLP CME w/valance
- Need:Water neck,Gauges,injectors,alt and more
- Wanted: Aftermarket hood for 94Z28, NC or SC...
- Kumho Ecsta MX's
- Looking for Long tubes for my 95 lt1
- bellhousing for a 3.4 v6 with a 5 speed
- WTB Timing chain cover for the LT1
- WTB: Aftermarket Rear susp.
- WTB: MSD Digital6 box and/or coil
- wtb center spoiler peice
- WTT....tails
- WTB: 1995 Firehawk or Comp T/A speedline rims
- Need wire from coil to opti
- WTB: LS1 front brakes for my LT1
- WTB: 4 bolt LT1 block and T-56 parts
- WTB: Complete LT1 & 4L60E shipped to Florida 33460
- T56 Parts Needed (rubber Boot,clutch Hydraulics,aftermarket Clutch)
- Need a gutted stock water pump for LT1
- WTB: OBDII TunerCats Software
- WANTED** hurst shifter knob
- Can anyone Fax over the instructions that come with the LTCC because i lost mine!!!
- WTB: Bumper Cover and Fenders (93-97 Camaro)
- 52mm TB, Trickflow elbow, and LS1 Coils
- WTB 93-97 T56 torque arm bracket
- 790 hoosier tires
- WTB 98-02 Ebony/Black Center Console
- WTB:Clear Sidemarker Lenses(rear)
- Hurst Shifter
- WTB Fender for 98+ Camaro
- WTB 1996 rs front lower spoiler
- wtb: 30 to 36 lbs injectors for LT1(8) (new)
- WTB: Mallory IV 685
- need rims for 02 firebird quick!
- Wtb: Lt1
- I need a new set(8)of stock OEM AC Delco GM Spark plug wires for a 95 LT1!
- long tubes
- wtb/wtt exhaust setup...LT1 stuff
- WTB LT4 Hot Cam
- Drivers side window switch pod
- 1995 Z28 headers
- WTB Busted T56
- WANTED- LS1 Brake Master Cylinder
- WTB 2 Silver ZR-1 Rims
- WTB: DMS front lowering spings
- 95 camaro dash pad
- WTB GM graphite head gaskets
- lt1 ignition, skinnies, etc.
- WTB-6spd console-black
- 83 Camaro Wiring Diagrams Wanted Or Service Manual Wanted
- WTB: MAF for LT1 and Driver's side Window Motor
- WTB: 3" Electric Cutout
- Need passenger taillight for 95 ta.
- manual pedals
- lt1 accesory bracket
- Fluidampr or any balancer with keyed hub
- Looking for rear view mirror
- WTB Front fender wells & front plastic panels
- Need a 96 LT1 ignition module!
- WTB; 94 camaro tail lights.
- WTB: Jamex lowering springs 93-97 Z28
- posi unit for a 3 series carrier, mines getting weak.
- wtb 93 lt1 stock throttle body (or 52mm aftermarket if its cheap!)
- WTB ORY for Pacesetters
- WTB: 5 spoke chrome rims
- WTB - 16" Chrome 5 spoke Trans Am / Firebird Wheels
- need dash,front clip,other lt1 parts please look
- Looking for LT1 Vortech brackets
- 97 Tan front seat belts
- Need a 96 LT1 (6-speed) engine harness. whree can I get one?
- Wiring harness for Candian 94/95 TA
- T56 Inspection Cover
- Will Work For Parts
- Rear exhaust hangers, 93-96 TA exhaust tips, 1LE or WS6 rear springs
- WTB:Electric 3" exhaust cutout
- wtb flywheel to put a t56 behind gen 1
- Looking for the Following parts
- WTB: Good used rear end (Moser or 9" etc. ) for 82 Z28 4.10's
- WTB 93-94 Dash Firebird/TA Graphite
- WTB: LT1 long tubes
- looking for some valvetrain parts
- NEED A CYLINDER HEAD or heads
- WTB LT1 1.6RRs and Valve Springs
- WTB 17" ZR1 ss chrome rims
- WTB LT1, LS1, GTP Injectors
- WTB: Aluminum D/S+3.42 or 3.23 posi/disc for my 95v6
- Wtb: Used Or New Good Working Order Lt4 Starter!!!
- Firebird Vent
- Wtb Maf
- WTB shift light
- Z28 Aluminum Pedals.....
- WTB: Trans Pan, PS pump
- ls1 4.8 5.3 6.0 parts
- Interior pieces
- WTB undercarriage parts...
- fuel level sending unit 93-97 LT1
- WTB 295/30/18 series Tires......
- C6 Rims
- T56
- WTB: 93-97 door panels with electric windows
- WTB 94-97 camaro bumper cover
- Want to buy 42# or higher injectors
- wanted lt4 carb intake
- WTB: stock lt1 flywheel in good shape
- crank hub
- wtb ls1 roller rockers
- 97 ss rag top ground effects
- WTB: LT1 4L60E Stall Converter
- Ls6 Intake!
- Need Headliner
- WTB: 10-bolt rear-end girdle
- {SC} WTB: One LS1 rear disc backing plate
- WTB: Z28 Floormats
- WTB 98-02 LS1 Calipers and Mounting Brackets
- 98-02 sonoco hood and rsk (dick harell) spoiler
- 58mm Throttle Body
- WTB 3" Exhaust
- need lt1 engine or ls1 with wiring harness and computer
- WTB 4L60E tailshaft and vss
- headers
- LT1 engine
- WTB: Polo Green passenger door from Firebird/Formula/TA
- WTB Heads cross-over pipe!
- WTB 16" 5 Spokes
- aluminum engine block
- WTB 98-02 SS Wing
- WTB: 7" LT1 Vortech Crank Pulley
- WTB stock rims
- WTB: LS1 pullout with trans
- WTB: fresh th350 and converter
- WTB Front 16" Z28 Rim
- LT1 Procharger
- WTB 30# Injectors
- WTB wheels and tires anywhere close to Missouri.
