View Poll Results: LPE or Stage II
LPE 211/219
22.22%
Elliot Portworks Stage II
14
77.78%
Voters: 18. You may not vote on this poll
LPE 211/219 or Portworks Stage II
Close enough? So it's okay for you to make generalizations about what I post? Get real. I'm sure you're hooptie runs fine - I've never criticized your car. If you're satisfied with the results of your cam swap, more power to ya. Have you ever backed up the dyno number? Does the trap speed support the dyno number, both before and after?
I have always questioned the credibility and given props where it is due. Did you not read what I posted? You do not need to be an expert to challenge an expert to prove his method or knowledge. I never said you worshipped anybody, but the vieled advertisement in your sig says otherwise. BTW, it doesn't take a rocket scientist to see what went wrong in some of these guy's cars when the valvetrain came apart - the cam was put on a cam doctor, compared to the cam card, compared to the parts recommended by Camshaft Heaven, calls to Comp about their recommendation, which all pointed to mis-application of the products. It's that simple.
I may, and I'd love to see you there too! You bringing a car to line up?
When you claimed that only 2 LE cars run well then your saying those 2 are a fluke...no generalization needed. I criticize you because you and your long lost SS brother make comments about all the LE cars that run low 12's at 110-114...when neither have performed better yourselves. Its not to sound rude but to make the point. There isn't a 100% recipe to make something run hard....if it was that easy everyone would be doing it. Last I knew the majority of the bolt on LT1's were running what low to mid 13's@ 103-107...add a cam/ported heads to that and pick up 60-120 hp. If traction, DA, etc can all be equalized that would be about 6-12 mph picked up from the H/C setup on a normal street driven car. Maybe I'm in the minority here but the math seems to add up on paper for me....so how doesn't it make sense on the intraweb? After that gain its entirely up the the car owner to make changes to improve 60ft, aerodynamics, weight, driver skill, etc to make it faster and get down the track better. If i am wrong about the bolt on times LT1 cars run, anyone feel free to specify better...but last i looked those times looked normal.
The week after i picked up the car I went to the track, and with the same crappy 60ft as before I picked up 3 tenths and 6mph...it was however alot hotter that day. All things being compared I was satisfied.
The designer of the cam is in my sig your correct, just like everyone else that wants to post up they have an FMS F14 or Vengeance vindicator etc... You can't just state it doesn't take rocket science to figure out what goes wrong with peoples cars...because anyone can mess anything up its that simple. I have seen some of the smartest people in the world make dumb mistakes. I see valvetrains come apart more by taking advise from Comp just because of the lobes used, when thats not the only thing to take into consideration...thats generic information and if setup the way it was spec'd to I have confidence that it will work and last. Its been done, and I have seen it. I honestly could care less what YOU call wrong, or deem junk(as you stated about the LE setup on Javiers car...and that is what you said)I am happy with my choice, and I'm sure Bret Bauer isn't the only one that could have given me what i asked for when it comes to cam choice. I went to him because I am local and have seen his work, and as far as I am concerned I don't question his knowledge. If find it funny that the way it seems there is only room for Big names in the industry, and because You don't understand the way he does things doesn't mean he's wrong. Above all you turned this into a Bret bashing thread when it started as a simple question of whether or not the LE2 setup comes with rockers or not. You think maybe you jumped the gun?
I will not be bringing a car there, honestly I have no interest in building an LT1 engine to be perfectly honest. I enjoy racing and watching racing and thats why i'm going!
And whether I jumped the gun or not isn't even relevant....the original question was between LPE211/219 or LE2. The rocker question was secondary. I also believe I clarified the 'junk' comment - it was not meant to be offensive. I call my junk 'junk' and I think Javier understands this clearly.
I think we'll just have to agree to disagree about the 'BRE way'.
I enjoy racing too
You're correct - there are many things that can 'go wrong' with anybody's set-up, it even happens to the 'big names' occasionally. Nobody here is infallible, but there is a known range certain cams fall into, and for the most part, their behavior can be predicted for a given application. The only way this turned into a bash is that I believe that there is no correlation between what Lingenfelter would give you and what BRE would give you - their knowledge base isn't even compariable. We're comparing real-world R&D costing millions versus a young guy using a laptop program and profiting from his 'real-world' testing and failures at others' expense. You choose your route; I'll choose mine.
Correct, I have absolutely nothing with an LTx engine anymore.
Lingenfelter has done alot of R&D and perhaps one of the pioneers to this game...but that doesn't mean that new technology won't be better. I also know that Bret doesn't rely soley on a laptop program, or let others be guinea pigs for things he wants to try. In the same aspect, Bret sets things up different ways then the norm...and it works well for him and the majority of his customers which does not include you or the other people that blindly bash him because he thinks outside the box.
Are you naive enough to believe that a customer calls Bret for a cam and he just sends them some magical prototype and charges them for it? No hes not some huge company that can afford to have multiple vehicles to test parts on. He has had plenty of customers that would love to buy into his theories because he has proven to have the knowledge...instead he works a deal with them where they get the parts at cost and try them out. That alone is valuable R&D but you won't read about it every time his name gets mentioned here. How about Comp cams, do you think they test every cam in the library to get direct comparisons? Do you think when you call them, they dont use some sort of computer program to help choose a cam?
I haven't seen a whole lot of any cars run the same ET's much less MPH as I have with a comperable LE package in a full weight M6 car. As soon as I do then I'll like it. Until then...
this would be much more informative if the mud tossin would stop.
there is proof that LE/Brett combos work,LPE has worked long before the Lt1 and will continue,AI combos work! It comes down to who you feel most comfortable with some really dig the CNC ported package some like the old school way of porting.is this really a reason to bash the suppliers of performance orientated parts that they create,i would have to say NO!
To each his own.....
Other than Clint and Javier heres a few more.........................
https://www.camaroz28.com/forums/sho...d.php?t=507694
bottom of page 1
https://www.camaroz28.com/forums/sho...d.php?t=494689
top of page 3
https://www.camaroz28.com/forums/sho...d.php?t=466976
https://www.camaroz28.com/forums/sho...d.php?t=556348
Goto page 9 and start reading to refresh your memory
https://www.camaroz28.com/forums/sho...d.php?t=532211
Oh and I passed the Ontario sniffer test with no problems too
bottom of page 1
top of page 3
then again i just got home from the bar w/ the wifey.. so what the hell do I know.
