LE3 track times
Old Aug 16, 2006 | 11:11 PM
Black6spdZ's Avatar
LE3 track times
Well i just got back from the track, best she did tonight was 12.1 at 120.2 mph in a full weight t-top car. This was the first time to the rack with it so there is still a lot more in it i think.
Mods
383
LE3 heads
LE4 cam
ported intake
csr wp
lt headers w true duals
spec stage4
4.10 gears
toyo street tires
srp pistons
eagle h beams
eagle forged crank
fullly balanced
canton pan w/ HV pump
full bolt ons.
Scott
Old Aug 16, 2006 | 11:38 PM
streetrod93's Avatar
Re: LE3 track times
very nice times, esspecially with street tires.......very impressive
something sticky and some seriouse tuning, you'll be DEEP into the 11's with no trouble
Zigroid's Avatar
Re: LE3 track times
Mods
383
LE3 heads
LE4 cam
ported intake
csr wp
spec stage4
4.10 gears
toyo street tires
srp pistons
eagle h beams
eagle forged crank
fullly balanced
full bolt ons.
Scott
AWESOME. makes me wish I could have seen what my car had the potential to do...
Old Aug 16, 2006 | 11:50 PM
Formula_driva's Avatar
Re: LE3 track times
mediocre times...nice MPH
Old Aug 17, 2006 | 06:49 AM
METALBEAST's Avatar
Re: LE3 track times
Congrats! What was the DA at the track?
Old Aug 17, 2006 | 07:06 AM
Black6spdZ's Avatar
Re: LE3 track times
i still just have a mail order tune and straight 30w oil in it as well. I am also going to try to get a little weight out of the car somewhere. I am going to dyno it in the next few days so i will be able to find out just how much tuning there is to be done. I will post numbers when i get them.
Scott
Old Aug 17, 2006 | 08:35 AM
T/A lt1's Avatar
Re: LE3 track times
That is some good mph but you definately need some work in the launching department. My car ran 11.20's@120mph so you can go alot quicker with the HP you are making. Goodluck Later Clint
Old Aug 17, 2006 | 09:14 AM
NightTrain66's Avatar
Re: LE3 track times
GREAT MPH but as mentioned, the ET's can DEFINITELY get better with a good 60 ft. 120 MPH is pretty good for heavy car with the weather we have been having.
I see you have a 6 speed so some Pete Z bars and Drag radials would be the first things to get. Unhook the front sway bar and practice launching. If that is a stock rear end, you might have to slip the clutch or launch and get the car rolling and then tromp it. It will take some practice but a 1.75 60 ft is MORE THAN DOABLE.
If you have a 9" or 12 bolt, it will take a lot less finess and you c an just keep launching at higher and higher RPM's.
What 60 ft where you getting?
Get the launch down and some more tuning and you should have no problem with mid/low 11's.
Lloyd
Old Aug 17, 2006 | 11:26 AM
Black6spdZ's Avatar
Re: LE3 track times
my sixty foots were 2.0-2.1 but i was having trouble in second gear it would spin no matter how easy i rolled into it. A lot of the problem was that they were having some church event that had all 16+ second cars that were driving through the water and bringing it onto the track. I am going to get a set of drag radials and subframe connectors and see what that does. I might also go down to 3.73s because when i go through the traps i am really pushing fourth gear a lot.
Scott
Old Aug 17, 2006 | 01:11 PM
RealQuick's Avatar
Re: LE3 track times
mph is good.
Old Aug 17, 2006 | 01:37 PM
user 647483's Avatar
Re: LE3 track times
Great to hear!
Very good MPH, get some traction and a good launch and you will be running 11's all day
Old Aug 17, 2006 | 03:51 PM
ABA383's Avatar
Re: LE3 track times
Thats wicked mph....The ET will come with practice, tires, etc, etc...
--Alan
Old Aug 17, 2006 | 05:12 PM
1racerdude's Avatar
Re: LE3 track times
Scott
Gear it for 1000/1100 feet and let it run what it wants out the back.
Shift at roughly 10% past your peak power.
Get the 60' down 'cause a tenth on this end is worth 2 at the other end.
Old Aug 17, 2006 | 05:26 PM
stereomandan's Avatar
Re: LE3 track times
A lot of the problem was that they were having some church event that had all 16+ second cars that were driving through the water and bringing it onto the track.Scott
Gotta love the drag racing church events.
Great MPH.
Dan
Old Aug 17, 2006 | 05:49 PM
OldSStroker's Avatar
Re: LE3 track times
+10% might be a little higher than he wants to spin it....or than a stock PCM will let it go. I believe a LE3/LE4 383 peaks around 6500, so a 6700 shift would be close. You are dropping back into the fat part of the torque curve anyway.
