View Poll Results: LPE or Stage II
LPE 211/219
22.22%
Elliot Portworks Stage II
14
77.78%
Voters: 18. You may not vote on this poll
LPE 211/219 or Portworks Stage II
Old Feb 24, 2008 | 07:09 AM
  #91
SS RRR's Avatar
Originally Posted by 89385formula
I gave you a quick rundown a 3 minute search, and almost everycar on that list is close to full weight judging by what was said in the threads. You still have ported LT4 heads, not regular LT1 heads....everyone knows there is more performance value offered with LT4 heads.
That's highly debatable. The CNC program for the heads is relatively the same as what's used on the LT1 casting. LPE claims maybe a 10 flywheel hp gain using LT4's.
So some of the larger cammed cars that run quite similar to even out the use of LT4 heads. Maybe you could show me a list of people running the 211/219 in a full weight M6 running similar times as you? I mean your acting like you setup is the one to compare to, show me how many there are.
There are none that I know of. In the 6 years I had this setup I've never come across another one set up the same way. Why is that you ask? Because everyone thought LPE was overpriced and they were comparing LPE to what Craig was churning out with his prices. Also because GTP was making MANY combinations that were in the 11's. Especially around the Houston area. As I've said before I used to get busted on all the time because out of many many cars on here I was one of the slower full weight cars back in the lat '90s and early 2000's.
Plethora of LE/BRE setups running mid 12's@110....I posted every single LE results found in that 3min search. None were left out because they weren't fast enough...so where are all these cars you speak of?
There are five cars in the 17 you've posted that may fit what I was originally typing about. Not sure why you included LE3 and stroker engines in the mix.
The fact of the matter is many times before dyno numbers have been posted that are in the alleged 400+rwhp range and less than acceptable times have resulted. If you haven't read that on this site you are blind. Ask around. On LE's very website it gives alleged rwhp figures of what each package should run yet it's hardly ever the case.
You know about all these cars that I posted about because the funny thing is, You and your brother posted in virtually every thread. Many turned out just like this one.
You can spin it that way if you wish. Me, my brothers from different mothers see it another. So what now?
Old Feb 24, 2008 | 07:31 AM
  #92
89385formula's Avatar
OK debate it all you want. The LT4 heads are a better starting point, and 10 hp flywheel is still extra HP. You prove my point, you have the only full weight M6 with the 211/219 that ran 12.09@115...and yet you act like you set the bar. Congrats on your one and a million accomplishment.
LE3 setups are still nothing more then ported stock heads, and a bit more radical cam so why shouldn't they be included then? I'm guess LE's pricing is similar or less then what you paid for your LPE setup years ago....you mind telling how much you paid for your heads? Its comparable because its still ported stock heads/and aftermarket cam...just like what you got. Strokers shouldn't be included in results? Thats news to me, since its been over 10 years since the last LT1 F body was produced....engines need rebuilds, some get strokers...apparently thats not allowed. Tell that to your bro thats running a stroker with ported LT4 heads running just 120mph.
So now we are on the dyno talk again? I posted yesterday what I thought the majority of full bolt on cars were running as far as ET/MPH went. I did that math and those results all fall into that category, so what are you arguing about? The cars make power, DYNO proven all over the country.....so what is it some huge conspiracy?
Old Feb 24, 2008 | 09:08 AM
  #93
SS MPSTR's Avatar
I guess I should place my excuses here too - DA that day was 2700' I don't regularly post it, because it was a while ago, crappy DA, high humidity, crappy track prep, it had a miss, slipping clutch, and Mars was not aligned with Pluto.
Good f'ing grief, Charlie Brown.
Old Feb 24, 2008 | 10:26 AM
  #94
I am not saying anything against you.....I'm using you as an example. You have a stroker with Ai ported LT4 heads trapping 120, thats not bad....but apparently your stroker results don't count in the H/C world. If we went by SS RRR standards your car should be trapping 130. Seriously, your MPH fits in exactly what I posted previously that was exactly my point.
I have said it a ton of times already, the cars that go faster stock or with bolt ons are the cars that are gonna go faster when modded more heavily. I believe I remember SS RRR saying his car went a certain ET/MPH when stock, and although I don't recall exactly how fast that was....it was faster then the average LT1 car. I believe it was around a 13.6@102. Javier went faster cam only then alot of people here as well, and he performs better then most of the other LE cars, same from Clint, and the other guy thats had a number of good performing LE setups, Brady always makes the LE/BRE setups perform well too.
It just seems the 2 of you just keep beating a dead horse as always. Let it go, everyone has preferences with who they choose to use for performance parts....thats why there are a billion different companies. You don't chose Lloyd or Bret, thats fine they don't seem to care....but enough already. What happened to the days of choosing based on experience. Neither of you have their work on your cars, and my guess is if you did....You would make it run well with attention to details. I have spoken to a few people now that have wondered why Lloyd isn't sponsoring the board anymore. I don't know why, but I can tell ya this. If I had a business why would I sponsor a board with guys that constantly bash my product without ever having experience with it? Take a look around, most of us are here because we are car enthusiasts, well he was a long time sponsor and was one of the members to help keep this message board alive. So choose to work with whoever you want, but you should be ashamed for making personal attacks about his product because he isn't YOUR choice for a H/C package. You both said you would choose LPE over the LE2 setup, which is what the original question was...what more would you like to add?
  #95
96flame's Avatar
First two are under 114 mph...great et, and set up pretty well. 380rwhp = 113mph?
So what does an auto car trap? Def not the same as a 6speed. I swapped to an auto in my car and lost 4 mph but run the same et.
come back and brag when you trap 120+. nice job on working the ET down though...
With an emission setup I don't see that happening especially when the car is full weight.
Old Feb 24, 2008 | 10:27 AM
  #96
truedualws6's Avatar
And if I recall correctly you did not have the Turbonator installed that day either.
Old Feb 24, 2008 | 10:33 AM
  #97
96flame's Avatar
I figured that combo was exhausted and have since moved on. I thought all this head porting "technorogy" has advanced since 6 to 10 years ago?
No dyno numbers? No cam numbers? Duration? Lift? LSA? Or is this one of those sooper secret things?
I have also moved on the motor is different along with an auto trans now. I have no desire to dig into this further being as we've been through the details at least twice in the past 2 years and came out with the same ending.
Man I wish the snow would go away so I could get my car out
Old Feb 24, 2008 | 10:57 AM
  #98
Kaj's Avatar
Kaj
same here...96flame. I can't wait for spring, Wyoming winter's are unforgiving...
Old Feb 24, 2008 | 10:58 AM
  #99
Z-RATED94's Avatar
I don't believe it for a second. It's just more indirect instigation which you've posted so many times before.
Now I would NEVER try and take your crown away. And lets not be so paranoid, OK?
You are arguing about nothing. If you want a cam spec'd they'll be happy to point you in the direction necessary. If you want your heads ported/reported they'll do that too. This is exactly what I'm typing about... you argue based on nothingness.
Thanks, do you have their website handy? I'm having no luck with what I'm using to find their web page. Nothingness? I'll have to add that to my limited vocabulary. Good word for you to have, fits right into your comments with just about anyone using a BRE cam, which I do not. Oh wait, I have some older LE heads, depending on the user of said headporter, you either praise them or dispise them.
New engines are expensive to build and take time to work out unsuspected things. I've been living life with my family and working on our new house. This engine has been in the making for the last 4 years. It's hardly a priority. You just might unignorant yourself if you were to ever do so. Is this more indirect banter about how you believe my setup is a joke as you've PM'd me dozens of times now? How it doesn't exist? If not then really, what do you want to add to this debate? The fact that you're barely in the 11's N/A w/ all the crap you've done in an auto? As said.... you have absolutely no room to post about cost/performance w/ what you've done.
Funny how when someone else says their working out the bugs, you "usually" tell them their times are crap and they are never going to be fast using LE/BRE. But now you need what, another four years to work out some issues and post some track times?
Family, I'm lucky enough to have one too, plus a new addition, my daughters husband to be. They will be living with us, to save up enough money to get their own place. You have a new house, nice, we just re did a whole floor of the house, including a new full bath, plus other improvements to the 2nd floor. I still found time to hit the track twice last year.
And last but not least, my cost per performance. Is this something that bothers you. It's up there, but not really that bad, we all know it costs to go faster. No big newsflash there. But considering I'm still running the stock shortblock, trans, and rearend it might not be as much as you think.
And for the umpteenth time, never said my turd (as you like to call mine and others) was fast. But at least I post track times to help others know what I have and where I'm at, as far as ET. Have guys done better with less? Damn right. Am I faster then some? Yes, including some with more cubes and mods then mine. But hey, you have a good day, and post up the LPE link if you would.
Old Feb 24, 2008 | 12:34 PM
  #100
SS RRR's Avatar
Dyno... neat. How about THE TRACK? Not so much.
You can do whatever it is you want on whatever examples you want to give. I should've been more clear in stating stock cubes/emissions legal cam. Is a LE3 setup legitimately emissions legal?
Why not just throw in big blocks from Smokey Yunick and a F1 engine to boot.
The bottom line is LE/BRE as well as Overton's stuff never impressed me. The LE quality control things I've seen with some members complaining from past (at least 2 years ago) to present raises some huge red flags if I were looking at sending my cash to someone. GTP is what impressed me. It's a shame his rep. went into the ****ter...
No, actually I've only told you that because of some of the most ridiculous things I've read from your keyboard and because you believe for what you've done I should be impressed. I'm not. I know you're trying to convince me otherwise, but it's not going to work.
Good for you, super guy! Is there some sort of problem with how I conduct my personal business? What.. I'm to have some sort of agenda w/ this board and what I do or you slop off how my car is imaginary? Don't be stupid.
You mouthed off about it before to me on one of these threads before you realized what little I did to mine to run what I did. You bring it up again and have PM'd me DOZENS of times begging for me to take you and your car seriously. Sorry. Not going to happen.
You're perfectly able to find it yourself or pick up the phone and talk to them, good board citizen...
Old Feb 24, 2008 | 12:45 PM
  #101
JasonD's Avatar
Admin Emeritus
I haven't read all of this thread, but looking at the latest few posts, I don't need to. Guys, you do know better than to carry on here like this. It is really getting stale and wrecking someone else's thread to argue about pointless stuff is just not cool. Keep it elsewhere.
And for those who keep saying LE is a sponsor here, they haven't been for many months. Just setting the record straight.
G-BODYT56
Jan 14, 2022 11:14 PM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
karpetcm
Aug 14, 2015 03:02 PM
Henson071
Aug 4, 2015 09:32 AM
