View Poll Results: LPE or Stage II
LPE 211/219
22.22%
Elliot Portworks Stage II
14
77.78%
Voters: 18. You may not vote on this poll
LPE 211/219 or Portworks Stage II
Thank You
A big THANK YOU to everyone participating in this post so far because it's been an
extremely entertaining read. What was said two or three times that is the most
significant point of it all is "attention to detail". When you are in a class/group
that is so similar (i.e. not the stripped down trailer queen club) with street cars
that some daily drive with bolt ons and H/C combos that are similar, all that is really
left is the details.
There are 100's of details for a 93-97 LT1 f-body that can all add up to some major
improvements or go the other way and work against you. For me, since I can't drive
worth a crap, and I don't wan't to get into all the M6 upgrades necessary to produce a
decent 1/4 mile time I'll just have to sit back and read about it and enjoy my dyno
queen that is a total blast to drive on the street.
Anyone running low 11's with a full weight, streeable LT1 is doing one hell of a job and
it's an admirable accomplishment. My cousins 1966 L88 Corvette with 4.11s on 10"
slicks would run 12.1x back in early 1970s and I thought that was unreal. Here you
are doing better with daily drivable cars that probably get 20+ mpg on the highway.
I don't have a recommendation for the original posters question other than the options
do not seem to be comparable to me. A 211/219 cam is a different animal than a 22x/23x
cam so the H/C combo would be quite different. As with my setup which is a 210/224
cam, I did not want or need 200cc port volumes so I went with 185cc. If I had a
383 or a cam that would make power above 6k then I would want the 200cc ports.
I would think LE2 heads are probably closer to 200cc and the LPE package is
probably 185-190cc. The main difference is hand porting vs. CNC porting. CNC ports
will typically be much closer to the target volume and to each other (just another
detail). If you are searching for .01 seconds, details are critical.
There are only a select few of those which are comparable to a 211/219 cam and yes they are running good numbers. I was wrong to jump to the conclusions there aren't "any..."
I went back to that link and did not see anything regarding your name or car from page 9 on, so what am I supposed to be looking at?
You weren't lead to believe anything other than what you chose to believe. I'm not sure how you came to believe it ran 12.00, but nonetheless, it's still a 12.0 no matter how you look at it.
Yeah I remember you giving the "variables" speech and I think I remember telling you that not everyone w/ an LE/BRE package lives in the Rocky Mountains. I'm sure there are others who live at sea level tracks. You think?
My junk also ran a 12.28 @ 114.2mph at the Texas Motorplex which is somewhere in the 600ft. ele. range. It ran a best of 12.21 @ 114.5 at MIR. After the 4.11-to-3.73 gear change it ran the time that you were mislead to believe.
Yes I know there are variables, so on and so forth, but for the sake of argument and the plethora of LE/BRE 400rwhp cars turning mid 12's @ 110mph....
Within all these threads, not sure where to look for your info on your car.... do you have an auto? What package are you running? Specs and race weight?
My timeslip and weigh ticket is at the bottom of page 10 in that link. Car was M6 with 3.90 gears and 3800 lbs with me at the wheel. LE2 heads BRE emission cam which passed no problem. First time out with that combo I ran 12.73@110mph which is where most of the cars you speak of are at. I put in the time to work out the bugs to run a best of 12.14@115 mph at 642 ft.
No dyno numbers? No cam numbers? Duration? Lift? LSA? Or is this one of those sooper secret things?
BTW... this combo was on my car for 70K miles and never did I have one ounce of problems the entire time it was on the car not one LPE component needed to be serviced including the springs. It ran 12.low strong until the day I change up.
First two are under 114 mph...great et, and set up pretty well. 380rwhp = 113mph? Props, and now you're name-calling? Give me a break, jackass.
There are cars making a whole lot less power running quicker ET's than most on this site - are we not talking about making power?
You're right though...let naive and mediocrity be. It's not my money they waste. Why listen to Lingenfelter, he didn't know **** from shinola anyway.
Does LPE still produce ported LT1 heads? Any idea how much they run, cost wise, if they do? Anyone ever talk to them about different cam options other than the 211/219?
Don't mind me, just day dreaming here.
Carry on!!
Carry on!!
They deal in street packages which are emissions legal everywhere. Most, if not all of their street engines have an EO number.
As far as pricing is concerned... see what happens to any shop who becomes as big and is as well recognized. You should know you get what you pay for. Don't think you have any room to post up about cost/performance.
SS RRR, what's with the last sentence? Having another bad day? I'm just looking for a little info, and whether or not they still work with the LT1-LT4 packages.
And which is it, you can't beat the 211/219 or they can spec you another cam that might better serve your desired results? But wait, some larger profiles might not preform any better than one with a smaller profile. Really? Thanks for the hot tip. I sure hope I didn't screw up with this huge cam I have.
Cost verses performance? Lets talk about that when and if you have some track #s from this decade.
You are giving me lists of those w/ LE3's and 383's and those which don't disclose race weight.
Plethora of LE/BRE setups running mid 12's@110....I posted every single LE results found in that 3min search. None were left out because they weren't fast enough...so where are all these cars you speak of? You know about all these cars that I posted about because the funny thing is, You and your brother posted in virtually every thread. Many turned out just like this one.
