Street cam with torque(full precise details)
You've missed the point too. I'm not a critic of anything - I've asked for some cedentials, and as stated before, you don't need qualification to request them from someone who claims to be the best. As far as my 'underperforming' set-up - it's laughably still better than a majority of the LE/BRE combos posted, which is sad considering my engine had no compression. Like a few on here, my shortblock was not assembled well - not an excuse, a fact, and as I've said before I will post numbers when my engine is completed. Besides, what does any of this have to do with requesting substantiation for my set up or anyone elses? Do you have to have a medical degree to ask your doctor for explanation of a treatment or credentials? I didn't think so.Official critic? It's well known you're his friend, so your comments will simply be given the weight they deserve.
My comments should get the weight they deserve, since I see first hand the work that goes out the door from Bret. I have no problem doing business with him, and thats not because he's my friend....I know his credentials, and I deem him qualified to help me with my car. Also for what its worth the Company that installed the BRE cam, and dyno tuned it were quite impressed with Brets cam....and I would say they were quite skeptical at first. They use another well known guy for spec'ing their custom cams.
Multiple dynos were used to test the results of those LE/BRE heads/cam packages, and alot show over 400rwhp. Are the neysayers stating that all these dyno operators are playing dyno-tricks just for the sake of doing them even though they in no way have any affiliation with Bret or Lloyd?
SS RRR: You just happen to be the most lucky guy ever, or perhaps your just smarter then anyone else in the world. Seriously your the only one that knows how to set lash on Comp R's to not cause failure,
your $30 hardened pushrods will work for absolutely anyone without failure, Your LPE setup ran faster then 90% of the people on this board(claimed by yourself), or perhaps that could be because you are the best driver ever.
If you honestly want to know Brets credentials then go ahead and call him up, if you have no intentions of ever dealing with him as a business then I think that you should just drop it. Afterall is it your business if others use his services for a cam, or an engine or anything if it isn't you? I will however congratulate for taking the time to dial in your previous combo to what it should run, and for many its a tedious task. Your car ran well for what it was, and by the way you talk many cars you have had a hand in helping with run better then average times. I believe you could be an asset around here if instead of pounding your chest and boasting your accomplishments, you help others maximize there setups as you did.
Easy there... before you start running off with your own response or answer let at least me answer. It's quite the opposite. I only care about 400+rwhp dyno numbers if that combo goes to the track and runs 110 to 115mph. That's where I start wondering WTF is going on and I've seen it all too many times on this very site. Years ago it used to be people would post the ET and sometimes the dyno numbers. Now it's just dyno numbers and absolutely no ET's and if you do see them the dyno numbers just don't make a lick of sense compared to the ET's. So no.. I don't believe the dyno numbers are being inflated. What I do believe is that the care given to keep a dyno calibrated has fallen by the wayside since most anyone will believe whatever a "credible" shop with a chassis dyno tells them. I would not believe this if I would see more examples of Javier's car.
Why are you making this so dramatic? First off the pushrods are $40 before shipping. Secondly at least try to be accurate with your accusations. I stated the pushrods I used WORKED for MILD APPLICATIONS such as the 211 cam and LT4 hotcam. They worked. Period. There's no sensationalizm about it.
No beating my chest about it. Again with the sensationalizm. I am just simply stating what my very mild heads/cam combo ran 7 years ago to prove that, contrary to the cam grinder's and many members on this board, the LE/BRE is nothing different than any other reputable heads/cam combos that are available. I've already covered this in the thread. I shouldn't be one of the fastest with a stock block. For Christ sakes I should be the SLOWEST! If you want to be involved then by all means please read thoroughly before asking questions that have been answered.
The only snafu I had was gearing. I put in 4.10's because "everyone else was.." and all said it'd be better for launching. Boulderdash. I changed to 3.73 gears and saw a vast improvement. Went from 12.2's @ 114 to 12.0's @ 115. All because I was now able to stay w/in my power band.
Other than the above, yes the car has been aboslutely consistent. I got my money's worth and may get it again depending on how these LPE heads do on my new engine.
I never claimed that the LE/BRE was different then any other reputable heads/cam combo, and I once again agree with you. Your car ran good like I said, and is still good by todays standard. If more people could make there car run as well as you, that would be considered slow I'm sure.(some sarcasm, but quite serious)
I too would like to see some documentation to back up said claims. My current LT1 stroker engine was just completed by an individual with an accomplished resume for building numerous record setting performance engines. He is also a crew chief, and just set another national record with a motor he built.
For example:
This is known as begging the question.
The banter, while comical, avoids answering a direct question posed by "SS MPSTR". Either provide evidence, or cease to brag. Pouring water down our backs and telling us we're sweating serves only to strain credibility of the one making the claims.
I suppose painful litigation involving intellectual property rights and corporate espionage have been really pervasive in the camshaft industry.
For example:
For example:
Again why are you so interested in his credentials? SS MPSTR is here to cause problems nothing more, he has given no valuable information in any of his posts, he is here to stir the pot. I'm happy that your happy with your stroker, thats super. You aren't going to spend money with Bret, so nobody including Bret cares what your or SS MPSTR want....get my point?
Haven't you been reading?! You don't need to know any details because here's the proof below.
Stop asking objective questions.
SS MPSTR might support a certain person on the East coast, but the last time I checked his website, he had a LONG list of customers to back up his claims, and that list does not include customers who want to keep their names/set up's private. As long as you "deem" your buddy qualified to work on YOUR car, then that should satisfy the multitudes of others here who might want to know something beyond a hollow endorsement.
BTW- a typical mark of a scam is that you must "pay first" in order to get the "inside" scoop. Anyone want to get a side job stuffing envelopes?...you need to pay first for them to know you're serious. Not to compare your buddy to this analogy, it just happened to come to mind.
Stop asking objective questions.BTW- a typical mark of a scam is that you must "pay first" in order to get the "inside" scoop. Anyone want to get a side job stuffing envelopes?...you need to pay first for them to know you're serious. Not to compare your buddy to this analogy, it just happened to come to mind.
Who to have port my heads?
I'm confused on who should port my stock LT heads! I feel my stock heads if ported will be good with the LT4 H/C I've had in my car for about a year now.
PLEASE HELP ME decide who should port my heads.
Umm...this thread doesn't really have a whole lot to do with head porters. Do a search and do some reading. There's plenty of info out there to be able to make an educated decision.
what value are you looking for?? don't misconstrue my intentions because you fail to see or acknowledge the value in the question.
Stop asking objective questions.SS MPSTR might support a certain person on the East coast, but the last time I checked his website, he had a LONG list of customers to back up his claims, and that list does not include customers who want to keep their names/set up's private. As long as you "deem" your buddy qualified to work on YOUR car, then that should satisfy the multitudes of others here who might want to know something beyond a hollow endorsement.
Call him or email him and see for yourself, do you really need some internet punk to pry the info for you? When you want to purchase something you should always do research and call different vendors and see which YOU feel most comfortable with. You also have to take what many say on here with a grain of salt, many are making claims about a product they never have had. The 2 biggest porters that are debated here are LE/AI, and with results you'll find that the customers of each are very happy with the products, with some exceptions of course for both.
Me as well as MANY others don't see value in almost all your posts. Most of the times you come off as in internet punk trying to stir the pot, plain and simple. I would see some sort of value in your question if infact it was a genuine question, whereas instead I know that you feel he doesn't have credentials nor does have any knowledge. You have stated that you know Phil from Ai, so perhaps your theories and comments about who is better should be taken with the weight they deserve? I also have heard Phils/Rons thoughts on the whole LE/BRE vendors, so it doesn't surprise me by what your thoughts are...you know being there friends and all!
Internet punk
