Will a 454c.i. BBC fit in a 4th gen F-body?
Old Jul 17, 2009 | 07:28 PM
Mr.GearheadZ28's Avatar
I havent really decided on an engine and have a few choices, a 500hp Lt1, or a 500hp Rat motor. Seeing as they'll both cost about the same I might go with the big block if it is worth it and there won't be any major problems to get it to fit. As far as clearance will there be any major problems I may face? Does anybody make an engine mount for a big block to fit in an F-body or will I have to fab some?
Thanks- Jerry
Old Jul 17, 2009 | 09:10 PM
BadAssed93Z's Avatar
yes it will fit, a BBC is only 2.25 inches longer than a SBC. you will need a cowl hood, or really small breather.
Old Jul 17, 2009 | 09:49 PM
knta4dnu's Avatar
Just curious. What about clearance for, and servicing, the distributor?
Old Jul 18, 2009 | 12:22 AM
<Puck>'s Avatar
I hope you can fab and weld comfortably.
It isn't rocket science, but there are no "kits" to get the job done and a lot of stuff needs to be made and figured out on your own. I have read two or three build threads on BBC fourth gens and it was enough to change my mind about the swap
Old Jul 18, 2009 | 12:33 AM
reamo04's Avatar
its getting easier but still requires work
use a BMR k-member w/o mounts and usemotor plates
buy some lemon headers, that'll take the two biggest problems out of the way.
you have to cut the radiator support and stand the radiator vertical
servicing the distributor you can either cut out the cowl, or you wouldhave to drop the engine, or run something like megasquirt
Old Jul 18, 2009 | 06:20 AM
Complete writeup with pictures:
http://my.att.net/p/s/community.dll?...geid=28387&ck=
Old Jul 18, 2009 | 08:47 PM
maverickmk's Avatar
BMR makes a K member for a BBC in a 4th Gen http://www.bmrfabrication.com/F-bodyChassis.htm
Old Jul 18, 2009 | 10:22 PM
I'll do it if there are no accessory brackets to fab and I can use the ones out of a 86'-94 454 truck. Please say I can do it without messing with the radiator position, headers clearing okay with a BBC tubular k-member, and distributor is going to be a digitally programmable MSD E-curve that can be tuned in engine!. Big-Block= MONSTER torque/horsepower band!
Thanks- Jerry
Old Jul 19, 2009 | 12:23 AM
reamo04's Avatar
Thanks- Jerry
you cannot do it w/o doing the radiator vertical
as far as the accessory bracket, i have no clue. all the ones I have seen are alternator only.
Old Jul 19, 2009 | 08:12 AM
maverickmk's Avatar
I will probably doing that next after I beat up this LT1 I just put together. I've always wanted to put a big block in a 4th Gen as well. I don't think you'll have a whole of problems, just depends on your skill to do some fabricating or getting someone to do some fabricating for you.
Old Jul 19, 2009 | 08:25 AM
slowride94z's Avatar
https://www.camaroz28.com/forums/showthread.php?t=576310
https://www.camaroz28.com/forums/showthread.php?t=586295
https://www.camaroz28.com/forums/showthread.php?t=458573
https://www.camaroz28.com/forums/showthread.php?t=530459
here are a few local
Old Jan 28, 2025 | 01:04 PM
93streetcamar0's Avatar
Smile Re: Will a 454c.i. BBC fit in a 4th gen F-body?
Originally Posted by Injuneer
Hey saw your still active so, I’m trying to build my 4th gen Camaro with a 454. We’ve already made all the fab for distributor but I don’t know if I should buy the engine mounts or jus fab them myself. Also I would’ve loved to see your link but it just redirects me to yahoo. I’m also from Jersey
Old Jan 28, 2025 | 02:13 PM
I've seen 4th Gens with big blocks, including a 512ci version. But I have no idea what is involved.
No surprise that a 15 year old link is broken.
There are other big block threads here, and some on lt1tech.com. Nobody here any more. Can go several days without a post, except for the SPAM for a fake dating site. The few people that are left drop in once in a while, but mostly LT1 fans.
Old Jan 28, 2025 | 03:49 PM
There are other big block threads here, and some on ls1tech.com. Nobody here any more. Can go several days without a post, except for the SPAM for a fake dating site. The few people that are left drop in once in a while, but mostly LT1 fans.
figured thanks anyway
NOSfedstang
Jan 14, 2006 11:22 AM
elisowski
Advanced Tech
Jan 28, 2005 07:36 PM
94patriotredZ
Advanced Tech
Oct 11, 2004 01:05 AM
JamesTKirk41
Jul 15, 2003 11:37 AM
vz125dude
Advanced Tech
36
Apr 21, 2003 11:16 PM
