Procharger fit under 2nd. gen. hood?
Re: Procharger fit under 2nd. gen. hood?
Originally posted by JamesTKirk41
Will a P1-sc fit under a 2nd. gen hood?
Gen V 454HO crate motor (425 hp). TH400 and F*rd 9" with 3.42 gears. 8.75:1 compression. Blower is set up for 10 psi. Procharger assured me it should be close to the 625 hp I am shooting for. If only the hood fits...
I know I will have room for the carb bonnet but I'm not sure about the housing itself. If you are familiar with second gen hoods, the housing falls right where the hood dips down just inside the headlight.
Don't Fit
Just for everyone's info..
A P1-SC mounted to a BBC will not fit under the hood of a second gen. I have an 1 3/4 cowl and clearance is good over the carb but the blower housing hits the hood with the hood about 2 to 3 inches from closing. Keep this in mind if you are thinking about this mod.
CARiD
Jan 14, 2015 04:00 AM
