SBC Brackets to fit in a 4th gen
Old Oct 6, 2004 | 12:51 PM
94patriotredZ's Avatar
Thumbs up SBC Brackets to fit in a 4th gen
A couple of months ago I asked if anyone knew of some brakets to fit an sbc that fit in a 4th gen camaro. Street and performance does not make one that fits in the camaro, while having the ability to keep the a/c. I found that March Performance's mid-mount kit is the answer. just thought i'd share the info for anyone else dropping an sbc into the 4th gen.
Old Oct 8, 2004 | 04:17 PM
crash4cyl's Avatar
Re: SBC Brackets to fit in a 4th gen
you should be able to put a SBC in a pre 98 4th gen without An issue using stock motor mounts. They mounting bosses on the block are in the same location. Shouldn't be a problem.
chris
Old Oct 8, 2004 | 06:46 PM
actually, lt1 MOTOR MOUNTS are completly different than sbc mounts, hence the use of a BMR K Member. Accessory brackets on an lt1 won't work on an sbc because the bolt pattern on an lt1 is unique.
Old Oct 10, 2004 | 12:42 PM
Boost It!'s Avatar
how do you adjust timing and such? isn't the distributor under the glass?
Old Oct 11, 2004 | 01:05 AM
yes the distributor is "under the glass", but its not hard to adjust the timing.
Dec 31, 2014 02:21 PM
firebirdude
Aug 7, 2002 07:31 AM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
