Need Help Asap!!
Old Jan 14, 2006 | 09:18 AM
NOSfedstang's Avatar
Need Help Asap!!
I bought a 96 Trans AM roller. it has a TH400 FMVB, Trans break, ford 9in. tublar front and rear suspension...The car went 9.7's with the old 396ci setup.....It weigh was 3800lbs. I have the car down to 3300lbs.....My question is will a standered small block Chevy...I have found a still on a 406ci.....will the motor fit in the car? thanks
CJ
also headers will have to be made......
Old Jan 14, 2006 | 11:19 AM
Re: Need Help Asap!!
Several people have put Gen 1 SBC's ion their 4th Gen F-Bodys. Takes a bit of work, but it will fit. The big problem is under the cowl, where clearance for the distributor is limited. If its a "track car", you take the wiper linkage out and cut up the cowl. But even without that, its possible to fit the distributor in there.
Hood clearance can be a problem if you are using a carb.
Old Jan 14, 2006 | 11:22 AM
Mean Green's Avatar
yeah a genI SBC fits and they do make low profile distributors that should fit under that cowl with no problem.
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
