Just finished my 1.7 RR install
Old Oct 25, 2003 | 12:33 PM
  #121
Spartus's Avatar
alrighty.. I got mine running now. I ended up having some factory GM studs in there instead of ARP's.... So I went a purchased some ARP 3/8 for roller rockers. The Hex is about .050" lower, so it worked out great. Then once I had it all put together I ended up needing to beat the tops of the valve covers up with a chissel. I could see where the poly locks were hitting the covers...
ALSO, the ARP studs were a little longer in the thread area.. Maybe 1/8"... so my set screws were hanging out of the top of the poly locks... That's not good... So I ended up swapping the set scews from my GMPP's to the Scorpion poly locks, and now the screws are just below flush...... If not for that the valve covers would have never fit.
-Tom
Old Oct 25, 2003 | 09:10 PM
  #122
MattysTA's Avatar
-Tom
are you using these on a stock cam or with an aftermarket cam? cause i didnt have to clearence my valve covers at all........
Old Oct 25, 2003 | 10:44 PM
  #123
KillinFormula's Avatar
did you get new vaulve covers, and if so where do you get taller VCs?
Old Oct 25, 2003 | 10:49 PM
  #124
Spartus's Avatar
I'm running a Hot Cam.. So now I'm somewhere close to .560" lift... All that's hitting my valve covers is the top of the Poly Locks... I have a set of those custom Aluminum Ball milled valve covers that have about 1/8" more clearane to the top of the cover, but the supports inside the covers won't fit between the rocker arms. I'll be bringing them into work tommorow and have the machine shop cut out the supports. Then all should be fine.
I can say that I am very impressed with the GM guideplates. I had a set of Comp guide plates with some Comp Pro Magnums that I tried out earlier this year, and I had to twist the comp plates all the way one way to get the rockers to line up... With the GM plates I barely had to twist them all... ThunderRacing's description for these guide plates is "LT1 / Fastburn guideplates". So the spacing on these must be a bit different than the Comp or Crane SBC guide plates.
Today I took the car out for a drive to work and back (50+) miles. It was wet out, but even so the engine does seem to have a little more SOTP to it, making power a little sooner than it did before.. The 1.7's threw off my fuel trims though so I'll be needing to dive back into LT1 edit and fix things up.
-Tom
Old Oct 26, 2003 | 03:36 AM
  #125
MattysTA's Avatar
-Tom
Ok, i thought you were using them with an higher lift cam. that sux about the valve covers but atleast you got them to work for ya........since you can feel the diffierence with having the hot cam. imagine how my car feels since its an all bolt on car.....
Old Oct 26, 2003 | 09:23 AM
  #126
pu12en12g's Avatar
Originally posted by Fastbird93
Just an FYI for people, I just ordered a set of the GMPP guideplates from Thunder Racing. They have them in stock still.
I decided to give these a shot on my 224/230 car. I'm kinda interested to see what they do for me.
Bump on this.
I am very interested in seeing your gains from this upgrade.
Please let me know.
Old Oct 26, 2003 | 09:31 AM
  #127
jasons93z's Avatar
Hey guys, im interested in installing 1.6rr, i think 1.7 is too much for a stock cam. What all will i need, and how much will it cost. I will be doing this along with the header install. I hate to be a thread stealer, just asking. Thanks all.
Old Oct 26, 2003 | 10:57 AM
  #128
Fastbird93's Avatar
Originally posted by pu12en12g
Bump on this.
Please let me know.
Sure thing!! I'll be ordering the rockers around the beginning of next month. Install should come immediately upon reciept. The only thing that's going to keep me from getting it done right away is whether or not the new opti I'm putting on this week fixed my hesitation/stumble problem. If the guy with the hotcam/ported heads combo picked up 15, I'm not ruling out the possibility of me picking up even more since I've got some KILLER heads on the car. Even if I get the same gain of 15, that will still put me up into the 390+ range.
Another FYI, TEA sells these rockers too, albiet for $240. That first posted website is about the best deal going I believe. For those that ordered from the first place, how long did it take to receive them?
Old Oct 26, 2003 | 11:41 AM
  #129
Gripenfelter's Avatar
I looked into doing this on my car and my engine builder said I would come very close to smacking a piston at close to TDC.
11.3:1 compression
XE 230/236 112 cam
It would have 578/589 lift
****ty.
Old Oct 26, 2003 | 11:52 AM
  #130
Cmr0z28's Avatar
11.3:1 compression
XE 230/236 112 cam
****ty.
you sure about that? guys are running over .600" lift (I think atljars friend is running around .608") without any problems on a stock bottom end engine.
Old Oct 26, 2003 | 11:58 AM
  #131
MattysTA's Avatar
I had mine sent overnight for a total of 237 and change....
Old Oct 26, 2003 | 12:02 PM
  #132
MattysTA's Avatar
oh yeah BTW i played around with a mild bolt on ls1 lastnight. even with my slipping trans he couldnt get up next to me.....he was about 3 cars behind me the whole time......
Old Oct 26, 2003 | 12:24 PM
  #133
Spartus's Avatar
I ordered mine on Monday From Flatlander Racing and recieved them on Thursday. Same for the Guideplates from Thunder Racing..
Old Nov 2, 2003 | 01:02 AM
  #134
MattysTA's Avatar
Old Nov 9, 2003 | 07:07 PM
  #135
MattysTA's Avatar
got some track times tonight.....
Here is the best run of the night....keep in mind this is with a slipping trans and it bounced off the rev limiter 3 times on the 1-2 shift and once on the 2-3 shift
on bald nitto 275/40/17s......
temp: 44
releative humidity:39
absolute barometer:30.83
60 ft: 1.994
1/8: 8.58
1/8 mph: 81.89
1/4: 13.350
1/4 mph: 103.73
Yeah i see with a good trans,convertor,good tire mid 12s are on the way. i am also running the stock daul-cat y-pipe with 91,000 on the clock.....
