Just finished my 1.7 RR install
#211
Re: Just finished my 1.7 RR install
Ok, guys this might have been answered within the last 14 pages but i dont have time right now to read all of it. Can i use 1.7rr with the hotcam kit and stock heads? would the springs in the kit work? thanks
#212
yes they would work i def would get better springs than in the kitand check your push rod length.I have a hotcam in my car and i have 1.65 ratio RR and i had to go with .50 shorter with stock length the roller was way to far on the exhaust side of the valve tip
#213
#214
Anybody want to take a guess at the pushrod length for a stock cammed 96 WS6 using the 1.7RR Comp's. It appears that a 7.120" hardend' pushrod should be about right ? Stock pushrod is 7.200". What do you guys think ? The car currently has a set of 1.6 RR Comp's, LT4 springs, 7/16 screw in studs (GM), NSA guide plates (GM) and a set of hardend' 7.200" comp pushrods. I'm thinking the 7.120" comp hardend' pushrod with 1.7 RR comps ( I've had these rockers new in the box for a long time ) using the LT4 springs (.525 lift,max) or should I use the EX-614 springs (combination motorsports, sitting in a box for a long time (.600 lift, max) with the 1.7 setup.
#215
#216
Snorkelface,
I would agree not to guess at the geometry. Just wanting some input on what others have measured for the correct pushrod length. Probably worded that wrong by saying "guess" I have a pushrod length checker and will certainly take a measurement.
10-31-2016 11:09 AM
Richardan15
05-30-2015 08:36 AM
