Just finished my 1.7 RR install
Old Oct 16, 2003 | 10:02 PM
  #76
MattysTA's Avatar
Originally posted by stagen
Those were my pictures and yes the guide plates that you can see are NOT CORRECT as I hve stated on that page. You must use the flat plates.
yeah i guess i didnt read that whole post, i also tried using raised ones the first time. i also found out they wouldnt work. even regular flat ones wont work because the bolt holes dont line up.and as i found out by grinding them out a little to make the bolt holes line up. it throws off the positioning of the pushrods making my pushrods getting eaten up a bit. IMO GMPP guideplates are the only way to go.......
Old Oct 16, 2003 | 10:24 PM
  #77
stagen's Avatar
The crane plates lined up ok on mine. I haven't taken the valve cover off yet to see if there is any wear on the rods. I'll have to look this weekend.
I didn't pay attention when I got the plates and just went and bolted the one side on. Slipped the rockers on and decided to do a test fit. Glad I did as I would have been hotter than I already was for them shipping me the wrong plates. Fortunately JB from IRS was online and said they had some in stock and I picked them up the next morning.
Old Oct 16, 2003 | 11:39 PM
  #78
Cmr0z28's Avatar
hey I have a question.....I'm thinking about doing this......
does it change the way the car sounds at all? will it still sound like a truck with the cutout opened?
Old Oct 17, 2003 | 04:36 AM
  #79
jasycZ28's Avatar
I am going with the cc305 due to emissions. otherwise I would run the cc306. I don't remember the specs off hand of the two but would a cc305 with 1.7 rockers be close to a cc306 with 1.6 rockers? That way when emissions rolls around I could swap back in the stockers and be on my way.
Old Oct 17, 2003 | 05:15 AM
  #80
MattysTA's Avatar
My car def got noticably louder,deeper and lopeier sounding after i put these on,i have the loudmouth exhaust......
Old Oct 17, 2003 | 08:58 AM
  #81
Fastbird93's Avatar
Are the GMPP guide plates a direct bolt in?? I may still consider the swap if I don't have to do any machining to the heads to get a guide plate to fit right.
Old Oct 17, 2003 | 10:49 AM
  #82
94GrayV6's Avatar
Anyone have the p/n for the GMPP guideplates?
Old Oct 17, 2003 | 03:16 PM
  #83
MattysTA's Avatar
yes they are a direct bolt on, no machining needed
Old Oct 17, 2003 | 03:18 PM
  #84
MattysTA's Avatar
I listed everything needed for this swap,including all the part numbers on the first or second page of this thread.........
Old Oct 17, 2003 | 04:09 PM
  #85
Fastbird93's Avatar
Were those direct "bolt on" or was machining required?
Old Oct 17, 2003 | 05:00 PM
  #86
MattysTA's Avatar
fast93....
i answered your first post about the guideplates, scroll up a bit...
Old Oct 17, 2003 | 05:36 PM
  #87
Cmr0z28's Avatar
I have a question......if the max lift is gonna be .521", why can't we just use LT4 valve springs?
Old Oct 17, 2003 | 09:28 PM
  #88
MattysTA's Avatar
if you want to you can, i even have a set that is half new,half slightly used. but i decided to go with the springs i have on now. i dont like running springs that close to the lift numbers. thats just my personal way of doing things. so if anyone wants my lt4 hotcam springs ill sell them for the b/o.....
Old Oct 17, 2003 | 11:35 PM
  #89
stagen's Avatar
When my heads were being done the porter and a friend were testing the springs and stated that they would not hold up in the upper RPM range. This was with the Hot CAM and LT4 rockers. Again this was on ported heads. Stock should be ok but I'm like the last person. I prefer to be safe and went with better springs as they suggested.
Old Oct 17, 2003 | 11:45 PM
  #90
94GrayV6's Avatar
Just so everyone knows i ordered all the stuff I needed from GmPartsDirect a couple days ago. Today I recieved an email saying that the guideplates were on backorder with GM and there was no ETA on when new ones would arrive.
