Just finished my 1.7 RR install
Old Nov 9, 2003 | 07:21 PM
  #136
Fastbird93's Avatar
NICE!!!! Very nice with that slipping trans. I just got my rich condition figured out (PCM) and once I get a new computer in and the car tuned in, I'm going to swap the rockers in and do some more tuning so I'll have a good gain shown on paper.
Old Nov 9, 2003 | 08:35 PM
  #137
FacelessZ's Avatar
Exclamation
Can you use NSA 1.7 rr's with an XE 230/236?
Thanks!
Old Nov 10, 2003 | 06:58 AM
  #138
RealQuick's Avatar
Thanks!
Yup.
Old Nov 10, 2003 | 08:00 AM
  #139
magius231's Avatar
has anyone done it yet? I have the 230/236 .510/.520 (with 1.5's) and 1.7's would be a great way to get some more lift out of this cam...but has anyone run this cam with them yet?
Old Nov 10, 2003 | 08:07 AM
  #140
Fastbird93's Avatar
Correct me if I'm wrong, but I believe RealQuick tried it, and his springs didn't hold up. If the 1.5 lift is only .510/.520, then with the 1.7 the lift will be .578/.589. Just make sure you have the springs to support the lift and you should be fine.
On another note, this being the early stages of 1.7's being run on the LT1, has anyone heard of any study of long term valvetrain wear effects and possible failure of various components due to the valvetrain geometry change with the 1.7?? I know that it's not THAT drastic of a change moving from a 1.5/1.6 to a 1.7, but I'm kind of left thinking "Why not until now?"
On that note, my 1.7's should be going in within a couple of weeks.
Old Nov 10, 2003 | 08:30 AM
  #141
FacelessZ's Avatar
I know the hydra-rev kit isn't necessary with our cars...but would something like that help minimize the valve float and help support the 1.7's?
Old Nov 10, 2003 | 08:40 AM
  #142
RealQuick's Avatar
Sean is right, I did try it. Power fell off rapidly after peak which showed I was having issues. Before with the 1.6's it pulled strong up top and didnt fall of near as quick. Definitely a spring problem in my case.
Old Nov 10, 2003 | 09:07 AM
  #143
xxsaint69x's Avatar
i didnt feel like reading everything, but i was wondering what i would blow up by putting some 1.7RRs with a CC306. (230/244)
.544 .576 lift with 1.6 rockers
or even better the GM847 232/242 .575 .595 lift with 1.6 RRs
Old Nov 10, 2003 | 09:09 AM
  #144
Fastbird93's Avatar
Wow, if you could pull it off, you'd be looking at .578/.612. That would be mean, but maybe a bit much on the exhaust lift for a hydraulic roller.
Old Nov 10, 2003 | 09:56 AM
  #145
FacelessZ's Avatar
Hydra-rev kit with 1.7's? Anyone have anything to add?
Would utilizing 1.7 rr's become more beneficial after stock heads were ported? I saw some people reply that 1.6's are good for stock heads, but would 1.7's become more useful on ported heads?
Old Nov 13, 2003 | 07:58 PM
  #146
SAR2K's Avatar
Thumbs up
1.7's worked great on my stock heads & stock cam. Now with ported heads and aftermarket cam, they're iceing on the cake.
Steve...
Old Nov 13, 2003 | 09:15 PM
  #147
Fastbird93's Avatar
Steve...
Looking at your sig, makes me glad I'm putting them on my car!!!
Old Nov 14, 2003 | 01:56 AM
  #148
drewstealth's Avatar
Wow...nice times. Yep, i'm definatly gonna get the 1.7's.
Old Nov 14, 2003 | 11:15 AM
  #149
Spartus's Avatar
Those of you installing the 1.7's with GM guideplates should be careful that your pushrods don't hit the guideplates. The extra angle gets the pushrods aweful close to the guideplates. Especially after you AIM the guideplates properly. I had to turn all of mine to the right to line the rockers up with the valve tip. After doing this my pushrods were rubbing... I had to have the guideplates clearanced(slot made deeper)...........
This is not just a BOLT ON, and OFF YOU GO type of mod. I checked my geometry when done too, and had to go with a longer pushrod. I ended up with a 7.250" pushrod.... I think Manley makes 7.230" pushrods for around $79 which would be a better fit.
Good luck guys and remember to check those things.
Old Nov 14, 2003 | 11:40 AM
  #150
Fastbird93's Avatar
Good information. It's probably going to run vehicle specific as there's a couple of people just throwing on the parts and having no problem. That said, it's definitely a good idea to at least double check to make sure that everything lines up right.
