Engine Swap Thread. V6 to...?
Old Mar 16, 2007 | 07:55 PM
  #166
-SLEEPER-'s Avatar
Carb'd 350
Has anyone put a carb'd 350 in an F-body? Would a cowl-style hood be need to clear the carb? Would I be better off to just buy an LT1? Thanks
Old Mar 16, 2007 | 07:58 PM
  #167
mdacton's Avatar
yes
yes
Old May 3, 2007 | 04:30 PM
  #168
dbusch22's Avatar
V6 to V6 swap... odd question i know 3.4L to 3.8L ??
so can you take a 95 3.4L car and put a 95 3.8L engine into it?
reason i ask is because i need a new motor anyway, and i don't care for all the fuss about 'harness this' and 'cradle' that... and 'this bellhousing' etc etc. i just need an A to B car. since i'll be buying a motor for about the same price no matter what, the extra 40hp out of the 3.8L sure would be nice.
Old May 3, 2007 | 04:54 PM
  #169
Tiago's Avatar
no...
nothing is interchangeable. might as well swap a V8 in.
Old May 3, 2007 | 05:13 PM
  #170
dbusch22's Avatar
ahh yes... 3.4 liter is it then! oh well, good thing this car is an AMC... Aint My Car.
thanks for the quick reply
Old May 3, 2007 | 10:02 PM
  #171
Klypto's Avatar
from personal experience. dont do it... sell the car and buy a v8... trust me. not going into details... just pisses me off, but not worth it
Old May 3, 2007 | 10:31 PM
  #172
AlfredB18's Avatar
I bet you can. You can use the same tranny (both have 60 degree bell pattern), radiator (if not, the 3.8L version fits easily enough), and crossmember, but the engine harness and computer changes.
The 3.4L was OBD 1.5 with the OBD2 port, so I doubt it's that big a fuss to swap an OBD2 3.8L in place. GM did it mid-year...
The tranny is already electronic, the speedometer has been electric for some time, the 3.4L has tons of sensors as does the 3.8L....the AC setup never changed.
I've only glanced at schematics bewtween the 3.4L and 3.8L, but it doesn't seem too terribly different between both engines. I've worked about two weeks straight, so that's as concrete a lookover I can give you so far...
Old Jun 18, 2007 | 06:40 PM
  #173
chris96camaro's Avatar
how difficult would it be to hook up a carbed v8 into my 1996 3.8?
I am in need of a new motor and would like to do the v8 swap...but i dont know the whole deal about carbuerators...
Is that a better option than a FI Lt1?
Old Jun 28, 2007 | 01:11 AM
  #174
Jonas24's Avatar
Hey guys i need help im trying to decide which engine would be the best way to go in my 94 3.4L i was thinking between a 355, 383, or an ls1 preferrably which ever one is cheaper.
Old Jun 28, 2007 | 01:26 AM
  #175
Klypto's Avatar
a ls1 can be a 355 or a 383... same thing just dif internals...
Old Jun 28, 2007 | 03:20 AM
  #176
Jonas24's Avatar
oh ic, what exactly is the difference between a 355 and a 383?
Old Jul 27, 2007 | 01:00 AM
  #177
95camarowhite's Avatar
I've got a question... I have a 95' 3.4L/automatic camaro and I was wondering if I would be able to swap in a 2000 or up corvette engine?
Old Jul 27, 2007 | 01:58 PM
  #178
Wyatt's Avatar
Changing to carb engine
Has anyone seen or has anyone posted any info on changing the engine in an F-Body to a carb engine and non-electrical transmission?
I am thinking about putting a big block in one. I know there will be a distributor issue under the dash, however that is of no concern given the dash can be removed and remade with aluminum sheeting.
BTW...this will be a track only car and I hate electronic controlled engines. I am from the old school of drag racing. LOL
If someone else has done all the work it might save me some time reinventing the wheel.
Old Sep 12, 2007 | 10:47 AM
  #179
ford1's Avatar
98 3800 series2,can you pull it out the top without dissassembling the engine,such as plenumn and the like?I cant see how to get a cherry picker in there and hook a chain to it.I'm considering dropping the front cradle and taking it out the bottom on my lift and just lifting the car up.Then I'm looking at the tranny and engine sitting there in front of me.Any thoughts!! thanks
Old Oct 3, 2007 | 10:29 PM
  #180
ford1's Avatar
HELLLLOOOOOO!!!!!! droped it out the bottom ,thanx for the input!!
