Engine Swap Thread. V6 to...?
Old Mar 20, 2005 | 06:19 AM
  #106
Sergio's Avatar
Re: Engine Swap Thread. V6 to...?
As far as the list of what is needed see the beginning of this thread, it's pretty complete.
As far as performance i'd do a search in the LT-1 section and you'll find about 1024 topics covering this.
What it basicly comes down to is:
- CAI
- LT headers
- Bigger injectors
- Freeflowing exhaust
- Proper ported and FLOWED heads
- Cam to match the heads
That's basicly enough for a serious power increase of at least 100FWHP.
Old Apr 25, 2005 | 07:35 PM
  #107
billmacomber's Avatar
Sorry if this has been answered before but I couldn’t find it what is the difference between the v6 k-member and the v8 would it have to be swapped out or just the motor mounts
Old Apr 25, 2005 | 08:24 PM
  #108
gerard143's Avatar
the v6 cross member has the mounts in different location along with being formed different so that the v8 motor actually can sit in the cradle lower then the v6.
you can find k members around here and there for about 100 bucks.
i'm doing a swap now.
any questions email me.
Old Apr 26, 2005 | 04:25 AM
  #109
Sergio's Avatar
I got myself an aftermarket one.
Gerard, good luck man ! Keep us posted and try to make pictures of the entire proces as no one has really done that before ...
When are you dropping that 3.4 ?
Old May 7, 2005 | 08:31 PM
  #110
EKO's Avatar
EKO
As far as actually removing the engine/trans, I've pulled my V6 A4 out the top together before, but it was a b****. I've also see it done, by disconnecting the driveshaft, trans crossmember, wiring/fuel/hoses etc and finally the k-member and lifting the car up and rolling the engine out from under it. I have access to a 2-ton ceiling hoist, and put the car on some 2 ft. ramps when I pulled the V6 the 1st time. But now I'm thinking about pulling the ramps out of the garage and just doing it when its on the floor by lifting the car off the engine. This way I could just put the wheels on the other k-member and roll it in. I've heard that the car is designed to have the engine removed/installed this way. What do you guys think is the easiest way?
Old May 8, 2005 | 06:30 AM
  #111
Sergio's Avatar
Dropping the engine is the easiest way hands down.
Removing from the top is more work and requires more skill, tools and headaches.
There have been several how to's online how you can remove the engine the quickest and easiest way possible, and that's by dropping it.
Pulling the engine from the top is a waste of time.
Old May 8, 2005 | 09:13 AM
  #112
gerard143's Avatar
i agree from the bottom is easier
Old May 30, 2005 | 10:04 PM
  #113
LS1_03's Avatar
Can the 3.4L be swapped into a 92 S-10 which has a 2.8L currently? That'd be kind of fun if it was a mostly painless swap.
Old Jun 3, 2005 | 07:00 AM
  #114
Sergio's Avatar
Since the 3.4 is merely a bored and stroked 2.8 i think it could be done without too many problems.
It will have some parts/accs and wiring which are ofcourse different but that can be dealt with easily, the important things are the motor mounts which i reckon are in the exact same spot.
Old Jun 6, 2005 | 11:54 AM
  #115
LS1_03's Avatar
Hmm. Thanks. It'd be fun to throw in a 3.4 or 3.8 and toss a turbo on it. I'd have a pretty quick beater S-10 that still got good gas mileage....
Old Jul 3, 2005 | 04:47 PM
  #116
Sergio's Avatar
interesting point this one guy makes ....
http://web.camaross.com/forums/showt...=1#post3171230
Wonder how everybody else did who performed the swap, did you have to replace than forward harness including the complete fusebox and cockpit fusebok and wiring also ???
Old Jul 3, 2005 | 07:04 PM
  #117
gerard143's Avatar
ya i was in the process of doing a swap then decided for now to just fix my v6 cuz it was cheaper at the time, but the forward harness does have some differences, for example a coolant level sensor, and the 2 radiator fans,etc.
the forward harness runs under the master cylinder and disconnects inside. its sorta a pain to stuff it all out the little hole to rip it all out. but there are people that did a swap without it, they just must wire up the fans and say the hell with the coolant level sensor.
Old Jul 3, 2005 | 10:44 PM
  #118
Sergio's Avatar
Hm, good info man ...
Damn, looks like i will be needing that forward harness after all
You got one you don't need anymore Gerard ?? I'm buying !
Old Jul 6, 2005 | 11:27 PM
  #119
gerard143's Avatar
i am hanging on to mine for the time being. might still swap down the road
Old Jul 6, 2005 | 11:31 PM
  #120
gerard143's Avatar
sergio are you doing ur swap now or?
