please help.....have a constant miss over 5K, please read, i cant figure it out....
Old Jul 22, 2002 | 02:07 PM
  #91
Transamdriver's Avatar
Post
I am having this same problem, around 5k rpm it feels like I back off the throttle for a second then lay back into it after 5k. My solution is I am converting to OBDI and changing all the plugs and fuel filter AGAIN after 10k miles. If this doesnt fix it I am stumped. I have installed: New opti, TR55 plugs, Accel wires, AC Delco Coil, been through 2 diff. types of coil wires, fuel filter, last but not least O2 sensors. And guess what?? The freakin miss is still there.
John
-97 TransAm
Old Jul 22, 2002 | 02:23 PM
  #92
sleeperZ96BT's Avatar
Post
dont expect the obd1 conversion to fix it, i have my miss pre and post OBD1 swap. just thought id toss that in, will post later with fuel pressure results..
brian
Old Jul 22, 2002 | 02:31 PM
  #93
Post
I have to go OBDI since I just put on Hooker LT headers and removed the AIR and EGR systems. Also I can only run the two O2 sens. Plus I am doin it for the ease of tuning.
Old Jul 22, 2002 | 03:36 PM
  #94
HEATH's Avatar
Talking
GOOD NEWS!!!!!!!!! FOUND THE FIX--------------- TAKE ALL THE ELECTRICAL COMPONENTS OFF OF THE CAR COMPLETELY AND THROW IN A CARBED 468ci BIG BLOCK CHEVY. SO WHAT DO YA THINK..J/K
94 T/A LT1 A4
SOME MODS,KINDA QUICK
times- C-YA AT THE TRACK!!
Old Jul 22, 2002 | 04:47 PM
  #95
LT1TONY's Avatar
Post
I put a fuel pressure gage on it yesterday and mounted it to the windshied and checked pressure at WOT and it didn't even budge so fuel pressure is good! I borrowed my buddies brand new coil and module and i'm going to try that tonight. I'm also going to take a spray bottle with water and start spraying the wires and coil area to see if i develop any sort of miss or anything. If this stuff doesn't work than i'm going to swap my MSD 6AL box and pill with his to see if this could be the problem.
I'll keep you guys posted.
Tony
Old Jul 22, 2002 | 05:09 PM
  #96
HEATH's Avatar
Post
i havent tried the water bottle yet. so im curious.. good luck.
Old Jul 22, 2002 | 05:29 PM
  #97
Post
well i didnt get to fuel pressure test it, the car was too hot and we would have had to burn our arms to get to where we need to. unfortunately im starting to just live with it for now and work on my next problem, which is to fix my amp i might have fried (see stereo area if ya wanna help).
ill keep you posted,
brian
Old Jul 22, 2002 | 05:34 PM
  #98
KWKSLVR's Avatar
S.E. Region Moderator
Post
Have any of you guys checked for an Intake Leak? Granted, it seems like an ignition problem at first, but don't rule out vaccum.
The sure fire way to tell is to just hook up a FPG and monitor your fuel and see what happens when you reach 5100rpms. Everyone seems to be swapping out ignition only components. What about the fuel system? Injectors, etc. could stand to be looked at, especially if everyone has a stock fuel system.
BFBA Treasurer/Secretary
1997 Trans Am M6 13.676@104.07
1998 Intrepid - The Most comfortable beater on Earth.
Whats a 60ft?
Bark like hell, Bite -yeah right.
Birmingham F-Body Association
Home Page
PBMotorsports
AERC
NABR
Old Jul 23, 2002 | 08:53 AM
  #99
LT1TONY's Avatar
Post
I have over the valve cover looms with brand new custom Taylor wires i made. All i have to say is i started the car last night in the dark no lights outside and i was looking in the engine bay to see if anything was arching. (you guys should do this too) I realized that a few of my wires would arch like to the valve cover. (once again these are brand new 8mm Taylor wires) I moved everything out of the way so nothing touched anything metal and took it for a ride at my certain hwy spot and got on it 3 times from a dead stop and hit 6800 with no problems. Did this 3 times and the car was just flying. I decided that i would try it 1 more time and it started acting up a little again. I stopped and popped the hood open again and saw that a couple of my wires were doing the same thing. Would only arch every once in a while. Anyway i'm leaning towards my new wires more and more now, sucks that they are brand new, but this has got to be it. I checked it with my LT1 Edit and it's not lean everything normal, checked fuel pressure mounted on windshied with gage, checked spark plugs, replaced coil and module, no vacuum leaks. I SUGGEST you guys check the wires at night with no lights on or anything and see if anything is sparking. Also take a water bottle and spray down your wires to see if it starts missing. I'll let you guys know what i do with my wires. Sorry so long.
Tony
Old Jul 23, 2002 | 09:19 AM
  #100
HEATH's Avatar
Post
THE INJECTORS ARE NEXT TO HAVE CHECKED ON MY LIST OF BURNING MONEY, FUEL PRESSURE IS FINE, FILTER AND PUMP IS NEW...
ON THE WIRES I STILL HAVE TO CHECK MINE, I KNOW I HAD ONE ARCING ON IT AT NITE, BUT IM ALSO GOING TO CHANGE PLUGS WHILE IM UNDER THERE. ITS BEEN SO DAM HOT. IM JUST TIRED OF WORKING ON IT. IM STILL TOSSED UP BETWEEN USEING MY MSD WIRES or use factory delco wires, my MSD has only been on there for 5000miles but that is when my problem started IM LEANING TOWARDS THE BAD GROUND CONCEPT NOW> im going to check that out
later also/.
94 T/A LT1 A4
Old Jul 23, 2002 | 10:46 AM
  #101
LT1TONY's Avatar
Post
I really like my Accell extreme 9000 wires that i had on it before. But since i went over the valve cover looms and long tube headers i went with the Taylors and i custom fit them. I also don't feel like messing with the wires especially when you have long tube headers. All in all, i'm tired of messing with this also. But i will fix it.
Tony
Old Jul 23, 2002 | 10:25 PM
  #102
HEATH's Avatar
Post
just an update.. 11pm ;-(
i just finished checking my car out, it consisted of changing wires, plugs coil wire,
rerouting some to stop arcing, new opti, fixed leak on intake below, lossened rt side rockers 1/4 turn (my freind adjusted those)
checked the grounds on engine, volt tested engine for bad ground, the only thing i havnt done is test injectors. all that in 4 hours and it didnt do SH:T,, oh well the dealer i had work on the car last week left the RO open so i could bring it back and they can try some other things so wish me luck. im wishing all of us luck! (THIS BLOWS,)
94 T/A LT1 A4
Old Jul 29, 2002 | 04:58 PM
  #103
HEATH's Avatar
Post
mines at the dealer now for 4 days and hes tried a list of 17 or so things some of which ive tried and hes found nothing. he has called GM tech assistance and they know nothing re: this problem dont you think its B/S as many people thats had this and one of the largest dealers in the US cant finger it out AAAAAAAAAAAAAAAAHHHHHHHHHHHHHHH!!!!!!!!
does any boby have a clue how to get GM involved with our Q? or any other GM based troubleshooting websites>>>??? thanks
heath,
ttt
Old Jul 31, 2002 | 10:34 AM
  #104
HEATH's Avatar
Post
now someone at tech assist. told him they have had missing problems withe some kind of pump in the trans going bad
COULD THAT BE TRUE????????????????????????????
im not a tranny tech by no means but is that possible and if so why would it all of a sudden start doing it when i put the head and intake back on it ...
Old Jul 31, 2002 | 10:55 AM
  #105
Tibbys96Z's Avatar
Post
HEATH in your case my first guess would be the torque converter.
Sleeper, I'd have to go with a fuel problem.
