please help.....have a constant miss over 5K, please read, i cant figure it out....
Old Jul 31, 2002 | 12:04 PM
  #106
HEATH's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Tibbys96Z:
HEATH in your case my first guess would be the torque converter.
Sleeper, I'd have to go with a fuel problem.
</font>
fill me in here how can a t/c do that ?
thanks
Old Aug 9, 2002 | 10:05 AM
  #107
HEATH's Avatar
Post
****** i finally got mine back from the dealer after 3 wks they didnt find squat???
now what they tried almost everything and could not find it?
now my next chance is a shop that has a dyno and some serious diagnostic capabilities? 90$per hour.
ttt
TTT
Old Aug 9, 2002 | 10:35 AM
  #108
97ss1826's Avatar
Post
In my car the miss feels like if you push the clutch in for a split second. Then it just picks right back up. Just has a dead spot at about 4800. It did this with my old plugs and wires and still does it now. First time it did it, it threw an EGR code....not sure if that may be a problem, as I dont know how the EGR system works.
Old Aug 9, 2002 | 10:41 AM
  #109
HEATH's Avatar
Post
mine feel like a rev limiter almost it seems as if it is getting worse if you stay into it it will hit 5000 rpms and just stay there and flutter, it used to go right through it and up to about 5900 and shift but know it just hangs there not gaining any speed and you have to let off&gt;???????????????????????????
94 T/A LT1 A4
SOME MODS,KINDA QUICK
times- C-YA AT THE TRACK!!
Old Aug 9, 2002 | 04:22 PM
  #110
sleeperZ96BT's Avatar
Post
well seems like this thread wont die!! well, i got my new clutch in and it feels strong. ill be getting on it tomorrow AM and see if it might just have been the clutch sucking. i know this doesnt help you HEATH, but it may help some of the M6 if it checks out. what did they look for at the dealer??
brian
Old Aug 9, 2002 | 04:39 PM
  #111
HEATH's Avatar
Post
EVERYTHING I DID Xs 2
THEY BLOCKED OFF EGR, REPLACED INJECTORS,RAILS,OPTI,PLUGS WIRES COIL, ALL BACK TO GM.TESTED FUEL SYSTEM. BOOSTED PRESSURE ON PUMP,KNOCK SENSOR, 02SENSORS,MAP,MAF,PCM AND THEN REPROGRAMED THE FACTORY PCM W LATEST UPDATE?,
AND RAN IT W/EXHAUST UNHOOKED AT FLANGE!
A FEW MORE THINGS BUT I CANT REMEMBER
soo sorry about the caps~~~~~~~
what do you think??
good luck w/your clutch,
Old Aug 9, 2002 | 05:38 PM
  #112
Schantin's Avatar
Post
I didn't read the 108 posts in between... but as for the initial prob (missing above 5K RPM), here's my $0.02. Do you have CAI? I ask because my initial cold air setup starved my engine for air above 5100-5300 RPM and it missed and stuttered badly. (I have the Lingenfelter setup now and no more high end misses.) When it first happened, I had just fiddled with the CAI, so I hooked the filter up just past the MAF sensor to eliminate the pipe bends. The prob went away immediately. Anyhow, if your engine is starving for air at high RPM, this might be your prob. A dirty filter (or a wet one too), obstruction in the pipe, or lack of venting within the fenderwell could all cause this prob. Hope this helps.
Old Aug 9, 2002 | 06:13 PM
  #113
Post
i know it was mentioned before, but i never checked my K+N CAI. it has been ~15,000 miles since i bought it new, maybe it needs to be cleaned. funny that it would happen so consistently at the same place everytime, id think a dirty filter would be rather inconsistent. HEATH, you using the K+N CAI?
brian
Old Aug 9, 2002 | 06:59 PM
  #114
hsyr's Avatar
Post
Mine had a consistant miss over 5000rpms and I changed my EGR valve ($120 CND) and that fixed the problem. How many of you have bought a new EGR valve? Personally if your going to I would wait and take out the old one and clean it with a drill bit by hand. If that doesn't fix the problem buy a new one. If that doesn't fix it I don't know.
Old Aug 9, 2002 | 10:30 PM
  #115
Hagancue's Avatar
Post
Heath and 97SS,
Sorry to hear that you are both still on a quest. So am I. I have the same problem and have done all but the Opti. Mine is an M6, so TC is not an issue for me. Don't really expect that it is for you either, guess you don't ever really know though. Only thing I did that had a marked effect on the problem was new plugs (Bosch platnum) and fresh di-electric grease in the boot. Really helped, but did not entirely fix it, now after 1 month I am back to where I started. UGH.
Too many with this problem. There is a common cause. When any of us finds it, we will all be better off!!
Bill H
Old Aug 10, 2002 | 12:52 AM
  #116
Post
FWIW i have a new EGR and that didnt do jack!
brian
Old Aug 12, 2002 | 11:44 AM
  #117
HEATH's Avatar
Post
iDO! have the K&n fipk, ill check it tonite when i replace a foglamp bulb.
it would be awesome if that was it i know i never checked it an neither did the dealer but that would have to be coincidental as hell
that it started doing it the first time i jumped on it after the reassemble of the upper half
oh well its worth a try. i wont get too excited until i see something that fixes this damn problem..
were going to have to have a gathering just to celebrate figuring this out?? if were still young enough to party. im only 25 so im getting worried.
Old Aug 13, 2002 | 12:14 AM
  #118
Hagancue's Avatar
Post
Hey Heath and Sleeper,
I too was intrigued with the idea of the CAI as a cause, particularly as I have never even started mine with the stock set up. Well.....I obviously had to check this out. Unfortunately to no avail. I started by removing the entire intake to the throttle body. Installed the stock elbow, the MAF, and then the K&N. I had to remove my hood to accomplish this as I am short of space. Did a drive test, no change. Then I took the K&N off and ran it (only one pass on my test road) with no filter whatsoever. No difference. Well - not quite, it did not make much power. Think the MAF did not like the open flow. Bottom line I have now crossed this one off my list of possibles.
I will not give up. If I have any news here, I will post straight away. You guys please do the same.
Heath any news on the $90/hr guys??
Bill H
Old Aug 13, 2002 | 12:47 AM
  #119
Post
Bill-here is my latest issue.......
http://web.camaross.com/bb/Forum1/HTML/109661.html
should know tomorrow if its the opti or clutch........will post results. check the link and let me know what you think.....
brian
Old Aug 13, 2002 | 02:23 AM
  #120
grohl12's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by sleeperZ96BT:
help needed!! i need to figure this out!! ive been dying to dyno and go to the track but feel its useless with the hesitation and wouldnt be accurate anyways of how the car performs....ill be trying some ideas soon, but please keep suggesting! bill h.....hows it going on your end?
brian
</font>
I just made a post. I had the same problem. It was ignition. I replaced my plugs and wires and is about 90% gone but wasn't able to get to one of the plugs so we'll see... But I also wanted to get the MSD Ignition and blaster coil
Jet Black '93 Z28 M6
K&N FIPK, BBK Headers, Flowmaster, Hurst Shifter, NGK Iridium TR55-IX Spark Plugs/Magnecor Wires, Clear Corners, Body Kit, Interior Light Switches, Indiglo Race Pedals, Indiglo Gauges, Sequential Tail Lights
White Z28 and 5.7L LT1 decals and white rear CAMARO inserts.
Stereo:
Alpine 7864 CD Player
MTX D1000 Bass 1500W Amp
Kenwood Excelon KAC-X501F 1200W Amp
(2) 12" Polk Momo Subs
Polk Momo MM465 speakers w/ tweets and crossovers
My Website
