Intake restrictions. How to diagnose.
Old Mar 31, 2009 | 08:48 PM
  #61
wrd1972's Avatar
If I could make a lid work with the stock or SS hood and NOT hack up the metal crossmemebr I would. I have a used K&N FIPK on the way. I am going to get the results from it and compare it to the rest of my findings ASAP.
Old Apr 4, 2009 | 08:15 PM
  #62
wrd1972's Avatar
Update.
Installed the K&N FIPK and it is about 1KPA better with less pressure loss than my AS&M CAI.
All in all I improved my MAP by 2 KPA by switching to a 58mmTB and the K&N FIPK according to my data logs.
52mm TB/AS&M CAI (left)
58mm TB/K&N FIPK (right)
look at the MAP line (pink)
Old Apr 4, 2009 | 09:18 PM
  #63
<Puck>'s Avatar
Originally Posted by wrd1972
Update.
For what its worth, on back to back dyno runs with a H/C stock shortblock setup without unstrapping the car from the rollers removing the intake from the elbow(open TB) gave me 2.x rwhp more then with the full K&N FIPK and a dirty filter. Power wise it is pretty much zero restriction on a stock cube build. Tested within 5 mins of last run so no cool down time or any tricks - we were just checking for intake restrictions like you are. It turned out my MAP was going.
Point being, if you are stock cubes then a FIPK is already pretty much overkill On most builds these engines are head restricted, not intake.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
