Intake restrictions. How to diagnose.
If I could make a lid work with the stock or SS hood and NOT hack up the metal crossmemebr I would. I have a used K&N FIPK on the way. I am going to get the results from it and compare it to the rest of my findings ASAP.
Update.
Installed the K&N FIPK and it is about 1KPA better with less pressure loss than my AS&M CAI.
All in all I improved my MAP by 2 KPA by switching to a 58mmTB and the K&N FIPK according to my data logs.
52mm TB/AS&M CAI (left)
58mm TB/K&N FIPK (right)
look at the MAP line (pink)
Update.
Point being, if you are stock cubes then a FIPK is already pretty much overkill
On most builds these engines are head restricted, not intake.
