can you tell me what these trouble codes mean?
Old Apr 4, 2009 | 04:57 PM
ssclone's Avatar
well i finally found out what codes, can you tell me what they mean?
code 36 ECM detected less than 40 high resolution timing pulses between each low resolution pulse for 5 consecutive cycles.
and
42 PCM did not detect any EST signal within 84 crankshaft revolutions.
this is in a 94 A4 ta.
thanks
aaron
Old Apr 4, 2009 | 09:11 PM
It generally (and most times) means you have an optispark problem. Either the opti, itself, or the electrical harness.
Old Apr 4, 2009 | 09:45 PM
ssclone's Avatar
that is what i was thinking it could be.
thanks again man. looks like ill be checking out the opti tomorrow.
aaron
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
